Old 11-10-2012, 06:38 PM   #7376
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Originally Posted by Cmac13
I don't know about +25 that would take some negative camber to prevent those from rubbing (like -4 or -5 maybe) I have +35 with rolled fenders and -3 camber. I would go with the +42 and if you want a wider stance get 5 or 10mm spacers
Honestly... I dont know why I never thought about using spacers...
Slow Scoobie is online now   Reply With Quote
Old 11-10-2012, 09:22 PM   #7377
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
More than 10mm and you need extended bolts
Navysesal is offline   Reply With Quote
Old 11-11-2012, 12:05 AM   #7378
gbkallday2.5i
Member#: 329199
2010 Impreza 2.5
Originally Posted by Digital Dillon
Based on what I've read, other people seem to like the Racelands. They do not have adjustable dampening (adjustable shock stiffness) like every other coilover out. And, they have a set spring rate (spring stiffness) while some companies offer different rates and I know ISC will do custom spring rates at no charge. You may want to consider new rear lower control arms or the whiteline rear camber bushing kit because lower = more camber and the rear can not be adjusted without aftermarket parts. If your on a budget just go for the Racelands. I believe they are $550 after shipping. The next cheapest is ISC which can be had for $875 shipped.
so all that I would need to do it just buy the raceland coilovers and that comes with 4 struts and springs all put together and I would just have to put them on correct? or is that wrong? and are there any supporting mods that will have I get done along with the coilovers?
gbkallday2.5i is offline   Reply With Quote
Old 11-11-2012, 12:48 AM   #7379
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Yup that is all out with the old in with the new. Installing is very straight forward. The hard part is setting everything up the way you like it. So basically rise height since racelands dont have dampening adjustment. Then just ride around for a bit to let them settle(much debated topic) then get an alignment.
Old 11-11-2012, 01:17 AM   #7380
gbkallday2.5i
Member#: 329199
2010 Impreza 2.5
sounds easy enough!
like I said I am new to the whole suspension modifying thing.. what is dampening?
Old 11-11-2012, 01:28 AM   #7381
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by gbkallday2.5i View Post
sounds easy enough!
All your answers can be found here. Read up young grasshopper
Old 11-11-2012, 01:32 AM   #7382
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
sounds easy enough!
Dampening lets you adjust how stiff the suspension is. Basically letting you choose how soft or hard the ride will be. Most coil overs are 24 or 32 way adjustable.
Old 11-11-2012, 08:17 AM   #7383
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
How's those fortune autos treating you?
BSP671 is online now   Reply With Quote
Old 11-11-2012, 11:44 AM   #7384
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Great I actually just pulled them off to clean them
Old 11-11-2012, 12:11 PM   #7385
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Are coilovers suppose to come with shock covers? I'm scared it's gonna seize from all that grime on the road
I have stances btw
Old 11-11-2012, 12:43 PM   #7386
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
I have stances btw
My fortune autos came with shock boots but I clean them regardless
Old 11-11-2012, 01:37 PM   #7387
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Yours don't have? Usually almost always has, heck even cheapo ones have em'. I would conjure up some DIY dust boot to at least have a piece of mind knowing that a good amount of nasty s*** is off the shaft (pun intended lol). Condom reference maybe? Haha
Old 11-11-2012, 01:41 PM   #7388
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Lol I wouldn't go that far, too lazy I guess. I just hose it down and wipe em' up. I'd give it a few months till I just don't give a f*** any more lol
Old 11-11-2012, 01:50 PM   #7389
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Yah I didnt see any. If they dont ill just buy a generic one and slap them on
http://www.maximummotorsports.com/st...roducts_id=975
Old 11-11-2012, 02:19 PM   #7390
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
I'd be more worried of the collars seizing up. The exposed threads like to collect all the salt and road grime!
Old 11-11-2012, 03:03 PM   #7391
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Well my coil seating collar came loose twice already so I wouldnt mind it seizing
if I'm gonna install the boot I'm problably gonna lower it another inch, I'm too use to the 2 finger gap now. Problably gonna go 1 finger
Old 11-11-2012, 03:04 PM   #7392
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Winter wheels.. plasti-dip blaze blue. Pretty cool color. The more coats you put on, the brighter it gets.
daigledangle8 is offline   Reply With Quote
Old 11-11-2012, 05:25 PM   #7393
09subi2.5i
Member#: 331636
09 impreza
paprika
Does anybody here have 17x7.5" wheels on the stock suspension? And if so did you notice any different in ride quality? Would the profile of the tire be too small? I do not want to have to constantly dodge potholes. Looking to buy Enkei RPF1 with potenzas re90as
09subi2.5i is offline   Reply With Quote
Old 11-11-2012, 05:36 PM   #7394
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
17x7.5 will be fine, the stock suspension will absorb most of those bumps and as long as you arent stretching your tires you will be fine. The enkei's are very strong and lightweight, I love my PF01's but the rpf1's are very lightweight. Just make sure to get the proper size otherwise your speedometer will be off. Ill do your research and say that w/ a 17x7.5 wheel, the proper tire would be a 225/45/17 according to tirerack.
Blox lug nuts for sale! Pm if interested.
Old 11-11-2012, 05:36 PM   #7395
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Also, just picked this up today
Old 11-11-2012, 06:08 PM   #7396
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
Well there was more then just cleaning. I had to redo my spring preload. Plus I adjusted the ride height
Old 11-11-2012, 06:32 PM   #7397
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
I had 17x7.5 with a 235/45/17 ride quality was almost identical on stock suspension. No rubbing at all even when hitting pot holes or other imperfections in the road.
@navysesal pssh 1 finger gap! NO GAP all around! Tuckin!
Old 11-11-2012, 06:37 PM   #7398
Slow Scoobie
Member#: 320464
09 2.S"low"
Dark Gray Metallic
I just slapped my steelies on..im thinking of painting them either neon orange or pink. But damn blue looks good too. Kinda old school
Old 11-11-2012, 07:11 PM   #7399
09subi2.5i
Member#: 331636
09 impreza
paprika
Thank you! Where could I find the answer to the speedometer problem? And do you think I will be able to take my car on dirt a bit? Right now I have the stock 16" steelies. (I'm a bit worried as you can tell but ordering online I don't wanna mess it up!)
Old 11-11-2012, 07:15 PM   #7400
09subi2.5i
Member#: 331636
09 impreza
paprika
Thanks I needed that re assurance to purchase these haha
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
Message Board Statistics All times are GMT -4. The time now is 01:08 AM.
