Old 11-09-2012, 04:05 PM   #51
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
xdrian really excited to see some final plots after jr further works his magic and also some track footage!!
I was recently at the domestics and imports race at MIR. I was REALLY disappointed in not seeing even one subie out there. Next year you should make it down!
Old 11-09-2012, 04:25 PM   #52
kpadill2
Member#: 266208
Nice, any pictures of the front mount setup? 67mm is so tempting!
kpadill2 is offline   Reply With Quote
Old 11-09-2012, 06:13 PM   #53
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Originally Posted by spoolinsti05 View Post
What's wrong with the AVCS on the V1? the control is unstable or just limited?
+1 ??
Originally Posted by AkumaMotorsports View Post
I knew you would not use the AVCS on the AEM V1, so I assume it works well for your application.
Can you please go into this issue you are talking about further?
Originally Posted by xdrian View Post
And the V1 is mint with this car, starts right up and runs the car well. We arent using avcs in the car at all, I would have to run a jdm harness or run wires for the avcs but its not necessary with my build.
Could you or jr. please chime in on this issue akuma is talking about with the AEM v1 ecu's AVCS tuning issue ? 1st is the 04 sti ecu, then 05-06 sti ecu, last is ron's drag wrx with most likely no avcs
Reason I'm asking is I just picked up 3 of these unit's (used for $500 each) for our 3 high hp cars, & 2 of 3 of them are planning to continue using avcs.
Old 11-09-2012, 06:23 PM   #54
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
AVCS with the AEM v1 is erratic and must be calibrated and monitored religiously. Don't try and get greedy with AVCS on high lift cams with the v1 or you will end up with bent valves.
Crystal_Imprezav is offline   Reply With Quote
Old 11-10-2012, 11:30 AM   #55
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Is there anything that can be done to avoid the tuning issue. I've tried to research, only thing I could find is to not put the box on the metal floor in the stock location, and something about the unit not picking up cam/crank signals correctly with larger cams
I bought the unit from b.r.e.d. , & I'm having my motor built with mike keegan, who's also claying the heads so I can know exact piston to valve clearance to safely tell me how much avcs to run, so if there's no way to use the aem v1 ecu with a good amount of avcs, I guess Ill have to ditch it for the old AP or tactrix again
this thread mentions with larger cams has problems: http://www.igotasti.com/vBforum/show...ce-review-quot
one thread not too much info was given : http://forum.aempower.com/forum/index.php?topic=26722.0
Old 11-10-2012, 06:18 PM   #56
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
Originally Posted by Irv Weissmanhowerton View Post
Is there anything that can be done to avoid the tuning issue. I've tried to research, only thing I could find is to not put the box on the metal floor in the stock location, and something about the unit not picking up cam/crank signals correctly.
Speak to the Syvecs.us
http://syvecs.us/syvecs-wp/?page_id=22
I'm running S6 PnP
Jura
jura11 is offline   Reply With Quote
Old 11-10-2012, 09:27 PM   #57
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I will inbox you my number
We switched to e85 today and lost a fuel pump in the process. Looks like Monday we are shooting for 800whp
Old 11-11-2012, 01:19 AM   #58
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Sikkk!!!
Old 11-11-2012, 07:23 AM   #59
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Shame about the pump guys. hopefully all goes well Monday!
I had the AEM and at 5500-6000rpm it would misfire bigtime. i ended up filing the cam sensors and grounding each coilpack to the battery.
This solved some issues, but then my mate blew his motor a few weeks later with the same ecu and so i switched to vipec
Old 11-12-2012, 04:31 PM   #60
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
[email protected] psi on e85, trying to go to 35
Old 11-12-2012, 05:00 PM   #61
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
[email protected]
Old 11-12-2012, 05:01 PM   #62
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Oh and 800whp at 8500rpm
Old 11-12-2012, 05:05 PM   #63
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Damn!!! Hope my s400 gets me in the 7's. that's sick *^
Old 11-12-2012, 05:50 PM   #64
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Originally Posted by Junior2JZ View Post
[email protected]
WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 8 second power?
Let's see some graphs Jr.!
Old 11-12-2012, 06:09 PM   #65
TheColorCute
Member#: 265589
2004 Slow 6466 STi
[email protected]
Super encouraging for my 800whp build!
Awesome work, guys!!
For those of you who are friends with Adrian and/or Jr on Facebook, there's a graph there!
TheColorCute is offline   Reply With Quote
Old 11-12-2012, 06:49 PM   #66
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
OH WOW! Congrats bro! great job JR
Old 11-12-2012, 06:59 PM   #67
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Wow. That is crazy power!
C J is offline   Reply With Quote
Old 11-12-2012, 07:09 PM   #68
Member#: 278519
30r E85 sti 450+whp
kb'izzle
copy and post it
Old 11-12-2012, 07:23 PM   #69
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
updated first post
xdrian is offline   Reply With Quote
Old 11-12-2012, 07:30 PM   #70
Badler
Member#: 133597
Oh damn!
Old 11-12-2012, 08:23 PM   #71
JTPerryR1
Member#: 163361
05 STI 9.84 @ 150
15 silver STI
Haha. That is awesome. Nice job guys !!
JTPerryR1 is offline   Reply With Quote
Old 11-12-2012, 09:33 PM   #72
CatfaceType-R
Member#: 81102
It's on like donkey kong!
Good job guys!
Old 11-12-2012, 09:46 PM   #73
bjohnson_55
Member#: 216580
nice job junior as always
Now lets see if someone can get it down the track!
bjohnson_55 is offline   Reply With Quote
Old 11-12-2012, 09:53 PM   #74
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Trap Speeds please?
02WRX2.5 is offline   Reply With Quote
Old 11-12-2012, 10:01 PM   #75
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Originally Posted by 02WRX2.5 View Post
Trap Speeds please?
All we care about!! Trying to get some tires to see what it does.
510-530whp last time got us 134mph traps. I am just worried we will run out of gearing and be shifting 5th. It should trap well into the 150s
