Old 11-09-2012, 01:52 AM   #1
Oliverklozov
Member#: 335793
2014 Wrx Hatch
Default Shaved vs. Rolled fenders
I just got a new wheel and tire set up for my 2009 wrx hatch and am having a problem with the tires rubbing on the fender lip. Just wondering what is better, shaving the fender lip or rolling the fender lip. Discuss!
Oliverklozov is offline   Reply With Quote
Old 11-09-2012, 02:04 AM   #2
shaving...done wrong, would be worse than a poor roll job
shaving would require proper priming/rust prevention
get wheels and tires that fit properly and dont do either
Old 11-09-2012, 02:05 AM   #3
sc00by4life
Member#: 97135
stupid question.
there is so much risk with shaving the fender, and if it isn't done properly.....will royally **** up the fender.
Old 11-09-2012, 02:14 PM   #4
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
1997 Legacy Outback EJ25
^ This is the best solution but if you are set on getting the wheels to fit, take it to a professional that will use an Eastwood Fender Roller, the correct amount of heat and enough patience to do it without the fender paint cracking. It should run you around $50-60 per corner for a roll and refinish. You may also want to look into an alignment before you start rolling. A bad roll can be fixed, where once things are cut off they are gone forever.
Improbus is offline   Reply With Quote
Old 11-10-2012, 12:39 PM   #5
WRXJohnny
Member#: 337122
Default roll for sure
I wouldn't attempt either. Buy of the two, go for the roll. But, expect to pay for refinish because the paint will surely crack.
WRXJohnny is offline   Reply With Quote
Old 11-10-2012, 12:57 PM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Surely, not necessarily. Risk is always there. Especially on the rear of the GH/GR Chassis Subarus.
Old 11-13-2012, 02:03 AM   #7
Oliverklozov
Member#: 335793
2014 Wrx Hatch
Rented an Eastwood roller for 20$ and rolled the fenders today with the help o my gf "womaning" the heat gun! Managed to roll the fender lip completely flat without cracking the paint what so ever!!! I am quite pleased with the job we did and surprised at how easy it was! I recommend this to anyone it's cheap and easy to do your self!
Old 11-16-2012, 06:59 PM   #8
mclaugks
Member#: 282911
where do you rent a roller?
mclaugks is offline   Reply With Quote
Old 11-16-2012, 07:01 PM   #9
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Google.
Old 11-16-2012, 07:08 PM   #10
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
1. Enjoy car and wait until your fenders are already rusty from age
2. Do whatever to make the wheels fit
3. Refinish/paint fenders
Unless you know what you are doing or you plan to pay a premium, don't do this and plan to have your fenders come out nicely. There is absolutely no way you will not disturb the integrity of your paint by stretching and bending the surface it is adhered to, even if it looks like you haven't!
Do not ever shave your fenders unless you have a very clearly thought out reason to. Shaved fenders loose their structure very easily and will be prone to bending/warping, even under normal conditions.
PlasticFoamMan is offline   Reply With Quote
Old 11-19-2012, 07:55 PM   #11
Ghostwhite
Member#: 254958
What he said, shaving is not worthwhile for a DD or street car.
Ghostwhite is online now   Reply With Quote
Old 11-25-2012, 05:30 PM   #12
fakechow
Member#: 338879
2002 Wrx
black
OMGHi2U roll on the dd
If this car is your daily then just go for the roll if your just looking for inner clearance but absolutely use a heat gun thoroughly before doing so to try and eliminate cracking of your paint. Plus you'll save your self headache and $$$$
fakechow is offline   Reply With Quote
Old 11-26-2012, 10:35 AM   #13
wrx316wichita
Member#: 325852
hacksaw and sharpie
wrx316wichita is offline   Reply With Quote
