Old 11-06-2012, 02:12 PM   #1
rushdylan
Member#: 337170
2003 wrx
Default help wiring my glow shift cluster?
i just picked up this glow shift cluster from a buddy and tossed it into my car, he tore it out before i could say wait and now we have no clue where anything went or goes. i have everything powered from the clock power/switch so they work and the boost gauge works but now i need to tackle the oil pressure and oil temperature. he claimed all 3 gauges worked perfectly when he pulled them out but i cant see any differences in the oil sensor below the alternator and there is no sandwich plate? oil temperature is sitting at 0 and oil pressure is sitting at 100, although there is NOTHING hooked up but power and ground. any help is appreciated! one thing i do know is the wires were routed right behind the radiator fan on passenger side. but none were hooked up to anything
rushdylan is offline   Reply With Quote
Old 11-06-2012, 02:18 PM   #2
rushdylan
Member#: 337170
2003 wrx
i guess if i had some direction to where the sensors on his car might have been, i can pull them out and wire mine up and have a great working gauge
Old 11-07-2012, 08:52 AM   #3
jthatch12
Member#: 321715
03 WRX
Sounds like you don't have the sensors hooked up properly. The one gauge that reads 100 is probably only hooked up to power and not to the sensor
Old 11-07-2012, 02:24 PM   #4
rushdylan
Member#: 337170
2003 wrx
that's correct, but where is the correct sensor which I should be tapping into? I'm looking for oil pressure and oil temp sensors. i would then just split off of those wires from the sensor correct?
Old 11-07-2012, 02:30 PM   #5
jthatch12
Member#: 321715
03 WRX
The oil temp sensor(depending on the brand) may actaully replace the drain plug. I'm not sure about the pressure sensor
Old 11-08-2012, 12:40 PM   #6
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
You can't use the factory sensors, there are none. You need the sensors/sending units for those specific gauges.
tachrev is offline   Reply With Quote
Old 11-08-2012, 09:12 PM   #7
rushdylan
Member#: 337170
2003 wrx
that would mean replace with a new capable sensor in its place? I don't have to drill/tap any holes right?
Old 11-09-2012, 07:41 AM   #8
quazimoto
Member#: 70395
Have you even tried using Google or looking on Prosports site? There is an oil galley plug on top of the block,under the TMIC that everyone and their mother uses to install in an oil pressure/temp sender.
http://prosportgauges.com/remote-oil...ation-kit.aspx http://forums.nasioc.com/forums/show...ight=gauge+faq And why the hell did you post this in Engine Management and Tuning?
Old 11-09-2012, 11:39 AM   #9
rushdylan
Member#: 337170
2003 wrx
i just figured gauges would be for engine managment. ive had my wrx for a week, sorry officer.
Old 11-09-2012, 11:44 AM   #10
dangerousatom
Visiting NASIOC Timeout
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Ah....to be young and own a WRX
dangerousatom is offline   Reply With Quote
Old 11-09-2012, 12:35 PM   #11
rushdylan
Member#: 337170
2003 wrx
Old 11-09-2012, 12:40 PM   #12
quazimoto
Member#: 70395
Oil pressure and temp have nothing to do with Engine Management. There is a reason NASIOC has a "Newbie" section...........
Old 11-09-2012, 07:04 PM   #13
rushdylan
Member#: 337170
2003 wrx
try not to be so polite there pal. killing me with kindness!
Old 11-09-2012, 07:31 PM   #14
Luc r
Member#: 332784
2006 wrx
sgm
man, someone hasnt gotten laid in a long time. love reading posts by mr. know it all's.
hope you get it figured out OP
Luc r is online now   Reply With Quote
Old 11-10-2012, 08:58 AM   #15
quazimoto
Member#: 70395
Good thing you at least contributed........oh wait,you didn't.
Old 11-10-2012, 12:51 PM   #16
rushdylan
Member#: 337170
2003 wrx
you talk too much
Old 11-10-2012, 12:52 PM   #17
rushdylan
Member#: 337170
2003 wrx
i think i got it under control by now, thanks!
Message Board Statistics All times are GMT -4. The time now is 05:41 PM.
