Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 03-19-2012, 12:47 AM   #76
Jondoe1980
Member#: 291697
2013 WRX STI Limited
Ice Silver Metallic
Thank you for your right ups, I learned a lot!
Jondoe1980 is offline   Reply With Quote
Old 04-08-2012, 02:29 PM   #77
sworn_enemy
Member#: 316134
2004 Impreza WRX
blue
Thank you very much! I have learned a lot too!
sworn_enemy is offline   Reply With Quote
Old 11-12-2012, 09:00 PM   #78
RBrady29
Member#: 254241
2005 wrx
hey great write up and pictures! i am using this thread for my own install, but i am having problems with removing my up pipe bolts. i have heated them and pb blasted them and i cannot seem to loosen them at all, also i am having issues with the down pipe because i removed all bolts and nuts and un hooked the exhaust and the down pipe still refuses to come off the turbo..... and yes I'm positive all bolts and nuts have been removed. any help would be greatly appreciated!
RBrady29 is offline   Reply With Quote
Old 11-12-2012, 11:00 PM   #79
robbyh
Member#: 326959
2004 wrx
black
Use a piece of pipe or longer ratchet to get more torque on the bolts that will break them free
And for the dp try a rubber mallet. Few wacks will pop the seal it has to the exhaust housing
robbyh is offline   Reply With Quote
Old 12-04-2012, 05:10 PM   #80
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Did it all work out?
Old 12-04-2012, 05:30 PM   #81
RBrady29
Member#: 254241
2005 wrx
Nope couldn't get it off, but i put it to the side until my new clutch comes. Plus i work at a performance garage and i got permission from on of the techs to go in on a weekend and he is gonna help me put everything on with the correct equipment. ill post some results when its all put together and tuned.
Old 12-08-2012, 07:11 PM   #82
droned23
Member#: 330606
2003 wrx
Looks sweet hope it runs well
droned23 is offline   Reply With Quote
Old 02-25-2013, 11:29 PM   #83
Smallhashbrown
Member#: 301335
2002 WRX Wagon
Default Turbo
How's the car holding up today with the turbo? I just bought vf48 and DW 565cc injectors. Going to use your write up for sure
Smallhashbrown is offline   Reply With Quote
Old 02-25-2013, 11:49 PM   #84
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Car's holding up great @ 301whp w/ original 5 speed transmission.
Good luck with the install.
Old 02-26-2013, 12:14 AM   #85
Smallhashbrown
Member#: 301335
2002 WRX Wagon
Thanks man! How many miles are you up to these days? I'm worried about my glassbox... What clutch you running?
Old 02-26-2013, 04:31 PM   #86
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
105k miles, roughly about 30k miles @ >280whp and 60k miles @ >220whp. You'd better stick with OEM clutch to be safe, which is what I have.
Old 02-26-2013, 05:50 PM   #87
Smallhashbrown
Member#: 301335
2002 WRX Wagon
Awesome! Thanks for the write up and info!
Old 04-03-2013, 08:53 AM   #88
SammyJankis
Member#: 339035
I just got my vf34 and pink injectors and I'm swapping everything onto my 03 wrx in early May. I was wondering if anyone could provide a list of small items that it would be beneficial to go ahead and replace while I have the turbo off. Hoses, clamps, etc. I want to make sure I get everything ordered/bought before I start the swap.
Also, how necessary is upgrading the turbo inlet hose? Is the Perrin worth the money or is the stock unit fine?
This write-up is awesome. Gave me the confidence to go ahead with the swap. Thanks!
SammyJankis is offline   Reply With Quote
Old 04-03-2013, 11:14 AM   #89
WMCCook29
Member#: 152685
2016 Forester XT
Upgrading the inlet is not necessary...however, the stock one becomes very brittle with age and if it cracks during the install you'll be SOL if you don't have a replacement on hand (stock or aftermarket). Personally, if I'm gonna end up replacing the inlet anyways I would rather spend a little bit more money on an aftermarket one.
WMCCook29 is offline   Reply With Quote
Old 04-03-2013, 11:40 AM   #90
crewfan
Member#: 351817
Would anyone recommend a jdm turbo?
crewfan is offline   Reply With Quote
Old 04-03-2013, 12:28 PM   #91
quazimoto
Member#: 70395
What do you think a VF34 is?
