Old 09-20-2012, 05:02 PM   #76
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Just ordered up a few new parts;
-JPMCoachworks Shift Boot
-JPMCoachworks Ebrake Boot
-Prova SI-Drive Knob
-Bayson-R Front Lip
JPMCoachworks will be doing quite a bit of stuff for me in the up and coming months, I'm excited to meet up with them and discuss some stuff at SEMA in Las Vegas!
I'm also in the middle of an extensive detail session with the car, getting it ready to head down to Englishtown for EVO vs STi Shootout! Its a "track" car but I like to keep it clean!
wrxadam05 is offline   Reply With Quote
Old 09-20-2012, 05:19 PM   #77
noside
Member#: 241254
2015 Scat Pack
Good to hear, I'll be at the shoot out on Saturday also. Interested in the times you can produce and checking out the car.
noside is offline   Reply With Quote
Old 09-20-2012, 05:56 PM   #78
wrxadam05
Member#: 84070
500whp GRB STI
Sounds good, where you driving in from?
Old 09-20-2012, 06:08 PM   #79
noside
Member#: 241254
2015 Scat Pack
I'm from central NJ so it takes me about 15 mins to get to e town.
Old 09-20-2012, 09:55 PM   #80
wrxadam05
Member#: 84070
500whp GRB STI
Nice, come say hey if you see me.
Old 09-21-2012, 09:55 AM   #81
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
-Bayson-R Front Lip
ill be there too! posted in here sayin i have a similar build but never responded (sorry) but shes done and being broken in now!
look for 2010 AW sti se with orange ic piping and a purple gtx3076
04wrexsti is offline   Reply With Quote
Old 09-22-2012, 07:16 PM   #82
wrxadam05
Member#: 84070
500whp GRB STI
Sorry didn't see ya out there. I was on low boost because the guy said I couldn't go faster than an 11.99 because I didn't have a fire jacket. 18psi got me a [email protected] which isn't really bad seeing as I cut a 2.0 60'.
Old 09-22-2012, 10:51 PM   #83
idratherbesurfing
Member#: 282972
2006 Sti
cgm
did u run with a roof rack? if so ill upload your video.
idratherbesurfing is offline   Reply With Quote
Old 09-23-2012, 12:35 PM   #84
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
yeah im still on base map breaking my car in so i didnt run it, i was going to put it in the show but didnt really feel like sitting around all day haha.
i did see your runs, i cant believe 18 psi got you that!, cant wait to see what itll do on your real map
Old 09-23-2012, 01:47 PM   #85
wrxadam05
Member#: 84070
500whp GRB STI
Nope look through the thread, no roof rack .
Old 09-23-2012, 01:50 PM   #86
wrxadam05
Member#: 84070
500whp GRB STI
I have a bad habit of not laying into my launch control for some reason. Wouldn't of made a difference because of the clutch. I do part throttle then floor it on green, leaving the line with no boost... new twin going in, then going back out for low 11s.
Old 10-15-2012, 11:16 AM   #87
wrxadam05
Member#: 84070
500whp GRB STI
Two pictures I took at EVO VS STI Shootout @ Englishtown.
Swapped out brakes for DBA 4000 Series Club Spec
And Motul RBF600
I built this whole car in my 1 car garage, it sucks ass...
I also swapped out the rear diff fluid for Motul MOTYLGEAR 75W90, and the transmission fluid for Motul Gear 300.
Old 11-06-2012, 01:48 PM   #88
WhatTurboLag?
Member#: 243992
2006 WRX TR
How is the car without avcs? I'm still really thinking about doing that but mine will be more of a daily.
I got a jpmc boot aswell. It's a hybrid boot to combine my console with the sti shifter
WhatTurboLag? is offline   Reply With Quote
Old 11-06-2012, 03:23 PM   #89
wrxadam05
Member#: 84070
500whp GRB STI
Just saw your post, sorry for the late reply. Car is great without AVCS, you get quite a bit of CEL's but once disabled everything runs flawlessly. I even passed inspection without ANY codes popping up.. BOOYA!
