Mid Atlantic Impreza Club
Old 11-09-2012, 10:57 PM   #1
tjmazz13
Member#: 291681
2004 Pearl White STi
IAG Stage 4, S363SXE
Default Removing 3M film
I just bought an STi and it had the 3M protective headlight film on it. When I removed it, it left a lot of adhesive. What can I use to safely remove the adhesive without damaging my headlights?
TJ
tjmazz13 is offline   Reply With Quote
Old 11-09-2012, 11:28 PM   #2
enjoi1968
Member#: 234416
It's A BRAAAAAHtato,
Yo.
Goof Off and a fair amount of elbow grease
enjoi1968 is offline   Reply With Quote
Old 11-10-2012, 01:36 AM   #3
Matt_H
Member#: 107000
2015 BMW X1
Do not use this on your head lights.
Matt_H is offline   Reply With Quote
Old 11-10-2012, 03:29 AM   #4
aznboi0204
Member#: 266514
2011 OBP STi Sedan
bug and tar remover and elbow grease
aznboi0204 is offline   Reply With Quote
Old 11-10-2012, 03:58 AM   #5
jewbaru42
Member#: 265098
2003 wrx
silver w/ blk enkei rims
alcohol wipes, dry paper towels/microfiber towel and windex. DONE! that's what I used when I removed my old tint and there was still some adhesive left behind. works like a charm and didn't take a lot of elbow grease. But it also depends on how thick the **** is so elbow grease is depending. good luck
jewbaru42 is offline   Reply With Quote
Old 11-10-2012, 04:05 AM   #6
Scoobie_88
Member#: 337465
2002 WRX GDA
Sedona Red Pearl
rubbing alcohol will help
Scoobie_88 is online now   Reply With Quote
Old 11-10-2012, 07:20 AM   #7
spagez
Member#: 252748
2013 wrx
acetone or nail polish remover.
spagez is offline   Reply With Quote
Old 11-10-2012, 10:31 AM   #8
enjoi1968
Member#: 234416
Yo.
You clearly know something.... Care to share, as I've cleaned 3 sets..
Old 11-10-2012, 10:46 AM   #9
jeffie7
Member#: 321791
05 STi
WD40 is something almost everyone has, its a better cleaner than it is a lube lol.
FWIW I removed the rear badges/gunk left behind with it, I also remove stickers and such from motorcycles using it.
jeffie7 is offline   Reply With Quote
Old 11-10-2012, 05:34 PM   #10
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Pressure washer
lilblue619 is offline   Reply With Quote
Old 11-12-2012, 05:01 PM   #11
2.5_IMP
Member#: 163604
3M citrus based adhesive remover and a microfiber cloth. Some auto parts stores have it, craft stores should carry it too.
2.5_IMP is offline   Reply With Quote
Old 11-12-2012, 07:30 PM   #12
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Goof Off contains acetone and xylene, which melt many thermoplastic polymers. Obviously ABS/polycarbonate is a thermoplastic, so if you had success with it, then fine, but I wouldn't use it.
There are also several types of Goof Off that have varying contents of spirits/etc. I even think there's one with no spirits but with citrus oils, similar to Goo Gone which also does not have "harsh" mineral spirits.
A lot of people on here confuse Goof Off with Goo Gone, with disastrous results. There was an image in the $10 taillight mod thread of one taillight that was eaten through with Goof Off. Taillights are usually made with much lower impact protection requirement, and thus much more compliant and low temperature thermoplastics, which are more susceptible to chemical attack.
P.Rico is offline   Reply With Quote
Old 11-13-2012, 02:28 PM   #13
BarmanBean
Member#: 297778
2005 OBXT 6mt
Also try stoner's invisible glass cleaner. The stuff is awesome for cleaning glass, but i've also found it works really well at getting adhesive residue off--worth a shot.
BarmanBean is offline   Reply With Quote
Old 11-13-2012, 04:07 PM   #14
kts262
Member#: 45464
91 E30 325i
95 E36 325is
^^ this stuff has worked great removing a number of different bits of adhesives on a number of cars and other projects around the house I have had. I picked up a large can of it a while back and it has been worth every penny.
kts262 is offline   Reply With Quote
Old 11-13-2012, 04:25 PM   #15
lando
Member#: 149637
2010 STI SE
WD40 is a water dispersing agent, it is not a lube. It actually gums up and dries out after a period of time. I wouldn't use it on anything.
lando is offline   Reply With Quote
