![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
Member#: 291681
MAIC
Vehicle:'04 STi PSM - 340whp/340wtq |
I just bought an STi and it had the 3M protective headlight film on it. When I removed it, it left a lot of adhesive. What can I use to safely remove the adhesive without damaging my headlights?
Thanks TJ
#2 |
Member#: 234416
MAIC
Vehicle:It's A BRAAAAAHtato, Yo. |
Goof Off and a fair amount of elbow grease
#3 | |
Member#: 107000
MAIC
Vehicle:2008 STI <3 TXS and 2011 F150 Andrewtech |
#4 |
Member#: 266514
MAIC
Vehicle:2011 OBP STi Sedan OBP |
bug and tar remover and elbow grease
#5 |
Member#: 265098
MAIC
Vehicle:2003 wrx silver w/ blk enkei rims |
alcohol wipes, dry paper towels/microfiber towel and windex. DONE! that's what I used when I removed my old tint and there was still some adhesive left behind. works like a charm and didn't take a lot of elbow grease. But it also depends on how thick the **** is so elbow grease is depending. good luck
#6 |
Member#: 337465
SCIC
Vehicle:2002 WRX GDA Sedona Red Pearl |
rubbing alcohol will help
#7 |
Member#: 252748
MAIC
Vehicle:2013 wrx DGM |
acetone or nail polish remover.
#8 | |
Member#: 234416
MAIC
#9 |
Member#: 321791
MAIC
Vehicle:05 STi Aspen White |
WD40 is something almost everyone has, its a better cleaner than it is a lube lol.
FWIW I removed the rear badges/gunk left behind with it, I also remove stickers and such from motorcycles using it. |
#10 |
Member#: 288292
MAIC
Vehicle:2004 sti wrb. the blue one. |
Pressure washer
#11 |
Member#: 163604
3M citrus based adhesive remover and a microfiber cloth. Some auto parts stores have it, craft stores should carry it too.
#12 | |
Member#: 239452
MAIC
Vehicle:2010 Impreza WRX 1991 Prelude Si 4WS |
There are also several types of Goof Off that have varying contents of spirits/etc. I even think there's one with no spirits but with citrus oils, similar to Goo Gone which also does not have "harsh" mineral spirits. A lot of people on here confuse Goof Off with Goo Gone, with disastrous results. There was an image in the $10 taillight mod thread of one taillight that was eaten through with Goof Off. Taillights are usually made with much lower impact protection requirement, and thus much more compliant and low temperature thermoplastics, which are more susceptible to chemical attack. |
#13 |
Member#: 297778
MAIC
Vehicle:2005 OBXT |
Also try stoner's invisible glass cleaner. The stuff is awesome for cleaning glass, but i've also found it works really well at getting adhesive residue off--worth a shot.
#14 |
Member#: 45464
MAIC
Vehicle:91 E30 325i 95 E36 325is |
^^ this stuff has worked great removing a number of different bits of adhesives on a number of cars and other projects around the house I have had. I picked up a large can of it a while back and it has been worth every penny.
#15 | |
Member#: 149637
MAIC
Vehicle:2010 STI SE WRB |
WD40 is a water dispersing agent, it is not a lube. It actually gums up and dries out after a period of time. I wouldn't use it on anything. |