It has great power down low, nobody would ever be able to get in my car and say "AVCS is definitely disabled". From here on out, NONE of my Subaru's will have AVCS.
Old 11-06-2012, 09:55 PM   #90
WhatTurboLag?
Member#: 243992
2006 WRX TR
Wish you were closer so I could see for myself hahahahaha. I want to do a 2.3 de stroker, (might sleeve and bore to a 2.5) and want to do everything once for max reliability. Hence the longer rods. And deleting avcs I feel like would increase reliability a lot, am I correct? Lol
Old 11-07-2012, 09:22 AM   #91
wrxadam05
Member#: 84070
500whp GRB STI
Absolutely. You can take my word for it. I have owned every version of WRX and STi that was ever released in the states. Running it without AVCS and around 9:1 compression is definitely the way I will build all my engines from here on out.
Remember, if you delete AVCS you have to keep the solenoid on the heads. Some people delete the exhaust side, but just keep that **** on there. Its not hurting anything. I also leave them plugged in but disable them in the ECU.
Old 11-07-2012, 02:58 PM   #92
WhatTurboLag?
Member#: 243992
2006 WRX TR
Interesting, you couldn't run a static cam gear off a wrx or something on both sides?
Old 11-08-2012, 02:50 PM   #93
wrxadam05
Member#: 84070
500whp GRB STI
You can, but then you wouldn't be able to degree the camshafts in. They have different centerlines, so in order to get timing correct you have to use adjustable cam gears. You can't use WRX cams either for the "correct" centerline because the cam position sensor pickups are different. So I went with 04-07 camshafts so I didn't have to do 4 x AVCS Deletes (Tap and Plug), with 04-07 cams I only had to do 2, the exhaust camshafts.
Old 11-09-2012, 11:18 AM   #94
WhatTurboLag?
Member#: 243992
2006 WRX TR
Interesting. If I do it I want to physically remove the gear. Is be worried about them moving or getting screwed up or anythinh
Old 11-12-2012, 09:41 AM   #95
wrxadam05
Member#: 84070
500whp GRB STI
I don't understand what your saying, you can't do an AVCS delete correctly without adjustable cam gears as the centerline for the cams is off. The only other way to do it is to use WRX cam gears and a LIC adjustable idler pulley.
http://licmotorsports.com/products/l...sti_lic-061505
You would use those in order to move the cam gears in the correct position, however that is way harder than just getting adjustable gears from BC.
Old 12-02-2012, 07:02 PM   #96
wrxadam05
Member#: 84070
500whp GRB STI
Not sure if this will work, but taking her for a drive before putting her away for the winter and MORE POWER in 2013.
http://www.facebook.com/photo.php?v=3781794273962
Old 12-05-2012, 09:28 AM   #97
wrxadam05
Member#: 84070
500whp GRB STI
Out she comes!
Sorry for the absolutely hideous pictures. I'm going to buy myself a new Nikon DSLR for x-mas, tired of instagram pictures LOL.
Plans;
New fuel system, custom harness, possible intake manifold flip, re-ring, cosworth head gaskets, MAYBE Carrillo rods, new clutch, ceramic coating, random powdercoating, and brake booster delete. Oh, and probably composite TGV's.
Looking to make Mid 500's on pump 93 in the spring.
Old 12-10-2012, 01:42 AM   #98
MotsoWRX
Member#: 338926
2011 Subaru Sti
Wrb
Engine bay looks great.
MotsoWRX is offline   Reply With Quote
Old 12-10-2012, 02:26 AM   #99
NOTanEVO
Member#: 210790
title of this thread needs to be changed...
WORLDS FIRST MILLION DOLLAR GR.
excellent work my man that is one well kept and well wrenched machine you have there
NOTanEVO is offline   Reply With Quote
Old 12-10-2012, 02:31 AM   #100
NOTanEVO
Member#: 210790
double post
