Old 10-31-2012, 11:05 PM   #1451
ans2k
Member#: 315631
2012 Impreza Sport
Originally Posted by auskip07 View Post
Im not sure why you consult an aftermarket company about stock parts. The default answer is leave it. But in reality im sure taking it out would be fine. I dont remember seeing one on mine.
i think it might just be the prez model
Old 10-31-2012, 11:20 PM   #1452
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Perhaps he is inquiring about putting the Perrin drop-in filter and wants to know if there is an issue installing it with the secondary filter?
ST Eye is offline   Reply With Quote
Old 11-01-2012, 03:55 PM   #1453
kenny doggins
Member#: 326540
2012 Impreza MT SP
ok so does removing it get more mpg's or anything? It can't just be a useless part.
kenny doggins is offline   Reply With Quote
Old 11-02-2012, 06:27 AM   #1454
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
It would probably improve airflow a bit and improve MPGs by a miniscule amount though.
Old 11-02-2012, 11:06 AM   #1455
mrbloink
Member#: 333058
I just got the grimmspeed pulley removal tool today, it doesn't quite fit on the stock pulley. You can get two bolts into the pulley but not the rest. It should however be enough to remove it. Hopefully I'll be able to put in the perrin on Monday on my day off
mrbloink is offline   Reply With Quote
Old 11-02-2012, 12:26 PM   #1456
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I am interested in this part but could you please give us the weight of the new vs the old part so that we can have something to compare to. (helps to use the same scale) If its drastically different this part might be worth the effort.
Old 11-02-2012, 12:28 PM   #1457
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Yep im noticing that may be the case with alot of little differences.
Possible.
Old 11-02-2012, 02:40 PM   #1458
mrbloink
Member#: 333058
I will def be comparing the stock vs the perrin pulley. I won't know exactly until I get a day off to get the stock pulley out. It doesn't actually seem like its a lot of effort, and for $120, you cant really go wrong
Old 11-04-2012, 12:37 AM   #1459
pkL
Member#: 313093
2012 Impreza 2.0i
What about any potential issues with warranty? Otherwise I would be all over this, given that it fits and is compatible.
Old 11-04-2012, 02:10 AM   #1460
ST Eye
Member#: 73068
It all depends on what the engine failure is.
Old 11-06-2012, 01:55 AM   #1461
pkL
Member#: 313093
2012 Impreza 2.0i
Yeah that makes sense but knowing how dealers are they're probably try and void and deny your warranty anyways with or without the Magnusson-Moss act.
Old 11-06-2012, 03:17 PM   #1462
Irongrave
Member#: 325040
2012 Impreza 5door
DMG
I pulled the screen out today. Its layers of plastic fabric mesh with a charcoal/carbon media impeded between them. My best guess is that its there to remove some of the airborne pollutants thus helping it lower the emissions out of the tail pipe. I will report back with any codes if there are any.
Irongrave is offline   Reply With Quote
Old 11-08-2012, 01:23 AM   #1463
pkL
Member#: 313093
2012 Impreza 2.0i
From your description, the material seems like that of an air purifier filter. So it probably serves the same purpose too.
Old 11-08-2012, 08:52 AM   #1464
Irongrave
Member#: 325040
2012 Impreza 5door
DMG
That was my best guess as to what it was as well. So far 75 miles or so no codes and no noticeable changes in how the car drives, sounds, and its too early to see and MPG change.
Old 11-09-2012, 07:08 AM   #1465
mrbloink
Member#: 333058
I just installed the perrin crank pulley last night. It definitely makes the throttle feel a little more responsive. I really like the feel of it. Such a pain to install tho! The bolt was on super tight and I needed to put pipe over both of the 24 inch breaker bars for more leverage! The grimmspeed tool does work, not perfectly, but it works. I could only get two bolts through the stock pulley which made keeping it against the pulley whilst breaking the threads on the bolt a nightmare! You also need to remove the two rad fans in order to remove the bolt from the crank but that's no biggie. The perrin pulley teeters between 1.2 - 1.25 lbs on the scale! It is light. I won't be able to get a weight on the stock pulley till tomorrow when I get back to work, however I can tell you it weighs a ton! Best part, no CEL
Old 11-09-2012, 10:08 AM   #1466
Sticman
Member#: 317244
12 Impreza
I have been waiting for someone to review this. Thank you for trying, it sounds great so far. Do you have any pictures of the install yet?
Sticman is offline   Reply With Quote
Old 11-09-2012, 10:58 AM   #1467
mrbloink
Member#: 333058
No but I'll take some this evening. I got it in black so it doesn't look too different. I don't want the car to look much dif than stock
Old 11-09-2012, 11:07 AM   #1468
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
LOL, Im sure the stock torque on the crank bolt is somewhere around 200-300 lbs. Old trick is if you dont have the man power. remove the spark plug wires and Turn her over 1 or 2 times with the rachet attached and anchored the nut should be loose after that. Good to hear you got it on. Hope you tried to torque the hell out of it.
Old 11-09-2012, 12:16 PM   #1469
mrbloink
Member#: 333058
I thought about that but was too scared to crush a brake line. I did it to 33 lbs and then again to 98 to make sure that the bolt turned more than 45 degrees. I gave it another quick go after that but heard the threads start to crack so I left it at that. I'll check again after a hundred miles or so
Old 11-09-2012, 12:20 PM   #1470
mrbloink
Member#: 333058
The o-ring seemed a little too big but I managed to make it fit. Is it worth replacing it?
Old 11-09-2012, 10:14 PM   #1471
daricklo
Member#: 327977
Question
If there are no oil leaks, then you will be fine. Don't need to replace the o ring. How did you hold the crank pulley in place when you were loosening crank bolt?
daricklo is offline   Reply With Quote
Old 11-09-2012, 10:51 PM   #1472
mrbloink
Member#: 333058
I used the grimmspeed crank pulley removal tool. You can get either two of the large bolts through the pulley or three of the small ones
Old 11-10-2012, 05:47 PM   #1474
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
MjSub2.0 is offline   Reply With Quote
Old 11-10-2012, 07:25 PM   #1475
pkL
Member#: 313093
2012 Impreza 2.0i
Overall how hard would you say the install was and how long did it take you? I seriously doubt my own abilities in installing this myself.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
