Old 11-11-2012, 03:31 PM   #26
redrex009
Member#: 337456
2009 wrx
lightning red
Thanks guys, this is all super helpful stuff.....i think ive also got what i think is a boost creep issue on the stock tune... its becoming a more apparent issue.... upon acceleration its very hesitant before boosting any thoughts?
redrex009 is offline   Reply With Quote
Old 11-11-2012, 03:38 PM   #27
redrex009
Member#: 337456
2009 wrx
lightning red
I live like right next to surgeline in tigard oregon. ..... just saving up, then thinking about going and seeing those guys
Old 11-11-2012, 03:40 PM   #28
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
What exactly is happening? Like stuttering as it goes into boost?
Old 11-11-2012, 03:44 PM   #29
redrex009
Member#: 337456
2009 wrx
lightning red
Yes,exactly wtf is that?
Old 11-11-2012, 04:33 PM   #30
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Fill out your profile first off.
Secondly, read UNABOMBERS MANIFESTO, it's a handy sticky located at the top of the Newbies and FAQS section.
Thirdly, how much power it can handle comes with far too many variables to answer. Your goal is 300 whp for 1000-15000 bucks, easily done. Research 4 times and buy just once.
And finally, if you live so close to a performance shop for Subaru's, why not give them a call and tell them your goals? They will give you the exact way to do it, and for a bonus you can ask about your problem and get a good answer.
Old 11-11-2012, 05:37 PM   #31
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
I've got a 2009 too. My plans are dp, upgraded tmic, injectors, pump, tune. so far I've done an AP tune and am up 33hp from stock. the dp should get close to 300hp.
Injectors and pump for reliability. 268whp is at 88% IDC for me, so 300whp would put them very close to max. Possible to get 300whp with stock fueling, but not reliable.
the tmic serves two purposes 1 its stronger than the stock plastic that can hold anywhere from 18-22 before breaking depending on who u ask and 2 it can help compensate for running the turbo in a lower efficiency band in the higher rpms.
I wouldn't expected a modded car to be very reliable. just keep some money in the bank and order performance parts when the stock parts break.
tunertype is offline   Reply With Quote
Old 11-11-2012, 06:37 PM   #32
redrex009
Member#: 337456
2009 wrx
lightning red
For sure man i could do that just looking for different opinions and discussion beforehand too alot of you guys are knowledgeable and have had similar experiences.....thanks bro.....
Old 11-11-2012, 07:00 PM   #33
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
Originally Posted by redrex009
Max power my 09 can handle? Reliability is extremely important to me..... its my dd and my first subie. Any suggestions or advice would be awesome.
Any car can "handle" any power with the right mods
That being said, torque becomes an issue with wrxs before power does
brew02wrx is offline   Reply With Quote
Old 11-11-2012, 07:01 PM   #34
tommyson01
Member#: 154579
2005 OBXT
Old man blue
This is some of the best advice in this whole thread (and you gave it to your self). Tim Bailey knows what he is talking about.
tommyson01 is offline   Reply With Quote
Old 11-11-2012, 07:11 PM   #35
Meldarred
Member#: 226227
2012 WRX STI LMT
PBP - purple?
Originally Posted by Nimbus09 View Post
I'm at 300whp with aem cai and a cobb catted dp. Easy to get to those numbers!
With what kind of reliability? I am so tired of seeing these posts about an intake and downpipe hitting 300 AWHP, because it is not the entire story. Read the posts on these forums from unibomber.. Supporting mods are your friend... Do the research on the forums before you do anything. It will really save yourself some time and frustration..
Meldarred is offline   Reply With Quote
Old 11-11-2012, 07:13 PM   #36
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Could be a lot of things...
Accidentally filled with 87 octane?
Spark plugs getting fouled
Piston ringlands are shot (That's what mine started with)
Those are just 3 I thought of off the top of my head, there could be others. Regardless, if you haven't put 87 octane in, I'd have a compression test done and you may as well replace spark plugs while you're there.
Old 11-11-2012, 11:28 PM   #37
redrex009
Member#: 337456
2009 wrx
lightning red
Nope always 92 as long as ive owned it i always get out and make sure lol and thanks that gives me a good pkace to start...
Old 11-11-2012, 11:32 PM   #38
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Others may be able to chime in with other ideas...
Old 11-12-2012, 12:15 PM   #39
cmiovino
Member#: 134005
2004 WRX Premium
In my opinion, the typical 'stage 2' setup of a downpipe, catback, and tune is best for the money. 25% power increase for roughly $2000 total. That's not bad at all. And that's with name brand parts. Throw in the Cobb SF intake if you like too... assuming you're going with the Cobb AP.
That's approximately 330HP crank give or take. You're up to around 265 to the wheels. (In general, stage 2 upgrades take your stock crank HP and make it your new wheel HP... with different tunes, results will vary.)
Old 11-12-2012, 12:19 PM   #40
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
You must not be too familiar with the newer WRX's. He should be around 300whp with a downpipe, intake, and tune.
Old 11-12-2012, 12:27 PM   #41
stiguy2008
Member#: 332709
Smh 300whp out of a wrx with exhaust & tune? I wanna just take a guess & say the wrx barely makes 200whp from the factory if that due to the awd drivetrain loses bc the sti only puts down around 230whp stock! advertised hp is not at the wheels by any means. Just figured I'd try to help ya out(:
stiguy2008 is offline   Reply With Quote
Old 11-12-2012, 12:30 PM   #42
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Well seeing as the VF52 is almost exactly the same size as the STi turbo, it is almost completely in the tune.
Old 11-12-2012, 02:08 PM   #43
redrex009
Member#: 337456
2009 wrx
lightning red
From the dynos i've seen 09+ puts down between 220 and 230 stock depending on the dyno.... i hope the sti puts down more than that...
Old 11-12-2012, 02:12 PM   #44
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
09+ WRX's and STi's make almost the same power with the same mods. The tranny probably makes the biggest difference.
Old 11-12-2012, 02:19 PM   #45
Badler
Member#: 133597
It doesn't.
Badler is online now   Reply With Quote
Old 11-12-2012, 02:32 PM   #46
tommyson01
Member#: 154579
2005 OBXT
Old man blue
I think you're confusing Sti numbers with WRX numbers...
Old 11-12-2012, 02:37 PM   #47
redrex009
Member#: 337456
2009 wrx
lightning red
Surgelines dynos
Old 11-12-2012, 02:42 PM   #48
redrex009
Member#: 337456
2009 wrx
lightning red
Theres a stock to stage 2 comparison look it up
Old 11-12-2012, 02:55 PM   #49
Fotown
Member#: 325459
09 WRX
Stg2 Black Sedan
So you are saying that the STI has a drive-train loss of around 80+hp? or almost a 3rd.
Fotown is offline   Reply With Quote
Old 11-12-2012, 03:03 PM   #50
be0tch
Member#: 66206
2005 WRX STi
Uncorrected low-reading dynos of STis can be in the 200-215whp range, so yeah.
be0tch is offline   Reply With Quote
