Originally Posted by danstheman7
I'd love to know how to change them too. Asked this a while ago, no one gave me an answer. I can't even get my hands into the corners
Ok then I'll tell ya. I was kinda disappointed with no responses myself. I used a pair of needle nose pliers to twist the bulbs to get them out & pull the socket out to get at the bulb. Once the bulb is replaced getting it back in is the hardest part. Since I ended up dropping the frigin bulb in the engine bay I had to search for it. I ended up having to take off 4 pop clips to get my hand into the engine bay. I took off the pop clip that is to the left of the drivers side wheel which is the main pop clip that holds the under cover (that keeps water out of the engine bay). Then 3 clips that are under the cover (between wheel and front of car underneath). I got my hand under there and found the bulb but also found that it was much easier to twist the bulb back into place. Twisted the socket back into place and was done.
I know my descriptions weren't the best but if you have any questions let me know and I'll help you out. The project sucked, mostly because I dropped the bulb and had to search for it but the bulbs I put in look amazing. I'm really happy with the outcome. The stock yellow looking bulbs look crappy with hids. Best of luck!
