Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 11-10-2012, 08:56 PM   #1
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
Default Roll-bar and sun roof delete
I have 2001 RS.
Finally test fitted my autopower race roll bar. I did specify that car has sun roof (I think, it was long time ago)
What are some of my options for delete if I can't make it work? I'm asking in this section because I'd like to take this car out on a road corse next year.
thanks for all the help
-slava
slava from goshen is offline   Reply With Quote
Old 11-11-2012, 02:09 PM   #2
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
So does it fit or does it not fit? You don't really say.
If you're looking to delete the sun roof, you can weld in a blanking plate. If you want to keep the roof, you could cut down the hoop and re-weld the mounting plates.
mykrrrr is offline   Reply With Quote
Old 11-11-2012, 03:06 PM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
Or you could do what I did and rivet a piece of aluminum down to the roof
Rokkit is offline   Reply With Quote
Old 11-12-2012, 07:19 PM   #4
slava from goshen
Member#: 152176
BRP/SRP
It didn't fit, but I didn't try making it fit yet either. I do want to delete all that, thought of a manual pop up option of some sort.
Want to stay away from welding at this point.
Old 11-12-2012, 07:20 PM   #5
slava from goshen
Member#: 152176
BRP/SRP
Rokkit, I like your rs. I want to flare mine but don't know what would be a good wheel size set-up. Don't want to go too heavy. Car will see auto-x and some track. Some weekend driving.
Old 11-13-2012, 10:32 AM   #6
tdrrally
Member#: 91562
1995 impreza,awd
reddish
what form of racing is that car set up for?
tdrrally is offline   Reply With Quote
Old 11-13-2012, 12:21 PM   #7
Rokkit
Member#: 84181
NASA #530 GTS2
I run a 245x40x17 Hoosier or goodyear (Road Race Compound) and I think I'm going to cut those 60mm s240 flares down to 30mm this winter. You could stuff a 275 under those 60mm flare easy.
I also run a +45 enkei with a 15mm spacer... so it's a bit of offset.
(just for some tire reference)
Old 11-13-2012, 01:30 PM   #8
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I just took the door from the moon roof assemble and bolted in down to the opening. There are studs on the door and body that you can use with a small bracket to hold the door in place.
Patrick L is offline   Reply With Quote
Old 11-13-2012, 09:14 PM   #9
slava from goshen
Member#: 152176
BRP/SRP
Patrick: you make brackets to hold the skin down?
I have no idea what type of racing it will be for. This car was swapped and built years ago, back when I was younger and a big dreamer. Now I just want to get it back on the road and enjoy it. Probably will auto-x and hope to go to gingerman raceway a few times.
Old 11-13-2012, 09:15 PM   #10
slava from goshen
Member#: 152176
BRP/SRP
I was thinking of 17x9.5 or 18x9.5 with low offset. Maybe +15 up to +30. With 255 or 265 tire for now.
Old 11-13-2012, 09:25 PM   #11
slava from goshen
Member#: 152176
BRP/SRP
Thinking of 240 flares or trying these:
http://www.aptuning.com/index.php?pa...mart&Itemid=14
Rokkit, how much cutting you do and did you weld in the rear?
Old 11-19-2012, 10:12 PM   #12
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
as far as I know most racing series won't let you have a functional moon/sun roof installed. It needs to be blocked off and disabled. So making a spec cage that fit with the moon roof would be odd.
Zefy is offline   Reply With Quote
Old 11-19-2012, 10:21 PM   #13
Rokkit
Member#: 84181
NASA #530 GTS2
Cut about 2" out of the rears, but mostly due to rust. Could get away with about an inch with the way it's lowered now. fronts are a totally different story though
Old 11-25-2012, 03:38 PM   #14
slava from goshen
Member#: 152176
BRP/SRP
What you do to front fenders? I just got an EF2 turbo for it
Old 11-25-2012, 03:38 PM   #15
slava from goshen
Member#: 152176
BRP/SRP
Maybe I'll get L roof and do roof scoop
