#1 |
Member#: 336712
Vehicle:2002 bugeye wrx silver |
When I bought my car this was the ad I saw. I don't know really what any if these are. Well some but most I don't. And was curious if these were some nice upgrades in my 02 wrx. Thank you.
Subaru security upgrade Pioneer DEH-P7000BT BlueTooth Receiver (phone and audio BlueTooth) Whiteline Group 4 Coilovers (adjustable in height via strut body, bump & rebound via knob) STI Strut Top Mounts Whiteline Steering Rack Bushings Turn-in Concepts Rear Diff Bushings Turn-in Concepts Outrigger Bushings Turn-in Concepts Fender Braces Turn-in Concepts Shifter Bushings Perrin Adjustable Rear Sway Bar Energy Suspension rear sway bar urethane bushings Perrin End-Links Cusco Rear Strut Tower Bar with V-Brace STI Engine Mount Bushings K&N Air Filter Turbo-XS 2" Stainless Turbo Back Exhaust PDE Flex Up-pipe Kartboy Exhaust Hangers Kartboy Short Shifter Kartboy Shift Knob Enkei RPF1 17x7.5 Wheels Custom Aluminum Centering Rings/Spacers Pirelli P Zero Nero Tires StopTech Braided Brake Lines SpeedBleeders Greddy, Peek/Hold/Warn Boost Gauge (silver) Cobb Tuning Access Port -- Stage 2 Map Loaded ABS Switch Mod Fog Light with High Beams on Mod EGT (catless) resistor mod Grounding Mod New Windshield (Oct 2012) New Clutch (Jan 2010) AND ALSO : can anyone tell me if this will fit my wrx. The picture says Sti I have no idea why but if anyone could let me know I'd appreciate it a bunch! http://item.mobileweb.ebay.com/viewi...d=170642337256
#2 |
Member#: 228784
MWSOC
Vehicle:2004 wrx black, stage 2+ |
The decription for that lip says wrx, so yes it will fit a wrx. there is no 02-03 sti in the united states.
So why did you buy a used, modified car when you had no idea what the modifications were? Which leads me to believe you don't really know the condition of the car? |
#3 | |
Member#: 336712
#4 |
Member#: 248761
MWSOC
Vehicle:98 Legacy Doomwagn JDM ej205 swap |
Pretty good list. Looks like they focused mired on handling than power. Chances are your tXS 2inch turbo back exhaust, is actually a 3 inch TBE.
Hopefully there is some sort of tune on it. |
#5 | |
Member#: 336712
And stock tires/rims and winters also. And summers. And yes mostly handling mods Pretty sure it's tuned.. He said it was |
#6 |
Member#: 332887
Tri-State
Vehicle:2012 WRX stage 2+ DGM (sedan) |
70% of the mods you listed are for handling. Are there any specific mods you had questions about (i.e. location, purpose, etc etc)?
#7 |
Member#: 228784
MWSOC
what do you mean by a drunk boost gauge? its not acting right? If so, how sure are you that its the gauge and not the car/actual boost?
There is a tune, says stage2 tune loaded. Everything looks well done. Any questions on specific things? |
#8 | |
Member#: 336712
Only 77k miles also And the boost gauge would say I'm boosting while I'm in neutral barely accelerating. Or just starting from a stop sign its saying I'm boosting. |
#9 | |
n00b Moderator
Moderator Member#: 140114
MAIC
Vehicle:06 18G Semi Built SGM WRX |
OP did you have the car inspected at all? That would have been the FIRST thing to do, especially when buying modded. Luckily most items listed are handling and no mods are out of Stage 2 parameters except the intake. (And depending on how old the tune is from Cobb, it may actually be when Cobb supported K&N) One thing that I see that I would be suspect is is the "custom" wheel spacers. Essentially any wheel spacer used on these cars are bad UNLESS (well not unless, but this helps majorly) the wheel studs are the extended model. This is for insuring that enough thread grip length is present for the lug nuts. How do you know if you have extended lugs? Well without asking the previous owner, you'd kinda have to guess without taking a few things apart. |
#10 | |
Member#: 336712
And is that good at supported but k&n? Not sure how old the tune is The vehicle was also the guys daily driver until the day I bought it so I'm sure It would pass no problem but good point. |
#11 |
n00b Moderator
MAIC
I would either go get a pro/e-tune or find a stock intake and put it on. Even when it was a "supported" intake by Cobb it didn't exactly mean the tune was changed enough.
And you MIGHT need the spacers depending on the offset (not mentioned) of the wheel. If you're having the tires put on professionally, have them figure out if you need the spacers. My guess is no. |
#12 |
Member#: 336712
Yes the guy doing the tires is pro. He's going to do a general look around of the car up on the lift and tell me what he thinks.
Old owner also said I won't need spacers on the winters. |
#13 | |
Member#: 23676
NESIC
Vehicle:. |
A few notes, mostly personal opinion based on facts. I don't care for K&N filters. They give zero power, because the restriction is the stock airbox, and they don't filter as well as a paper element. I am a Kenwood man, so I don't like the Pioneer HU ![]() And yes that lip should work fine. |
#14 | |
Member#: 336712
And the radio is a pain the neck to figure out but I got Bluetooth a little speaker thing above my steering wheel pretty cool I guess. But it works nice haha. And thanks for the opinions this thing does hug the road very well. Really loving it And also even though I don't know much about cars with all these extras and the shape it's In. You can't give up a deal like that. I've always wanted a wrx too. Since I saw it on "top gear" Last edited by lvlatthew; 11-13-2012 at 01:27 PM. |
#15 |
Member#: 276209
MWSOC
Vehicle:I am Rub Function>Form |
Personally I'd never purchase a modified car unless I knew the owner well. As far as this one goes like everyone else mentioned almost everything on that list is suspension tid bits. In my eyes this is a good thing because most people that don't know how to mod a car correctly try to buy a bunch of go fast parts (usually cheap knock offs) and then drive the piss out of it sometimes untuned (or with a crappy one at best). The fact that the previous owner invested a fair amount of time/money on suspensions leads me to believe that he has an actual understanding of the car and focused on what could make it more enjoyable to drive.
#16 | |
Member#: 336712
#17 |
Member#: 194655
NWIC
Vehicle:08 STI White |
I like the list of mods. How about an ETS top mount intercooler on a great holiday sale price?
#18 | |
Member#: 336712
#19 |
Member#: 332887
Tri-State
oh boy... the vendor, ETS, is talking about a top-mount intercooler (aka TMIC). Ask the old geezer if he changed his or kept it stock before selling it to you
#20 | |
Member#: 336712
Stupid question. But is that what like cools the car? So far I've had no high temperature issues at all. Just saying Last edited by lvlatthew; 11-13-2012 at 02:41 PM. |
#21 |
Member#: 336712
Just found out that the intercooler is stock. Should I upgrade that?
#22 |
n00b Moderator
MAIC
That would be up to you.
#23 | |
Member#: 336712
And tbh not even quite sure what an Intercooler does. I'd assume cool down the motor but doesn't the radiator dothat? |
#24 |
Member#: 332887
Tri-State
A new TMIC would be able to provide colder air to the turbo, but may be more prone to heatsoak than your stock one. Getting a turbo blanket and/or heat tape would help TMIC heatsoak or you could just use a FMIC to avoid it altogether.
#25 |
n00b Moderator
MAIC
