#1 |
Member#: 319753
Vehicle:2002 wrx stage 2 psm |
So just shooting out a question, i have just under $1000 to spend right now on my car and im torn between two upgrades. I want to know what people out there would choose/see what comments people have on which would be recommended for my 2002 wrx
Option 1: Process West TMIC w/ splitter and hoses or Option 2: Tomei Extreme unequal length header w/ up pipe heat wrap etc... my engine mods right now are: custom made 3" turbo back (downpipe & catback) Turboxs bov Cobb short ram gimmick postmaf gimmick turbo inlet mishimoto silicon lower radiator hose walbro 255 fuel pump cobb accessport stage 2 stock turbo stock injectors stock headers stock uppipe stock intercooler I have not dyno'd it yet and i plan on it during the install of this next upgrade any negative comments please keep them to yourselves with the info given what would you do?
#2 |
Member#: 299368
Vehicle:2002 WRX WR Blue |
Should do the up pipe while you're at it. Quicker spool and save the turbo in the long run.
#3 |
Member#: 307879
Vehicle:2013 WRX Hatch SWP |
Now I'm no pro and just giving my opinion as you asked but I would go with choice number two with the UP. While the PW is a great piece, you won't benefit much from it while being in the stock turbo.
Again just my feedback Edit: once you go for an upgraded turbo then I say PW. |
#4 |
Member#: 319753
great, thanks. thats what others have recommended too and i see you point. anyone else?
#5 |
Member#: 328496
Deffinatly option 2 it'll be the best bang for u buck right now
#6 |
Member#: 263954
Vehicle:2008 STi Aspen White / Gold BBS |
None of the above. Get swaybars + endlinks.
#7 |
Member#: 319753
#8 |
Member#: 268190
TXIC
tomei header and up pipe!
#9 |
Member#: 154579
Vehicle:2002 WRX Wagon PSM - Sold |
Just the up pipe.
Then, spend some on your brakes and do the H6 rear up grade. I have to ask though, what are you goals for the car? |
#10 |
Member#: 302438
SWIC
Vehicle:10 WRX SS DMrally tuned! |
I vote the UP heat wrap and suspension bits. The reasoning is suspension parts make your car feel more fun, handle better, and are a long life upgrade that don't require tuning
#11 |
Member#: 198522
Vehicle:98 LGT Limited 10 Forester |
I would go with EL headers...i made 30 more whp and tq with them
#12 |
Member#: 133597
SCIC
#13 |
Member#: 248202
Vehicle:2013 WRX Sedan SWP |
Honestly at your power level your not going to benefit that much from an aftermarket exhaust manifold. If I were you I would screw the process west tmic and just find a lightly used Sti one and with the money you save from over paying for the process west find a cheap cat less up pipe and Sti injectors as well... Then turn up the boost a bit. Sti intercoolers can handle more power than your stock block can. You can achieve all of this with under a grand if you play your cards right.
Most importantly before adding anymore power make sure the upkeep on the vehicle is up to date. People who chose a new turbo over a timing belt are retarded. |
#14 |
Member#: 287000
Vehicle:05 LGT wagon 5mt |
I don't think either of those choices make much sense for your current setup ul headers are pretty much always a waste of money, el is the only bang for your buck, but those will push your powerband to the right and you already have a turbo that doesn't have much top end power. I'd say for $1000, get a used vf39, some sti injectors for $100, and an STI tmic... Then hope that you don't blow anything up. Btw, if you have that current setup without a real tune... You need to get one asap
#15 | |
Member#: 287000
#16 |
Member#: 284508
Vehicle:2011 wrx Silver |
save that money....
#17 |
Member#: 255776
Vehicle:2010 LR WRX MPS and PAR powered. |
At a minimum do your up pipe. Then do whatever mods you want.
#18 |
Member#: 112024
Vehicle:03 WRX vf34 wagon 6 spd, track & dd duty |
up pipe and some suspension/ brake upgrades
#19 |
Member#: 319753
wow thanks for all the advice guys ! yeah after some research im finding headers arent really worth all that money is if ANYTHING the grimmspeed cross pipe is a better bang for your buck then spending 700 on headers. i agree i do need an uppipe though so i definitely will have to get one. as for the suspension comments i see your point, the only suspension mod i have are coilovers, i got to up my game in the section
on another note my up keep is very good, i get it regularly checked and it runs very strong for a car made in 2002 and it has pretty low miles (80xxx) and it doesnt go up fast keep coming with the suggestions i like them! thanks again |
#20 |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
Sways and end links, fender braces and bushings. Your car now handles like a roller coaster.
Or the time tested classic: Hookers and blow... ~Evil |
#21 |
Member#: 263954
#22 |
Member#: 319753
do you really feel that much of a difference in sways and endlinks?
#23 |
Member#: 287000
Absolutely
#24 | |
Member#: 233501
That's what keeps the body of your car from rolling during turns A good 22mm sway bar won't ever do that. An upgraded sway bar will eventually kill the stock end links so that's where after market end links come into play. ~Evil |
#25 |
Member#: 70151
Vehicle:2011 WRX Limited Black |
Your car is over 10 years old, I'd be saving for repairs or replacement.
