Old 11-10-2012, 03:19 PM   #1
Bugeye386
Member#: 162975
Default Stage 3 06 wrx tr looking for a bit more.
Hi guys, I've been searching around a bit on options for some more power for my wrx. Current mods:
Catless dp and spt cat back
Gm boost solenoid
Sti top mount intercooler
VF39
Open source tune similar to xpt tuning stage 3 map
I'm not sure how much power I'm making right now but I would guess in the neighborhood of 275 whp probably? Looking to make a bump in power and still keep things relatively safe. I know the tranny is at risk already, and I know adding any power makes things less reliable. Just looking for something that can be tuned conservatively and still make good power somewhere in the 325 hp range. Was considering:
18g or 20g. Let me know what support you think these need.
Vf43?
Adding meth, haven't researched much so any info helps.
Going to xpt stage 3 race which adds cai and fuel pump and retune.
Any combo of more minor mods and a good protune.
Any suggestions welcome. This is a daily driver and will be used for fun on the street, very little track time.
Bugeye386 is offline   Reply With Quote
Old 11-10-2012, 03:46 PM   #2
04ScoobyWtf
Member#: 287974
18g 750cc injectors Wally and pro-tune no need for an intake.
04ScoobyWtf is offline   Reply With Quote
Old 11-10-2012, 08:38 PM   #3
Bugeye386
Member#: 162975
Which 18g? Td05 8cm^2
Old 11-10-2012, 08:44 PM   #4
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
That's a nasty turbo for the 2.5
wrxlaunch is offline   Reply With Quote
Old 11-10-2012, 08:47 PM   #5
Bugeye386
Member#: 162975
What would you go with instead?
Old 11-10-2012, 08:58 PM   #6
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
i think he means nasty in a good way... but i would go with a blouch 20gxt instead. because i already did and love it.
thisisntjared is offline   Reply With Quote
Old 11-10-2012, 10:03 PM   #7
04ScoobyWtf
Member#: 287974
Bloush 18g xt-r will hit 350
Old 11-11-2012, 08:55 AM   #8
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
I'd get injectors and a pump. You should be able to break 300hp with that and a good tune. Fuel will be a must anyways if u upgrade the turbo.
Whats ur budget? For a cheap bolt on replacement get the blouch 20g. for about double that you can get a twin scoll kit and get better spool up on a big turbo. bigger turbo and conservative boost will give you more reliability because you'll be running more in the efficiency range. intercoolers are there to help compensate for running your turbo outside the efficient range.
meth would be the cheapest option. it would be like running e85 and having a much better intercooler for about $500.
tunertype is offline   Reply With Quote
Old 11-11-2012, 09:53 AM   #9
thisisntjared
Member#: 177891
06 wrx wagon
you might want to clarify. you aren't saying a twin scroll will spool faster than a 20gxt are you?
i can understand if you mean: a twinscroll setup will have great spool for a big turbo, but will only spool a little later than a 20gxt
Old 11-11-2012, 10:57 AM   #10
02_WRX_<3
Member#: 226709
2002 Bugeye ftw!
Psm
A buddy of mine hits full boost about the exact same/a few rpm sooner than he did with a stock vf with his blouch 20g
Not sure if it's the xt or the xt-r
I don't really know why I posted that, maybe just to confirm that the 20gs spool fast as hell haha
02_WRX_<3 is offline   Reply With Quote
Old 11-14-2012, 03:48 PM   #11
Bugeye386
Member#: 162975
Thanks for all the info. Any other suggestions? My tuner said he can't get to 320 whp with a vf39 . Said to look at 18 or 20 g or even better the fp turbos. I'd like to keep the spool quick for fun on the street which is why in hesitant to go bigger in the turbo. That and I want to maintain some level of safety for the stock block
Old 11-14-2012, 07:46 PM   #12
thisisntjared
Member#: 177891
06 wrx wagon
if i were you, i would do more research on the dyno database that cobb makes available on their website, they have loads of comparisons, athough you can only load 4 cars at a time.
further, i would speculate that the hta68 or blouch 18gxt would spool somewhat close to the vf39 and go way beyond after 4.5krpm.
