Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 11-02-2012, 08:33 AM   #1276
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by sc00by4life View Post
wrong. its the exact same face. offset has nothing to do with the wheel face.
Whaaa?!?!
Is this a joke?
Old 11-02-2012, 01:27 PM   #1277
johnmkv
Member#: 300848
LR
Originally Posted by xluben
Whaaa?!?!
Is this a joke?
Exactly can someone please explain? It would make sense that offset also determines concavity of the face
johnmkv is offline   Reply With Quote
Old 11-02-2012, 02:06 PM   #1278
Aczwild
Member#: 71721
'98 RS (Race Car)
'13 GMC Sierra (Tow Rig)
It can determine the concavity of the face if the depth is great enough and the mfg wants to have several different molds/tooling paths. However depending on the company there will be 2-3 typical faces for concavity and you machine the backside of the hub to set your final offset. Therefore, depending on the wheel type and desired offset the face may not change.
Aczwild is offline   Reply With Quote
Old 11-02-2012, 03:32 PM   #1279
sc00by4life
Member#: 97135
Manufacturers typically have several face design, but it does not mean that they are a product of offset.
Hub depth Is what effects offset, but doesn't effect the wheel face as the hub depth can be as thick or thin as the manufacturer specifies.
An easy example to think of is the 18x9.5 +40 nt03 and the 18x9.5 +27 nt03. Exact same face, but one has a shallower hub for a higher offset. The +27 also clears brembos simply because the hub is so deep, and the +40 doesn't.
17x8 +48 and 17x8 +35 rpf's also have the same face.
18x10 +38 and 18x10 +18 xd9's have the same face and same amount of lip. Again, the lower offset clears brembos simply because of the hub depth.
You cannot say for certainty that offset determines wheel face or brake clearance. It is all based on the specific wheel design. Face design is typically based on wheel width, though that isn't always the case either.
Old 11-02-2012, 04:49 PM   #1280
rdejesus486
Member#: 320454
sub'd for ownage.
rdejesus486 is offline   Reply With Quote
Old 11-03-2012, 12:19 AM   #1281
chevZ
Member#: 335162
Obsidian Black
I'm new around here (and from australia) but this thread really helped me to figure out what tyres and size rota's i was going to buy.
Thought I would give back by posting how mine is sitting at the moment and my experiences, since it seems from reading every page of this thread - there are lots of people that were in my shoes and wanted the same fitment i wanted, without the hassle.
MY11 WRX
Rota Grids
18"
9.5" Wide
+38 Offset
255/35/18 Marshals (By Kuhmo)
Rolled Rear Guards
STD Coilovers.
When i slapped these on, my rear was fine.. to be honest i think i could go lower another 1-2cm in the rear but i like having passengers. The front was the only issue, to fix that i've put -2 degrees of camber on the coilovers and i've had no issues since unless i fly around a corner or hard turn into a bump.. then it scrapes a little. My biggest issue is with that sort of camber on front, in the wet or around a corner if i put my foot into it - it torque steers a little.. So i'm gonna drop it back to -1 degree and see if that helps.. if not i'll look for ways to roll the front guards.
Either way no huge problems, drives like a charm and fits really snug. In my opinion don't go 255's unless you have coilovers or a kit to adjust camber, or at the very least roll the front guards also.
chevZ is offline   Reply With Quote
Old 11-03-2012, 07:46 PM   #1282
vikramaditya1986
Member#: 281606
Originally Posted by Mach V Dan View Post
Because of the low +35 offset, I think you'll have to roll with anything larger than 235/45R17, and you MIGHT have to roll even with the 235 once the car is lower. For an easier time fitting larger tires, get a higher offset wheel. (+42 would be better, hint, hint.)
--Dan
Mach V
FastWRX.com
Hi Dan,
Just wanted to let you know that I got around to putting some rather mean Rota Grid 17x9s on the car, and it turned out rather well really wide stance and much more flush than I expected! Car drives really well, and I took the opportunity to finally wring it out at an AutoX event. Thanks for all your help and the detailed information!
I'm currently on the OEM Dunlop 235/45/17 tires, but in the future I plan on going to maybe 255s, accompanied with rolled rear fenders and lowered suspension.
FYI for newbies putting on aftermarket rims, here's the list of stuff I bought to put the new rims on - everything came together effortlessly:
* A set of ROTA Grid 17x9 5x100 42mm-offset 73.1mm bore wheels
* A set of aluminum 56mm-73mm hub rings to go with the wheels
* TPMS sensors w/ valve stems, and new long lug nuts that fit the wheels
* For tires, I used my OEM Dunlop 235/45/17s
vikramaditya1986 is offline   Reply With Quote
Old 11-03-2012, 07:58 PM   #1283
PearlRex11
Member#: 284420
2011 WRX Sedan
Edit, the picture came up now. Looks good. Have anymore pictures from the side?
