#1 |
Member#: 315068
Vehicle:2005 wrx PSM |
So i've searched google and called a few people but no answers. here's is the info.. Got a new short block put in and they started the car it ran then died, they say no spark. I tried to connect my tactrix cable to the car but it wont connect to either ecu flash or rr logger. I'm in a head stump. either its the cable or ecu and i dont have any other way to test it.... any ideas?
#2 |
Member#: 242246
RMIC
Vehicle:2002 Impreza WRX WRB |
Short? Blown Fuse? Loose connection on the ECU or main harnass? Check and recheck all your connections. I would defer to an expert on the matter, but those are quick simple things you can do without tearing apart a perfectly good (and new) engine.
#3 | |
Member#: 315068
Well its all being done by a shop since i do not have tools or a place to do it where i live now. just trying to figure out if my ecu has the problem |
#4 |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
Is check engine light lighting up. I recently ran into incorrect bolt installed on intake manifold that is ground for ECU on 05-06ish WRX. Car ran fine when it was traded in, but then died on salesman. Wouldnt start after that, until I found problem.
Just to be clear, the ECU and other electronics grounds on the intake manifold. They may have installed wrong bolt or not hooked it up correctly. |
#5 |
Member#: 315068
Alright thank you. hopefully they fuigure it out while im out working next week. im getting a spare ecu and cable sent to me to make sure 100%
