Old 11-11-2012, 07:32 AM   #26
finklejag
Member#: 318622
2012 Impreza
I just turned 10,000 miles. I rotated the tires for the second time yesterday. They still look brand new. The S30B have a UTQG of 320, and no mileage warranty. I was only expecting to get about 20,000 miles out of these. I might get 30K + out of them now.
finklejag is offline   Reply With Quote
Old 11-11-2012, 08:36 AM   #27
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
We had Bridgestone turanza el400's that came on our jetta, supposed to be a 40k tire iirc, but we got 72k out of them.
Old 11-11-2012, 09:22 PM   #28
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
When was the first time that you rotated your tires?
Old 11-12-2012, 07:33 AM   #29
finklejag
Member#: 318622
2012 Impreza
I rotate my tires every 5K.
Old 11-14-2012, 02:24 AM   #30
pkL
Member#: 313093
2012 Impreza 2.0i
Thanks, if that's the case I'm overdue then, rotating them early can never hurt (should improve gas mileage too). Did you rotate them yourself? Just front to rear and vice versa or did you criss cross them as well?
Old 11-14-2012, 06:37 AM   #31
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It's in the manual. The interval is 7500(every oil change).
Old 11-14-2012, 07:44 AM   #32
finklejag
Member#: 318622
2012 Impreza
I always rotated my tires every 5K on all my cars. I do it myself. I do front to back only. They usually last near the mileage warranty.
Old 11-14-2012, 08:11 AM   #33
Zeeper
Member#: 299286
2012 Sport 5MT
Green/Silver
7,500 mile rotation interval, (or 7.5 months if that comes first per Cars101).
I did mine at 6,000 miles or so, it is probably better to rotate them more at the beginning of the tire life and then extend to the longer intervals later on.
However, as a non-directional tire you will get more wear out of them if you follow the rotation pattern in the manual. All you need is a jack and two jack stands to rotate all the tires this way (you can leave one tire on the ground, lift two on stands, and swap tires while the car is lifted with the jack (no need to get under the car, so lifting with the jack to install a tire is alright by me).
Old 11-15-2012, 04:07 AM   #34
pkL
Member#: 313093
2012 Impreza 2.0i
Okay thanks for clearing that up, I will rotate my tires the next time I change my oil, which is coming up pretty soon.
Message Board Statistics All times are GMT -4. The time now is 04:11 AM.