PearlRex11 is offline   Reply With Quote
Old 11-04-2012, 07:51 PM   #1284
b0yt0y
Member#: 334294
2013 WRX Sedan
WR Blue
Hi guys! I recently ordered a 2013 wrx and It willbe delivered by December. I have a few question about the wheel and tire fitting on each other.
Will a 235/45 R17 fit on a 17x9 or 17x8.5 wheel?
The reason I asked this is... I bought winter tires since the car will arrive in winter and I am planning to buy wheels for the stock tires that i can use for the summer.
Thanks in advance
Oh LOL! I just found the answer to my question... Its the post before me
So I guess the question now is, Is there a difference or drawback in the performance of the car?
b0yt0y is offline   Reply With Quote
Old 11-04-2012, 11:39 PM   #1285
vikramaditya1986
Member#: 281606
Default Pictures
Here are some quick-pics taken on my cell phone right before I swapped the tires/wheels out for my winter set (OEM 17s with OEM-size Conti DWSs). As I said, they turned out pretty flush (and I wasn't even trying!). The challenge will be to put 255s on these wheels and not rub the fenders - I guess I'll have to roll the rears at least.
Old 11-04-2012, 11:45 PM   #1286
vikramaditya1986
Member#: 281606
Thanks in advance
AFAIK the OEM Dunlop 235s will stretch up to a 17x9 at most (as I did with mine). Yea, it looks like you're aiming for a setup similar to mine - OEM wheels with winter tires, and aftermarket wide wheels with OEM Dunlop tires. Please scan this thread thoroughly; in particular for my questions, and Mach V Dan's answers to them - they contain detailed information regarding offsets, and rim and tire widths.
Thus far, car feels great - I even took it AutoXing (granted I'm a novice, but it still felt pretty good). For steering feel among other things, it's important to keep the offset to a reasonable number: stock is +53, my Rotas are +42 and experts seem to recommend +30 or more typically. Hope this helps.
Old 11-06-2012, 09:22 PM   #1287
Mach V Dan
Member#: 12029
Originally Posted by XERO287 View Post
I also got new rear tires as it was bugging me:
Um, what? What size did you go from and to? Why was it bugging you?
Good post.
Thought I would give back by posting how mine is sitting at the moment and my experiences, since it seems from reading every page of this thread - there are lots of people that were in my shoes and wanted the same fitment i wanted, without the hassle...
Another good post. Lots of good specific info. Thanks.
Originally Posted by vikramaditya1986 View Post
Hi Dan,
Just wanted to let you know that I got around to putting some rather mean Rota Grid 17x9s on the car...Thanks for all your help and the detailed information!
Good specifics here, too. Sometimes people ask me which kind of hub ring (aluminum or plastic) is superior. Aluminum is strong and doesn't melt, but sometimes bimetal chemical reactions can make the metal rings very hard to remove from the hub -- we've had to chisel them off at times. Plastic/composite rings can sometimes melt, or just break down, under very high heat (like the heat generated from road course driving), but are usually easy to remove. If it's not going to be used for road racing, either type should be fine.
--Dan
Mach V
FastWRX.com
Old 11-06-2012, 09:40 PM   #1288
drolon1
Member#: 330189
2013 WRX
I was wondering how an 18x9.75 with a +20 offset would fit with 265/35/R18 tires. would i need a fender roll on stock height? when i lower it?
drolon1 is offline   Reply With Quote
Old 11-06-2012, 09:52 PM   #1289
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Ill tell you what somebody told me when i asked about this same size rim. It going to look terribly cholo at stock height. That size is really meant for someone with coilovers to be able to properly fit them. With that size, you will rub like crazy and really wont be able roll, pull or camber enough on stock suspension.
I was about to buy a set of rims and tires off a nasioc member that were this size. The guy had them on stock suspension and said he was rubbing extremely bad even with a roll.
imac6471 is offline   Reply With Quote
Old 11-06-2012, 10:13 PM   #1290
sc00by4life
Member#: 97135
roll....pull.....you also most likely wont get enough camber without heavily modifying the suspension......
i can tell you haven't even read this thread at all.
Old 11-07-2012, 10:53 AM   #1291
jesup16
Member#: 306393
2009 Legacy 3.0R
After a lot of reading here is what I have and plan to do:
2013 WRX 5-door Limited
Wheels: Miro 111 18x9.5 +40
Tires: 255/35/18
Suspension: Plan on staying stock
Fender mods: I've rolled fenders on 3 of my cars and I'm ok with rolling if I have to, but I don't want to pull.
