11-07-2012, 12:09 PM | #51 |
Member#: 337076
Vehicle:2013 XV Crosstrek |
If anyone has a spare CM621UB they're willing to part with for cheap or free, I'd love to have one to do some bench testing, and to try making a line-out mod.
JohnNevets: Nice work on the combo moves! The service manual does list "3+6+SOUND" for through mode, but it doesn't show 3+4 and 3+5 for sedan/wagon modes. 3+6 worked once for me, but I never saw it again because I didn't know about the other two. It all makes sense now. flyboy1100: All of the audio specs in the service manual have a note that says "auto loud off" and "eq through mode", so I'm pretty sure through mode means flat EQ. As for loudness, I can see why you might want to leave it on. It used to just add insult to injury, but with the EQ disabled, it's much more reasonable. I can change it on the fly with one hand now, but I think I'll mostly be leaving it off; I find the tonal balance often isn't great across volume levels and recordings, so I end up fussing with the tone controls. With loudness off, I can just keep the volume within a range where the tonal balance sounds right for a given recording and leave it at that. One the way to work this morning, I caught myself just enjoying the music and not thinking about the system. I didn't think this was going to be possible with the stock setup.
11-07-2012, 12:27 PM | #52 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
11-07-2012, 02:47 PM | #53 | |
Member#: 337076
I can use either one, though I'm hoping for a CM621UB so it will be an exact match. It supports the new(?) dimming disable position on the dashboard dimmer knob. I'll PM you to see what we can do. Thanks! |
11-07-2012, 03:29 PM | #54 |
Member#: 332561
Vehicle:2015 GTI Autobahn White |
So I did this this morning, am I the only one who thinks through mode is worse than wagon mode?
On through mode it also gets very low volume, I have it up at like 30 just to hear it. I have an audiocontrol LC2i and a jlxd400/4 running my fronts and a sub. Maybe I need to retune the amp and audiocontrol |
11-07-2012, 05:04 PM | #55 | |
Member#: 314216
11-07-2012, 05:21 PM | #56 |
Member#: 237993
Vehicle:75 MGB |
CZ624U1
Loundness works but none of the EQ options. |
11-07-2012, 05:30 PM | #57 |
Member#: 337076
11-07-2012, 06:13 PM | #58 | |
Member#: 332561
I guess I have more tuning to do |
11-08-2012, 09:31 PM | #59 | |
Member#: 100800
FM is awful but bluetooth audio streamed from my android sounds awesome. (CZ624U1 in a 2013 Premium Hatch) |
11-08-2012, 10:36 PM | #60 |
Member#: 8
HIIC
Vehicle:2016 WRX STi Ice Silver Metallic |
11-09-2012, 05:12 PM | #61 |
Member#: 308149
Vehicle:2012 WRX 5-door WR Blue Pearl |
This worked on my base 2012 WRX too. Can't honestly say if it made a huge difference or not. I prefer Loud On and Through Mode on the EQ. So does Through Mode disable the EQ and then Wagon and Sedan are the two EQ's you can choose from?
11-09-2012, 05:39 PM | #62 |
Member#: 72195
Vehicle:2016 Golf R DSG Oryx White Pearl |
So trying this tonight!
11-09-2012, 10:20 PM | #63 |
Member#: 330435
Does this lessen how bad the tuner sounds? My BT and CD sound great. The radio on the other hand sounds terrible.
11-10-2012, 11:33 AM | #64 | |
Member#: 337076
If I'm reading it correctly, the service manual says it uses -6 dB at 70 Hz, and -17 dB at 7 KHz. FM music stations generally have heavy EQ, but this goes far beyond flattening them out a bit. It must be optimized for talk radio, though even that sounds rather dry to me. I hate listening to music on FM anyway, so it's not a big deal for me. Still, when I get one of these on the bench, I will see if there's a way to bypass it in hardware. There are two ICs capable of EQ, one of which could be bypassed, but I don't know yet which gets used for what. This would probably be more than most people would want to take on, though. |
11-10-2012, 12:46 PM | #65 |
Member#: 72195
I can't tell much difference between the sedan, hatch and through mode. Loudness off helped music sound less muffled and over basy
11-10-2012, 12:50 PM | #66 |
Member#: 43310
SCIC
Vehicle:1978 Brat Silver |
any idea if there is a service/diagnostic/secret menu in the '13 navigation unit? I was following this thread and wondered if I might be able to tinker and improve my own head unit sound.
11-11-2012, 05:18 PM | #67 |
Member#: 163058
Vehicle:'20 WRX '16 BRZ Limited |
In my 2011 WRX, I'm actually able to get to sedan/wagon/through mode by pressing 1+2, 1+3, 1+4 or 3+4, 3+5, 3+6 then pressing Tune. I can't tell much of a difference between the three. I think sedan mode is more distorted in terms of bass frequencies but I'm not sure. Either way, it sounds syrupy and crappy lol
11-11-2012, 06:30 PM | #68 |
Member#: 241163
Vehicle:2012 WRX Lightening Red |
11-11-2012, 08:05 PM | #69 |
Member#: 314216
you have to turn the radio off then press the combination of buttons to change the eq settings
11-11-2012, 08:15 PM | #70 | |
Member#: 241163
11-11-2012, 08:32 PM | #71 |
Member#: 314216
11-11-2012, 08:34 PM | #72 |
Member#: 163058
Be sure to hold down the number buttons (e.g. 1+3) before hitting (just press it, no need to hold) the Tune knob.
11-12-2012, 01:35 AM | #73 | |
Member#: 237993
Vehicle:75 MGB |
11-13-2012, 11:46 PM | #74 | |
Member#: 74211
Vehicle:2011 SSM WRX 4DR |
11-14-2012, 12:53 PM | #75 |
Member#: 275888
Vehicle:2011 WRX Limited SWP |
Works miracles if you already have dynamatted/sound reinforcement. Thanks! Works on my 2011 radio as well.
Similar Threads | ||||
2011+ Impreza head unit into 2009? | codingparadox | Car Audio, Video & Security | 6 | 12-31-2011 12:48 AM |
2011 Stock Head Unit Audio Playlist Options | cheezmunky | Car Audio, Video & Security | 2 | 12-02-2011 10:09 AM |
WTB : WTB - non-navi 2011+ OEM Head Unit with Bluetooth. | ofspunk7 | Private 'Wanted' Classifieds | 2 | 10-25-2011 12:40 PM |
2011 STi head unit w/o nav RCA PORTS? | sk8dc10 | Car Audio, Video & Security | 5 | 11-06-2010 10:01 PM |
2011 stock head unit wiring question | subiebosch | Car Audio, Video & Security | 10 | 10-08-2010 09:21 AM |
