Old 06-25-2012, 11:45 PM   #101
filly10
Member#: 294279
Originally Posted by MjSub2.0 View Post
are you talking about the thing on the lower corner of the wind shield outside or that triangular piece in front of the side mirrors? Because that rattles to.
The piece on the lower corner of the windshield that runs up along the A-Pillar against the windshield.
filly10 is offline   Reply With Quote
Old 06-25-2012, 11:48 PM   #102
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Cool I'm gonna have to check that. Thanks
MjSub2.0 is offline   Reply With Quote
Old 06-26-2012, 08:00 AM   #103
WLS
Member#: 316030
Originally Posted by jr0bb5 View Post
Honestly it really doesn't bother me that much, but I have a couple other small issues that need to be addressed so I going to have the dealer take care of it.
Yeah I see that the whole housing is just a plastic shell that kind of floats. I can move it by hand so it doesn't really have a perfect stable position.
I'm having more of an issue with the key not fitting in easily on the first try.
WLS is offline   Reply With Quote
Old 06-26-2012, 12:09 PM   #104
nubsub
Member#: 313575
2012 Impreza 2.0i HB
filly, thank you for contributing to this thread. can i ask for some clarification:
1. was it hard to remove the pillar cover? did you just use STEye's instruction sheet? did you need to remove it? it sounds like you put the foam tape on the speaker cover, and if so, why is the A-pillar cover removal necessary? (sorry: i'm a very visual person and am puzzled).
as i noted in other posts, my solution (which seems to be working, is the keep the pillar cover from rubbing against the window. i think now in hindsight, the cardstock solution is better than the felt circle for appearance purposes. so after another week, i will try to find some white cardstock to replace both the felt circle and yellow parking permit cardstock i am currently using.
2. are you talking about this plastic piece that runs under the base windshield and comes up to just the base of the A-pillar. (ie, it's primarily under the windshield and only slightly comes up the sides of the windshield) the piece i am thinking about also has a circular rivet near the end towards the start of the A-pillar where there is some play...i agree: there is some "give" there and i can get it rattle a fair bit with my hand, especially the passenger side. if i am understanding you correctly, it is worth going out to buy some black foam tape this weekend to try your fix. (i only have some white stuff on hand) i am assuming you just squeeze a thin strip down there and it will hopefully last a while and maybe need to be replaced every few years (assuming that it will probably break down in time.)
as i type all of this, i realize that if people are willing (i need to reactivate my flicker account or something else since as far as i can tell, this site doesn't natively host photos attached to these posts), we perhaps could include some pictures of these items to clarify things. not sure you have the time or are willing to make the effort, filly, but if you are, i am sure others would greatly appreciate it.
thanks again!
Originally Posted by filly10 View Post
Well dealer wasn't able to replicate the rattles so i went after it myself when i got home and fixed both. Been a week now, rattle free!
1. A Pillar Rattle - removed the a pillar cover and ran a piece of foam tape down the side of the speaker cover where it meets the panel. Seems to keep everything just snug enough to keep it from rattling and once i put the A-pillar cover back on you cant see it at all.
2. Center Dash Rattle - Turns out this one wasn't in the center of the dash, it wasn't even inside the car. There is a piece of plastic trim that runs along the exterior of the A-pillar where the A-pillar meets the windshield (near the bottom, about 6 inches long). The plastic is barely fixed to the A-Pillar and rattles in the wind against the A-pillar. Again a piece of foam tape wedged in between the plastic and the A-pillar and I'm now rattle free.
nubsub is online now   Reply With Quote
Old 06-27-2012, 10:02 AM   #105
filly10
Member#: 294279
thanks again!
1. To remove the cover from the A-pillar i just pulled on the top of it and it snapped out of place, then i pryed the 2 tabs at the bottom out of place with a screwdriver. When i was done i just wedged the tabs back in place under the speaker and snapped the neon clip back in up top. I would reccomend following STEyes instructions though, they seem a little more comprehensive. I guess in hindsight i didnt NEED to remove the A-pillar cover to get the tape in between the speaker and the A-pillar but having it removed just gave more room to work and i was able to get the tape in nice and low beneath the top of the dash so you cant see it.
2. And yes that is the piece i am talking about (the one with the small plastic rivet near the top). For this i just got my knife blade under it and pryed up on it to wedge the tape under.
I'd definitely be willing to put some pics up if you had a spot for them.
