![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 335793
VIC
Vehicle:2009 Impreza Wrx Silver |
I just got a new wheel and tire set up for my 2009 wrx hatch and am having a problem with the tires rubbing on the fender lip. Just wondering what is better, shaving the fender lip or rolling the fender lip. Discuss!
#2 |
Vehicle:OK Houston we have an Uncle |
shaving...done wrong, would be worse than a poor roll job
shaving would require proper priming/rust prevention get wheels and tires that fit properly and dont do either |
#3 | |
Member#: 97135
NWIC
there is so much risk with shaving the fender, and if it isn't done properly.....will royally **** up the fender. |
#4 |
Member#: 278439
Tri-State
Vehicle:2011 WRX Sedan OBP |
^ This is the best solution but if you are set on getting the wheels to fit, take it to a professional that will use an Eastwood Fender Roller, the correct amount of heat and enough patience to do it without the fender paint cracking. It should run you around $50-60 per corner for a roll and refinish. You may also want to look into an alignment before you start rolling. A bad roll can be fixed, where once things are cut off they are gone forever.
#5 |
Member#: 337122
I wouldn't attempt either. Buy of the two, go for the roll. But, expect to pay for refinish because the paint will surely crack.
#6 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
#7 |
Member#: 335793
VIC
Rented an Eastwood roller for 20$ and rolled the fenders today with the help o my gf "womaning" the heat gun! Managed to roll the fender lip completely flat without cracking the paint what so ever!!! I am quite pleased with the job we did and surprised at how easy it was! I recommend this to anyone it's cheap and easy to do your self!
#8 |
Member#: 282911
where do you rent a roller?
#9 |
Member#: 139955
NESIC
Google.
#10 |
Member#: 197764
NESIC
Vehicle:02 WRX Stage DD PRND 01G |
1. Enjoy car and wait until your fenders are already rusty from age
2. Do whatever to make the wheels fit 3. Refinish/paint fenders Unless you know what you are doing or you plan to pay a premium, don't do this and plan to have your fenders come out nicely. There is absolutely no way you will not disturb the integrity of your paint by stretching and bending the surface it is adhered to, even if it looks like you haven't! Do not ever shave your fenders unless you have a very clearly thought out reason to. Shaved fenders loose their structure very easily and will be prone to bending/warping, even under normal conditions. |
#11 | |
Member#: 254958
#12 |
Member#: 338879
NESIC
Vehicle:2002 Wrx black |
If this car is your daily then just go for the roll if your just looking for inner clearance but absolutely use a heat gun thoroughly before doing so to try and eliminate cracking of your paint. Plus you'll save your self headache and $$$$
#13 |
Member#: 325852
hacksaw and sharpie
