Old 11-12-2012, 08:54 PM   #1
Ebal
Member#: 337115
Default 2003 wrx looses boost
I am experiencing problems with loosing boost towards 4500 rpm the car will go from 16.5 to 10 and hold at ten pounds any help would be appreciated thank you.
Ebal is offline   Reply With Quote
Old 11-12-2012, 09:19 PM   #2
jthatch12
Member#: 321715
03 Big 16G WRX
Normal . boost will taper down as you get closer to redline. My car hits peak(20 psi) at 3k and tapers down to 11 at redline
Old 11-12-2012, 09:23 PM   #3
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
^ i hope yours is tuned for that. as far as the taper it should hit 12 around 5600 and then to ten above 5800 rpms according to a stock wrx rom target boost map. do a boost leak test. some basic searches on here will help!
Old 11-12-2012, 09:26 PM   #4
jthatch12
Member#: 321715
03 Big 16G WRX
Of course I'm tuned for it! lol. My brother in law and I tune our scoobs ourselves. I'm currently at 231 whp and 244 ft/lb.
Old 11-12-2012, 09:36 PM   #5
Ebal
Member#: 337115
I am currently running the cobb stage 2 with catless exhaust and cobb ebcs
Old 11-12-2012, 09:37 PM   #6
Ebal
Member#: 337115
It was doing fine then all the sudden it started is it possible that it could be a exhaust leak per turbo?
Old 11-12-2012, 10:05 PM   #7
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
no boost leak post turbo pre engine is prob whats up! do a boost leak test and go from there! make sure no post maf leaks between the turbo and the maf as well. the turbo inlet is known to leak/rip
to jthatch12. thats it? my ej205 on 93 mad 250whp and 280wtq from my own personal tune. went to 280/315 on e85!
post back after you do the leak tests. its something everyone should do on there car once a year at the very least! my guess is there is a leak because that little of boost up top is not what the map calls for it i remember correctly
Old 11-12-2012, 10:10 PM   #8
Ebal
Member#: 337115
I have all new hoses coming tomorrow for my intercooler I already have a new turbo inlet Perrin what kind of boost leak can I do
Old 11-12-2012, 10:13 PM   #9
jthatch12
Member#: 321715
03 Big 16G WRX
On the TD04? I'd like to see some of your roms if you still have them around. I'm not done fully tuning yet, just hit a milestone
Old 11-12-2012, 10:16 PM   #10
Ebal
Member#: 337115
I also have a friend coming tomorrow with a vacum pump to check the wastegate
Old 11-13-2012, 06:10 PM   #11
Ebal
Member#: 337115
Ok so I had no idea of how to check for leaks I sea foamed my car and smoke come from the passenger side near the timing belt cover maybe lower than that near the header please help
Old 11-13-2012, 06:51 PM   #12
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Head-to-manifold gasket, or the up pipe gasket.
Travisty is offline   Reply With Quote
Old 11-13-2012, 07:22 PM   #13
Ebal
Member#: 337115
Would those gaskets just go out at once
Old 11-13-2012, 07:39 PM   #14
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Gaskets do fail with age, although it's rare. They're cheap and easy to do, so do them. Order some proper gaskets from some place like Rally Sport Direct, not some crap Ebay fiber things.
I always buy gaskets with a fire ring, and I suggest you do as well.
Old 11-13-2012, 08:39 PM   #15
Ebal
Member#: 337115
Got them ordered I will install in a few days I think that it is the pass side one cuz when I stand with the hood open and rev it has a small backfire it sounds like it is coming from there
Old 11-14-2012, 06:55 PM   #16
Ebal
Member#: 337115
Well I took the uppipe off and bam a gasket was missing a 1 inch chunk out of it
Old 11-14-2012, 07:20 PM   #17
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Curious how you are running Stage 2 tune with an EBCS as the EBCS is not supported for your tune. Unless yo are running a protune by cobb. Likely this is PART of your problem.
Old 11-14-2012, 08:19 PM   #18
Ebal
Member#: 337115
What would that do
Old 11-14-2012, 08:22 PM   #19
jthatch12
Member#: 321715
03 Big 16G WRX
^this
Old 11-14-2012, 08:28 PM   #20
Ebal
Member#: 337115
I know but why would it run fine then a few days later not have the consultancy and how could that have anything to do with a gasket.
Old 11-14-2012, 09:48 PM   #21
Ebal
Member#: 337115
Consisting