Old 06-27-2012, 12:20 PM   #106
nubsub
Member#: 313575
filly, thanks!
i'm sorry if i wasn't clear: but unfortunately, i don't have a spot to host pictures for this forum. i was referring to the fact that i need to come up with a way to store and broadcast my own photos as i don't have that ability myself at this point. (i know how to do it: either flickr or some picasaweb account, i think would work for free.)
anyway, back on track:
1. i think i understand what you did and i guess i can do the equivalent by removing the speaker cover instead. yet, i think we may have different rattles here. i tried putting things "underneath" the A-pillar trim previously and that still didn't solve all of my rattle problems as mine come from the trim rattling against the glass of the windshield. so unless i don't understand your solution (which to me reads: put tons of foam "under" the A Pillar trim), i still would get rattles in my car.
my solution, which has worked is to put something between the A-pillar and the windshield itself. on my driver's side, i'm stuffed a felt circle (3/16" thickness) between the two and that has stopped those rattles. on the passenger side, i folded over an old cardstock parking permit several times to the right thickness and stuff thated between the two. both have worked. both are a bit unsightly (the parking permit was yellow!), but seem to have worked after being in place for about a week. i think my prefered solution will be to put a piece of offwhite cardstock in there to match the trim. it's obvious if you are looking, but it blends in better than either of my two solutions.
2. thanks for the clarification. i like that idea. i just need to go buy some black foam tape. what thickness tape are you using? is the high density variety so it gives a little less? of course, i was also thinking i might be cheap and see if i can use a sharpie pen to darken some of my already on hand white foam tape (3/16" thick, i think) and see if that goes in ok and isn't obvious to the casual eye.
thanks again! your posts have been very helpful!
Old 06-29-2012, 08:53 PM   #107
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
I pulled the instructions from the factory service manual. The bible.
ST Eye is offline   Reply With Quote
Old 06-29-2012, 10:46 PM   #108
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
I've done all these and it's still there. I think the rattle is inside the dash under the tweeters.
Old 07-16-2012, 12:40 PM   #109
nubsub
Member#: 313575
Rattle updates 3+ months of ownership behind me...
thought i'd check in and hopefully keep this thread alive and hope solutions/fixes continue.
for me...
- A pillar rattle: seems that it has been solved 99% of the time: i never changed my previous fix: 3/16" felt circle stuffed between the windshield and A-pillar on the driver's side and a folded up parking permit (cardstock) on the other side. i was going to replace both with some white cardstock to better match, but the yellow permit has faded and i'm just too lazy and it has worked pretty well. i also added a piece of black foam tape on the outside 1/4" thick at the location suggested by filly. i sometimes hear a sound (rare) in the driver's side A-pillar near the windshield, but it's my guess that it's something else in the dash expanding/contracting. i can live with this since it seems so rare that it occurs.
- center console rattle: again, like all of my rattles: temperature related. this one is annoying when it's there. it seems it is somewhere in the dash computer casing that is expanding and contracting.
- steering column panel rattle. as i said before, it's not really the steering column, but something deep in the dash. the good news, which i reported previously, is that it has gone from a "cold temp" phenomenon to a "mid temp" phenomenon. that means i don't hear it during my daily commute to the train station, but more typically as the evening hours cool. it's still annoying, but either i'm getting more used to it or it has gotten quieter, it's less annoying than before. still there but less obvious.
- rattle that i thought was from the head rest: i'm pretty convinced that this rattle is coming from the outside trim (where the cross bar mount covers are). there is play in this trim when the car is cool and it goes away when sitting in the sun. my "loose portion is midway between the two doors on the passenger side. i may have the dealer look at it if and when i go in for something else. i'm not sure there is any easy fix for this one. this one goes away after the car warms up and i'm getting better at ignoring it during my morning commute.
will the remaining ones get worse or better as the months go on? time will tell...
Old 07-16-2012, 10:45 PM   #110
ST Eye
Member#: 73068
I have an annoying 'tick tick' noise that comes from the upper seatbelt are of the front driver-side are. It's right in your damn ear! I have already taken the plastics off trying to figure it out and I can't seem to find it. GRRR!
Old 07-17-2012, 12:03 PM   #111
nubsub
Member#: 313575
sorry to hear STEye. i commiserate. my "near steering column" one isn't even ear level, but it's close enough to be me drive me nuts.
have you been able to isolate it by putting pressure and pinching something in that vicinity when it happens? (be safe doing so! i worry about my own rattle distracted fixing while driving!)
Old 07-17-2012, 08:08 PM   #112
ST Eye
Member#: 73068
If I open the door to the latch (not open but not closed all the way) the noise goes away. I think the noise may be in the door area. The next step is to take off the door card. It almost sounds like morse code as I drive!
Old 11-07-2012, 07:51 AM   #113
IveBeenRued
Member#: 305466
2012 Sport Limited
Mine has been creaking now that the temps have gotten into the low 40's I to believe it is coming from the computer casing. Any resolution on your rattle?