From what I've read, this fit should work.
My question is for anybody running something similar on stock suspension. Do you think I'll have to roll? If so, does it need to be a completely flat roll or can I get a away with a small roll? I've rolled a few fenders before, and getting them completely flat takes a little more work.
I'm also open to any input on tire sizes, brands, etc...
jesup16 is offline   Reply With Quote
Old 11-07-2012, 12:49 PM   #1292
sc00by4life
Member#: 97135
Tires: 255/35/18
You should be OK depending on the brand of tire you get. You could roll the rear just to be safe.
And when rolling...in my opinion there is only one way to truely roll fenders - flat. Do it once and never think about it again.
Old 11-07-2012, 01:44 PM   #1293
jesup16
Member#: 306393
2009 Legacy 3.0R
I'm thinking about BFGoodrich Comp Sport-2's. The spec's have them with a tread width of 10.2, which is about 1/2 more than most 255's and a little less than most 265's. They are for DD.
Old 11-07-2012, 02:15 PM   #1294
XERO287
Member#: 253541
2011 WRX 5DR Premium
--Dan
Mach V
FastWRX.com
I didn't change the size or type of tire. I simply put on 2 new (of the same) rear tires as the fender rubbed a significant portion out of the sidewall and was causing vibration about 65 mph.
Don't be alarmed good sir. All was done in <25 miles as well so tread depth is even. All 4 tires are still at 265/35/R18.
Thanks for the concern though!
XERO287 is offline   Reply With Quote
Old 11-08-2012, 09:06 PM   #1295
texascanuck
Member#: 317045
2012 WRX Hatchback
Default couple of tire choices
Tires: 255/35/18
The Toyo Proxes R1R are good value for the money. I think Tire Rack has them for $884/set of 4 in the 255/35-18 size. My pick for a DD.
I also like the Yokohama Advan AD08 tires. But they will be more expensive.
texascanuck is offline   Reply With Quote
Old 11-08-2012, 10:10 PM   #1296
ninjaspork19
Member#: 316185
Ice Silver Metallic
Hello there,
I have a 2012 WRX sedan and I'm a little confused while trying to purchase new rims/tires for the summer. I've read through the sticky threads here for hours and its just confusing with so many opinions.
I'm a daily driver on my WRX and live in Michigan. I just ordered a set of winter tires to fit my stock rims and plan to get 18" rims and new summer tires to have 2 sets, one for summer and one for winter.
My question is, is searching wheels on tirerack that "fit my vehicle" the best way to go for a daily driver not looking to increase performance or roll fenders or fill the wheel gap or lower the car or blah blah? I'm not sure what the specs are on the stock rims other than they're 17". It looks like the largest I see that "fit my vehicle" are 18x8 on tirerack, but so many people on this forum say to go to 18x9 or 18x9.5, I'm not sure what stock width size is. Offset and backspacing I'm not quite sure on either. It just seems to me that what tirerack says "fits my vehicle" are much smaller than what everyone here says to do.
What I'm seeing most of on tirerack is something like:
Offset: 45mm
Backspacing: 6.25"
Bolt Pattern: 5-100
Rec. Tire Size: 235/40-18
Any help is really, really appreciated. I've never gotten aftermarket rims for any car and I want to make sure I do it right for the daily driver in me. I also assume I need another TPMS setup for the new set of tires so that one system is on each tire setup? Sorry this is all just way overwhelming and confusing after hours of reading posts. So many opinions and setups.. I just want something close to stock or maybe fill up the wheel well a little bit but don't want to mod anything else. Just new 18" rims! so complicated.
ninjaspork19 is offline   Reply With Quote
Old 11-08-2012, 11:16 PM   #1297
shuubee
Member#: 315645
hey guys i need some help. Today i lowered my 2013 sedan on kw v1. I have 18x8.75 35et xxr on 245/40r18 pilot sports. im lowered to where you can see barley see the tire. I am rubbing crazy on the rear with my fenders rolled, also when i turn the wheel to the left i hear this popping noise? I see people running 18x9.5 38 et on 255/35/r18 and dont rub. Can anyone please help me? im not sure if i should get new tires or raise my car higher?
shuubee is offline   Reply With Quote
Old 11-08-2012, 11:24 PM   #1298
sc00by4life
Member#: 97135
You probably don't have enough camber in the rear, which means you'd rear lower control arms.
Old 11-08-2012, 11:58 PM   #1299
shuubee
Member#: 315645
i have -3 in the rear. do you know why my front has a popping noise when i turn? is it the tire hitting the plastic?
Old 11-09-2012, 12:17 AM   #1300
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
Probably worth having a friend just look while you're driving/turning the wheel.
mw1484 is offline   Reply With Quote
