Old 11-09-2012, 06:27 PM   #1
SimpleWrx
Member#: 315068
2005 wrx
Default How to figure out.......
So i've searched google and called a few people but no answers. here's is the info.. Got a new short block put in and they started the car it ran then died, they say no spark. I tried to connect my tactrix cable to the car but it wont connect to either ecu flash or rr logger. I'm in a head stump. either its the cable or ecu and i dont have any other way to test it.... any ideas?
SimpleWrx is offline   Reply With Quote
Old 11-09-2012, 07:32 PM   #2
Viral E
Member#: 242246
2002 Impreza WRX
Short? Blown Fuse? Loose connection on the ECU or main harnass? Check and recheck all your connections. I would defer to an expert on the matter, but those are quick simple things you can do without tearing apart a perfectly good (and new) engine.
Viral E is offline   Reply With Quote
Old 11-09-2012, 07:46 PM   #3
SimpleWrx
Member#: 315068
2005 wrx
Well its all being done by a shop since i do not have tools or a place to do it where i live now. just trying to figure out if my ecu has the problem
Old 11-09-2012, 10:46 PM   #4
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Is check engine light lighting up. I recently ran into incorrect bolt installed on intake manifold that is ground for ECU on 05-06ish WRX. Car ran fine when it was traded in, but then died on salesman. Wouldnt start after that, until I found problem.
Just to be clear, the ECU and other electronics grounds on the intake manifold. They may have installed wrong bolt or not hooked it up correctly.
bswilmington is offline   Reply With Quote
Old 11-09-2012, 11:42 PM   #5
SimpleWrx
Member#: 315068
2005 wrx
Alright thank you. hopefully they fuigure it out while im out working next week. im getting a spare ecu and cable sent to me to make sure 100%