IveBeenRued is offline   Reply With Quote
Old 11-07-2012, 08:58 AM   #114
79letour
Member#: 302570
2013 XV
DGM!
I have a similar noise in my left ear while driving. I tried tracking it down, and its coming from the upper corner of the rear door panel. If I press it with my hand firmly it goes away.
At 15k, this thing is turning into a real rattle-trap.
79letour is offline   Reply With Quote
Old 11-07-2012, 06:48 PM   #115
Andrews360
Member#: 337204
2012 Impreza
dark grey
Default Subaru Service Bulletin for Front Seatback squeak
Just released Subaru Service Bulletin- has seat back fix procedure and part number for replacement bushes. If link doesn't work send me a msg and Ill email the bulletin to you . I have made this link public so you can all view it.
Cheers
https://docs.google.com/open?id=1rJ-...EogzrJQf5TCTUQ
Andrews360 is offline   Reply With Quote
Old 11-07-2012, 06:50 PM   #116
Brian Vantana
Member#: 314834
2012 Impreza
Dark Metallic Grey
I have EXACTLY the same rattle on the opposite side. When the girlfriend is driving and I am sitting in the passenger seat it drives me mad.
Brian Vantana is offline   Reply With Quote
Old 11-07-2012, 08:21 PM   #117
Paradis
Member#: 334647
2012 POS Impreza
2. rattle from steering column area near the the knee airbag. i've reported on this elsewhere. i can make the rattle stop by pinching together the adjacent panel and this airbag panel so i know roughly where it is located, but i can't figure out exactly where something is rubbing within the panel. this is very intermittent. it used to only happen when the car was cool (again, defined by not being in the sun, and the ambient temp is below 70 oF), but now, the past couple of mornings, it has been nonexistent under those conditions, yet i heard it faintly after driving a while (it warmed up some) and then not there at all when the car is warm. i'm hoping and praying wishfully that this one may solve itself. this is my most annoying rattle, i think, because it is so near to me when i'm driving and has a really high paced (tap tap tap) very fast) type of sound and can almost sound a bit creaky in tone.
I have exactly the same rattle! Does anyone have a solution?
Paradis is offline   Reply With Quote
Old 11-07-2012, 08:52 PM   #118
nubsub
Member#: 313575
unfortunately, no. not yet. i still want to bring it into the dealer but haven't made the time to do so. my problem still is that it comes and goes with temperature, so it's not necessarily replicable when one wants it to be.
Old 11-07-2012, 10:46 PM   #119
ST Eye
Member#: 73068
What I ended up doing is tweaking the door slightly and the noise went away.
Old 11-08-2012, 02:23 AM   #120
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I have a rattle too, it seems to be coming from the driver side speaker grille area, it's an annoying rattle/buzz. Would that be the knee airbag rattle you guys are experiencing?
Old 11-09-2012, 09:42 AM   #121
n00b on demand
Member#: 158355
2012 Sport 5MT
Whats the best way to remove the tweeter cover on the drivers side? I want to remove it and install foam tape but I am afraid I will break it.
The dealership had my car yesterday and added some foam to the A-Pillar/ tweeter area but there is still a slight rattle coming from there that is now present over any kind of bump in the road. I guess i could bring it back to the dealer sometime next week but then I will be taking yet another day off. So frustrating that this takes away from driving a nice car.
n00b on demand is offline   Reply With Quote
Old 11-09-2012, 11:29 AM   #122
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Any thin metal like a butter knife will do. I've taken mine OFF several times...make sure you pry it up from the section closer to you NOT the windshield side. You'll see why when you get it off...Don't worry it won't break. While your at it you should upgrade your tweeters it's worth it, sounds cleaner compared to stock.
Old 11-09-2012, 11:49 AM   #123
n00b on demand
Member#: 158355
2012 Sport 5MT
thanks!
Old 11-09-2012, 06:26 PM   #124
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
thanks!
Anytime!
Old 11-09-2012, 07:46 PM   #125
Brian Vantana
Member#: 314834
2012 Impreza
Dark Metallic Grey
How did you "tweak" it?
2012 Impreza thread A_Pointy_Rock Impreza Forum 26749 04-27-2016 06:18 PM
('11-'14) 2012 Impreza Owners - MPG Thread! Rdizzle Impreza Forum 5613 04-23-2016 09:27 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
2012 Impreza cabin rattles Bsmitty5913 General Community 14 05-05-2012 09:52 PM
FS : Thule Baserack/locks/bike carriers. 08+ Imprezas (and others!) Redneck Ricer NESIC Private Classifieds 4 08-07-2011 11:07 PM
