Old 11-11-2012, 12:48 AM   #1
redrex009
Member#: 337456
2009 wrx
lightning red
Default 2009 wrx max power
Max power my 09 can handle? Reliability is extremely important to me..... its my dd and my first subie. Any suggestions or advice would be awesome.
redrex009 is offline   Reply With Quote
Old 11-11-2012, 12:50 AM   #2
redrex009
Member#: 337456
2009 wrx
lightning red
Oh and no mods yet..... still considering an sti..... but love the waymy 5 spd is geared
Old 11-11-2012, 12:53 AM   #3
sc00by4life
Member#: 97135
leave it stock. period.
if this is of ANY question with ANY car that you own, leave it stock. "whats the most power my car can handle" and "i want reliability" are so extremely contradictory.
Old 11-11-2012, 12:57 AM   #4
redrex009
Member#: 337456
2009 wrx
lightning red
Well i guess im talking reliable power...
Old 11-11-2012, 12:59 AM   #5
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
5spd is weak. Will blow past 340whpish.
09 is also known for cracking ringlands fairly easy. I'd just leave it stock.
Zach Bitzer is offline   Reply With Quote
Old 11-11-2012, 01:41 AM   #6
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Bull****.
i_c_the_light is offline   Reply With Quote
Old 11-11-2012, 01:59 AM   #7
redrex009
Member#: 337456
2009 wrx
lightning red
Tell me more ic ive heard the 09+ tranny is way stronger than previous years i just want some advice.....
Old 11-11-2012, 02:15 AM   #8
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
I'd say "Stage 2"....i.e downpipe, tune and a intake if you want the sound.
DurtyB is offline   Reply With Quote
Old 11-11-2012, 02:19 AM   #9
redrex009
Member#: 337456
2009 wrx
lightning red
Definitely want the sound... thats for sure. My cars quick stock no doubt. I just want more power reliably..... ive been told i always want more lol... maybe.
Old 11-11-2012, 02:22 AM   #10
redrex009
Member#: 337456
2009 wrx
lightning red
Plus i know the vf-52 is a powerful turbo overly capable.... been told it might be the best stock yet.
Old 11-11-2012, 02:34 AM   #11
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
The 5 speed myth is crap. They've been used on the jdm cars since 1989 and the USDM was the first market to complain despite having the most underpowered WRX ever made.
Old 11-11-2012, 08:09 AM   #12
tommyson01
Member#: 154579
2005 OBXT
Old man blue
Go stage 2 and call it a day.
Something that would help would be for you to post your:
WHP goal
Budget
Goals for the car (ie what it's going to be used for)
tommyson01 is offline   Reply With Quote
Old 11-11-2012, 08:19 AM   #13
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
With the 09 go torqued performance stage 3.
Chaz2.5 is offline   Reply With Quote
Old 11-11-2012, 08:57 AM   #14
tank1987
Member#: 223181
05 WRX, stage mehh
hybrid built SOLD!!! :(
Anything can be reliable if you maintain and treat it good. If you are wanting to actually get into cars for real, then do your research, learn and read. Then mod, its fun. If you dont want to put in the real time which is in the books. Then stay stock. But honestly stock can be just as unreliable as modded. Granted modded has the make up to break down obviously more than a stock car.
tank1987 is offline   Reply With Quote
Old 11-11-2012, 12:34 PM   #15
redrex009
Member#: 337456
2009 wrx
lightning red
WHP goal
Budget
300-350WHP, probably 1000 to 1500 bucks.. and my goal is a VERY spirited daily driver.
Old 11-11-2012, 12:44 PM   #16
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Intake, header, up pipe, down pipe, catback, TGV deletes, turbo inlet, fuel pump, intercooler, external wastegate, EBCS, injectors. Pick any/all of these, some need to go together, some don't. Start with a down pipe and catback (if you have the stock not SPT catback). Catted or catless doesn't matter too much at your power levels. The most important thing is to make sure your tuner knows that you want it to be reliable while still upping the performance. You will sacrifice some power by doing that, but it'll be safer.
For reliability's sake, get a Killer B oil pickup. After inspecting mine, I'd recommend you do that sooner than later.
Edit: I wouldn't recommend going much past 320whp. Mine failed at 350whp.
Old 11-11-2012, 01:10 PM   #17
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
That is was ever a glass tranny is a myth, what is not a myth is that they put the wider profile LGT gear set in in the 5speed from 2007 onward. You can still break it with half of the stock hp, as always it all come sown to the driver.
$1500, AP/Tune, Bilstein dampers with matched RCE springs. This get you close to 300whp and have a greatly increased handling.
If you want to farther from there, DP with a highflow Cat $450ish, (you do not want to use a catless DP with the 09+, they often develop boost creep problems that can not be tuned out) and 3in catback (another $450ish)to go with it. You will be able to tune this to 350ish whp.
Then a somewhat larger rear sway bar and stronger endlinks will help eliminate the last of the under steer and make the car pretty neutral, but most of the under steer will disappear with the better dampers and increased spring rate, I went with the 330lb/in RCE yellows and love them (as does my wife, they are not st all harsh with the better dampers)
Also a nice improvement is lighter a rims, the stockers are pigs, I swapped in RPF1's and saved 15lbs/corner of unsprung weight and put snow tires on the stockers for winter, cost me all of 300$ for the rims on craigslist.
etothen is offline   Reply With Quote
Old 11-11-2012, 01:26 PM   #18
be0tch
Member#: 66206
2005 WRX STi
I don't think you're coming near 300whp unless you have at least a downpipe "stage 2" type setup.
You could definitely get that professionally installed w/ quality parts and still be in your price range with some money to spare.
350whp is gonna be another matter entirely.
be0tch is offline   Reply With Quote
Old 11-11-2012, 01:34 PM   #19
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
I'm at 300whp with aem cai and a cobb catted dp. Easy to get to those numbers!
Nimbus09 is offline   Reply With Quote
Old 11-11-2012, 01:35 PM   #20
rexblake
Member#: 178426
2010 S4
Gray
Stage 2 (dp and tune) is generally considered the safest route if you want extra power.
I wouldn't worry about your 5 speed. The 02-03 MY were the ones you really had to worry about shearing gears. Particularly on medium to large turbos (20g, gt3076, gt35, etc).
The vf52 certainly seems to be the best vf series turbo to date. Should get you close to 300whp, depending on dyno and fuel used.
Old 11-11-2012, 01:37 PM   #21
be0tch
Member#: 66206
2005 WRX STi
Yeah. Really just a dp+tune is enough to hit 300whp on 93.
Old 11-11-2012, 01:39 PM   #22
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
Find a used high flow catted downpipe and get your car protuned. If you are getting your downpipe professionally installed then you will probably be around the lower end of your budget with this setup. You may be able to find a used cat back and keep everything under your $1500 limit
snowboarder2587 is offline   Reply With Quote
Old 11-11-2012, 01:45 PM   #23
be0tch
Member#: 66206
2005 WRX STi
The gain from the catback will be minimal compared to the cost. You might be better off considering ebcs, injectors and fuel pump (in addition to stage 2 setup). This could push you over budget.
Then again, if you find this stuff used or do the work yourself you could save a considerable amount of money.
Old 11-11-2012, 01:48 PM   #24
rexblake
Member#: 178426
2010 S4
Gray
If you curious what other people have put down with the vf52, check out Cobbs dyno database.
Old 11-11-2012, 02:20 PM   #25
SWP n Gold
Member#: 110783
2010 WRX
Downpipe + tune. Less than a grand even if you go the AccessPort route and opt to buy both new instead of used.
SWP n Gold is offline   Reply With Quote
