Old 11-08-2012, 05:21 PM   #1
1ghost
Member#: 324535
Default xxr527 fitment
so heres my question I am looking at buying a set of xxr527 in bronze for my 2012 wrx sedan. I am going to go with the 18" but am not sure of with and off set. the car is stock height for now but will be lowering in future about an inch. I would also like to run a 255-265/35/18 preferably with out fender rolling. any suggestion/info would be great. If your running this set up and have pics would be awsome. thanx in advance.
1ghost is offline   Reply With Quote
Old 11-08-2012, 06:14 PM   #2
sc00by4life
Member#: 97135
you haven't included NEARLY enough information.
you haven't searched either.
if you do NOT want fender rolling, you shouldn't buy any wheel wider than 8" with a 235/40 tire.
Old 11-09-2012, 01:40 PM   #3
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
1997 Legacy Outback EJ25
First off. You need to read this entire thread:
Guide to fitting wheels and tires to the 2011+ WRX
Secondly. You aren't fitting any 527's without fender modifications. 18x8.75" +35 is going to stick out about 1.1" further than your stock setup. With that much sticking out you will rub even on stock suspension and if you lower you WILL DEFINITELY need a roll and pull on all 4 corners. This gets even worse when you bump up to the 18x9.75" +20 which will stick out about 1.7" farther than the current setup and will require coilovers to fit because camber will be needed. Also running a +20 has some ramifications with regards to steering and steering feel. Go read articles about numb turn in and scrub radius. You need to do lots of reading before you go willy nilly buying wheels. Also, XXRs don't have the greatest reputation. You have to question the manufacturing and metallurgy of wheels that are ~$160 each.
Improbus is offline   Reply With Quote
