Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 11-13-2012, 12:58 AM   #1
04SexTI
Member#: 278236
'06 sti
varies with the seasons
Default Can I lower boost with a MBC?
I have an 06 STI that I bought modded from the previous owner. It is currently tuned to 21 psi and uses a MBC for boost control. My question is, is it safe to turn the boost down to say about 18 psi by adjusting the MBC, or would I also need to get the car tuned again since the current tune is set to 21 psi?
04SexTI is offline   Reply With Quote
Old 11-13-2012, 01:48 AM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You'll be fine, just turning it down.
Old 11-13-2012, 02:12 AM   #3
OC_Nooby
Member#: 311781
2003 WRX w STI V8
lower away, it can only get safer.
OC_Nooby is online now   Reply With Quote
Old 11-13-2012, 03:00 AM   #4
04SexTI
Member#: 278236
'06 sti
Great, just what I was hoping for. Thanks for the help guys.
Old 11-13-2012, 09:02 AM   #5
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Depends on who tuned it.. In some cases tuners only do it for a small variance of 1-2 psi.... unless they tuned it for stages like 10,15,21 psi then you could hit AFR's that arent desirable as well as too much/too little timing.
Bamofo is offline   Reply With Quote
Old 11-13-2012, 11:47 AM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
This
Some tuners just set the car to target boost and get the car running correctly there, while the other parts of the table haven't been touched. Lowering the boost could throw you into an untuned region of your map, if so then anything could happen...too much timing, too little timing, too much fuel, too little fuel, etc.
If the car was tuned properly for all conditions up to and including the final target boost, then you'd be fine, but there's no guarantee that it was.
Old 11-13-2012, 02:10 PM   #7
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Originally Posted by the suicidal eggroll View Post
This
You guys are correct. Hopefully the tuner did tune the timing map but you wouldn't know until you looked at the map.
Old 11-13-2012, 08:12 PM   #8
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Just for the record: Tuners who don't tune for part-throttle suck at their job.
Cars that can't run safely at part-throttle are time bombs.
Old 11-13-2012, 09:37 PM   #9
Member#: 51961
2005 STi
2012 WRX
Indeed they do, but it happens...a lot
Old 11-14-2012, 12:17 AM   #10
NSFW
Member#: 140444
05 Stage Free LGT
I don't doubt it.
Old 11-14-2012, 07:00 PM   #11
Bamofo
Member#: 159743
07 STI Limited
Quarter throttle and full throttle with less boost are different stories though :-) whats fun is tuning the newer STI's and setting up different boost maps for I, S and S# then having to tune it all those times. But when its done... holy crap does it make it fun :-)
Old 11-15-2012, 05:55 AM   #12
NSFW
Member#: 140444
05 Stage Free LGT
How so?
If the ECU crosses through the same cells in the same tables, with the same MAF, same RPM, same load... what difference are you referring to?
Old 11-15-2012, 07:43 AM   #13
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
How so?
Full throttle for me is ~3.5 load, where quarter and half are significantly less...
Seems like it would make a difference to me.
Old 11-15-2012, 10:56 AM   #14
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I think what's being discussed here is whats the difference between lets say 2.5 load at full throttle with low boost, or 2.5 load high boost at partial throttle.
I personally havent noticed a measurable difference, but in theory the two conditions would be slightly different from one another (more heat and pumping loss at higher boost, lower throttle).
Old 11-15-2012, 03:01 PM   #15
Bamofo
Member#: 159743
07 STI Limited
If you turn down the boost say 2psi or 3psi to run it "safer" you might go from hitting the normal 3.5 down to a peak of 3 now. at half throttle you may only see the 2 load range... i think they are different in tuning... when i think of 1/4 thorttle i think of just barely in boost... my setup may be different then others but... that's all i ment. We are all agreeing here anyways. :-)
Old 11-15-2012, 05:53 PM   #16
04SexTI
Member#: 278236
'06 sti
Thank you guys for all the great information. I decided that I will just leave it alone for now use my foot to control the boost. Although, I will slightly be adjusting it lower since its getting colder, thus causing the boost to creep up slightly.
Old 11-16-2012, 12:13 AM   #17
NSFW
Member#: 140444
05 Stage Free LGT
Exactly.
Obviously if the load is different, that matters. That's not the point.
The point is that the very same boost levels (and the load cells) that you get at part-throttle can be achieved at WOT if you play with WGDC or an MBC. And I don't see why you'd need to retune for the difference.
If I remember right, WOT pulls at 30% throttle give me exactly the same boost as WOT pulls at 100% throttle and 0% WGDC. I actually did some experimentation to figure that out, because I figure it doesn't matter what the WGDC is boost levels lower than whatever you get with 0% WGDC, or at throttle levels lower that whatever it takes to make that much boost.
Old 11-16-2012, 07:52 AM   #18
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Wait... What?
Methinks this statement needs a revision.
Old 11-16-2012, 11:16 AM   #19
Member#: 51961
2005 STi
2012 WRX
*head explodes*
Old 11-16-2012, 11:34 AM   #20
jthatch12
Member#: 321715
03 Big 16G WRX
If I remember right, partial throttle and full throttle give me exactly the same amount of boost.....blah.. blah.. blah
that sounds better but still doesn't make sense lol
Old 11-19-2012, 03:37 AM   #21
NSFW
Member#: 140444
05 Stage Free LGT
WOT pulls at 30% is, um, wrong.
I just meant "pulls" at 30% throttle. Or, 30%OT pulls, I guess?
I got curious one day, and revised my DBW tables to cap them at progressively lower throttle openings until I got down to WG boost levels, and 30% was it. So with my foot to the floor, the throttle plate went to 30%, and I got 10 or 11 psi, which is the same boost I get with WOT (really WOT this time) and 0% WGDC.
That's with an ATP 3076 and the IWG and actuator that it came with. I'm sure it would vary with different turbos and WGs and WG springs.
Am I making sense yet?
