Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 10-04-2012, 06:57 PM   #251
Newkid17
Member#: 334165
That's one beautiful Svx! One Svx owner to another! Awesome job!
Newkid17 is offline   Reply With Quote
Old 10-10-2012, 10:26 PM   #252
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
So.... over 4 years into the start of this project...
... with many diversions...
... and consistent passion for the SVX
... I wander in to read the entire thread and am completely enthralled!
Great stuff!
T-WRX is offline   Reply With Quote
Old 10-17-2012, 09:15 PM   #253
sidewayz
Member#: 5810
2001 S366 2.5RS
Anyone wanna buy a 92 Claret with 130k on it? Cheap cheap
sidewayz is offline   Reply With Quote
Old 10-18-2012, 11:58 PM   #254
flystiguy14
Member#: 74416
91 SS leggy
pearl white
How much? whats wrong with it? and how bad is the rust?
flystiguy14 is offline   Reply With Quote
Old 11-08-2012, 01:14 AM   #255
TireIron
Member#: 218469
96 SVX
Green
Some tips on rear bushings...
The kartboy outrigger bushings work (small-thick on bottom, large-thin on top).
The 08+ kartboy rear subframe bushings (4 large-thick) fit to mount the subframe in place.
The 08+ whiteline diff bushing inserts work with a tiny bit of trimming on the sides of the lower insert piece.
Yes, thats an R180 with them.
The rear TIC trailing arm bushings are a direct fit after removing the old bushings and sleeves.
The front TIC trailing arm bushings work with some major modifications. The sleeves need to be drilled out for the larger bolts (machine shop took care of no problem). Also, the overall bushing width is too large. I needed to cut down the bushing and sleeve by 1/4 inch. I took 1/8 inch off the outside of each bushing and 1/4 off the sleeve.
Bushing installed not cut down, tightened fully, not enough threads engaged.
Bushing and sleeve cut down.
Installed and tightened down after cutting. Nut is fully engaged on bolt thread this time.
And the whiteline lateral links bolt in. The swaybar mounts will give me something for a custom 3 piece swaybar to mount to easily and give more room for tires inward (the OEM swaybar is very close to the rear tires).
TireIron is online now   Reply With Quote
Old 11-08-2012, 10:54 AM   #256
dragoontwo
Member#: 275500
1992 SVX
This is info I have needed for a while. Did you use both halves of the inserts? Many thanks for this.
dragoontwo is offline   Reply With Quote
Old 11-08-2012, 10:59 AM   #257
kuneefay
Member#: 266477
1996 F-250 7.3L
Great thread and great advice. Planning on starting my own svx track project within a year.
kuneefay is offline   Reply With Quote
Old 11-08-2012, 01:16 PM   #258
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The trailing arm forward bushings we have done before, but did require a remachined crush tube. i haven't done a lot as aside from me, and one local customer I was not aware of any interest.
That is good to know on the rear diff inserts. I haven't even tried them yet on the SVX.
Old 11-09-2012, 12:16 AM   #259
TireIron
Member#: 218469
96 SVX
Green
No, the package comes with 4 pieces. 2 of them are the diff inserts, which are used here, they have 2 "sticks" and 1 "crescent moon" sticking out of them each. The other 2 pieces are outrigger inserts I believe on the newer cars, or some other piece. You just use the 2 for the diff and insert them from the rear after trimming an 1/8 to 1/4 inch off each side of the "crescent moon". I should've gotten a couple pictures before inserting them, but I was trying to get the whole rear end done in a couple hours and pressing for time.
These should also work on the older legacy and impreza diffs with the same style bushing for those who don't want to fight and do the superpro bushings (will be a very tight fit and require even more trimming). The superpro bushings for the older legacy and impreza however DO NOT fit the SVX diff crossmember, which is why I went with this solution. The SVX diff bushing has a larger diameter and is thicker than the legacy and impreza bushing.
The only bushings that were really a problem were the trailing arm forward bushings. Having the sleeve machined out for the 14mm bolt was not an issue, but realizing after I had everything installed that the bushing was overall too thick and having to take it all back apart and trim things down was very tiring at the end of the day when it was getting dark and cold. Knowing ahead of time should save someone else some time if they try and install them in the future I hope. A razor knife worked well for trimming the 1/8 inch off each bushing half and my chop saw made quick work of the 1/4 inch off the crush sleeve. Who knows, TIC may even make a couple sets this way and throw them on the shelf and list them up for those who can't modify them on their own. After all, they only list 1 product on their site that fits the SVX, when there are plenty more that do thanks to subaru reusing designs.
Old 11-09-2013, 10:53 AM   #260
bstash19
Member#: 358851
2012 wrx hatch
lightning red
any new updates on the project?
bstash19 is offline   Reply With Quote
Old 11-19-2013, 04:56 PM   #261
lolsvx
Member#: 369355
So awesome to see someone doing awesome stuff to an SVX
lolsvx is offline   Reply With Quote
Project SVX Hites General Community 63 03-03-2009 04:50 PM
It's just after 3am and I just finished installing the TiC rear diff race bushings prototypeWRX Texas Impreza Club Forum -- TXIC 14 02-02-2007 07:02 PM
Has anyone tried the TiC Klunk Killer yet? Greg B Transmission (AT/MT) & Driveline 14 10-04-2005 01:28 AM
project SVX-T could still be alive kastle SVX Forum Archive 2 02-12-2001 12:01 AM
