Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 11-07-2012, 08:46 PM   #1
wInTeRfReAcK033
Member#: 331596
2002 Bugeye WRX
Fire engine red
Default Need Help!!! oil consumption
i have a 2002 wrx with 125000 miles. i seem to need to put a quart of oil in it about every 250 miles. i have no signs of leaks anywhere and took off my heat shield to find a small amount of oil residue on the inside. even so it is defiantly not enough to be going through a quart per 250 miles. please help. i have no clue where to begin.
wInTeRfReAcK033 is offline   Reply With Quote
Old 11-07-2012, 08:46 PM   #2
wInTeRfReAcK033
Member#: 331596
2002 Bugeye WRX
Fire engine red
bump.
Old 11-13-2012, 12:15 AM   #3
soberpoet
Member#: 264784
2003 WRX
Subaru Blue
first thing to check is pull the intercooler and see if theres any oil residue inside, there should be a slight film seeing as the td04l turbo is a journal bearing turbo.
if theres oil in the tmi continue to pull the downpipe to verify if your turbo is blown
if not perform a leakdown test on each cylinder, remove the oil cap and if you can feel air coming out of it you most likely have a ringland issue or piston rings could be letting oil into the cylinder
either way if you have a good turbo youre going to need to pull the motor for further diag
soberpoet is offline   Reply With Quote