Old 04-03-2013, 02:05 PM   #92
SammyJankis
Member#: 339035
my '03 only has 50k miles...any way i can judge how weak the stock inlet might be?
Old 04-03-2013, 02:08 PM   #93
SammyJankis
Member#: 339035
there are lots of options for a turbo upgrade. depends on what model year your car is, STI or WRX, how much you wanna spend, how fast you want it to be, etc...the vf34 is a JDM turbo but a vf39 from an American market car would be fine as well. theres a great turbo sticky on here somewhere that explains all turbos for these little rockets. good luck.
Old 04-03-2013, 02:31 PM   #94
WMCCook29
Member#: 152685
2016 Forester XT
Unfortunately it's a roll of the dice kinda thing - if it's a DD I wouldn't risk it without a new inlet handy. If you can afford a few down days while you order a new one, then I don't see a problem with trying to save $$ and reuse the stock one.
Old 04-03-2013, 02:33 PM   #95
SammyJankis
Member#: 339035
rgr that. i have an alternate vehicle but im doing the injectors and fuel pump at the same time and then trying to drive to my tuner an hour away for some pro dyno time. might just order the part and if i dont need it return it....kinda dick i know but whatev
Old 04-03-2013, 05:05 PM   #96
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I'd recommend replacing stock inlet with upgraded hose (seen many stock hoses leak). I have the latest version from Perrin and found it to be very good in terms of fitment and quality. With stock hose off, it only took me 30 minutes to install the hose.
It's very important to spray hose with soapy water during install, which will make putting hose back much easier. I cut nipples off stock hose to make removal easier.
Old 04-05-2013, 12:37 AM   #97
jhayesvw
Member#: 326502
2003 WRX Wagon
I keep wondering if my car would be significantly quicker down low (3000-5000rpms) if I just went to some pink injectors and vf34.
I have a blouch td05 16gxt, STI TMIC, 3" cobb turbo back,grimmspeed uppipe, grimmspeed 3 port EBC, walbro in tank, FIC 1100cc injectors, K&N intake, 91 octane protune and E85 protune.
The problem is that I dont want to run E85 as its very inconvenient for me. So the 1100cc injectors are probably overkill and may be possibly costing me low end HP (I think).
So my question is where do you get boost to start and where do you get the full 16psi.
Your HP numbers are as high as I would want. I havent even dyno'd mine.
If my turbo is comparable to the vf34 and 39 then perhaps just the injectors should be changed out and retune?
jhayesvw is offline   Reply With Quote
Old 11-08-2014, 09:37 PM   #98
wrxdan1
Member#: 368576
2015 STI
CWP
Hey op is the vf34 turbo u have on right now the twin scroll one or is that a different one. I just found out my turbo is going out and ganna have to replace it soon. I had planned going with a vf39 and Sti pinks but this write up has me thinking otherwise lol. I'll be using this write up on either turbo I go with so thanks!
wrxdan1 is offline   Reply With Quote
Old 11-09-2014, 12:02 AM   #99
facingeast
Member#: 390995
2004 WRX
VF34 is a single-scroll roller-bearing design.
The twin scroll IHI turbos are:
VF36
VF37
VF38
VF42
If this was a twin scroll the up-pipe would have looked different, as would have the turbine housing.
facingeast is offline   Reply With Quote
Old 02-19-2015, 11:49 PM   #100
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
There is subtle difference in terms of performance between VF34 and 39. I'd go with VF39 since VF34 is hard to source and cost considerably more.
I am proud to say glass tranny is still holding up great.
Will a OEM Flywheel for a 2.5L fit on a 2.0L WRX? em199si Transmission (AT/MT) & Driveline 13 11-23-2010 08:23 AM
'05 2.0L WRX VF34 dyno results Acingteam Proven Power Bragging 17 01-07-2009 01:58 PM
Will coilpacks from 2.5L WRX or STI fit on 2.0L WRX? gopsu Service & Maintenance 7 10-08-2008 11:31 AM
2.0l wrx with vf34 kmt Proven Power Bragging 26 06-01-2007 11:36 PM
2.5L Oil Pan on 2.0L WRX theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-20-2006 09:02 AM
