Old 11-12-2012, 04:07 PM   #226
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Originally Posted by jthatch12 View Post
Question, my FTDI cable from that website that z recommended, will it work directly out of box?
Boy is the shipping slow... Its just leaving Hong Kong today... I ordered it on the 23rd
Originally Posted by Guardian-X- View Post
Worked flawlessly for me right out the box (06sti). Haven't gotten to flashing but everything else works flawlessy (romraider,learning view etc) only reason i can't read my rom is due to the ecutek tune (lockout) on it so i presume you can do about anything with this cable without modification. I presume Z has already flashed with this cable without mods (have to check previous pages).
Expect at least 3 weeks shipping.
Can't help mate sorry ... i gave up on the WCH cable after the voltage mods and bought the FTDI one which has no problems straight out of the box. I don't really know if the WCH cable is of more use on the older ecu's or if the mod's actually make it work.
Yep, flashed the updated STi map with the dx cable right out of the box. I didn't even try messing with any mods on the WCH based cable because I knew I had the second cable coming from China and was hoping that would work.
Mine was on an 04 STi ECU though, so the cable from DX worked out of the box, but i'm not sure if the voltage mod is necessary from a 16 bit ecu (02-03 wrx)
I would say try it out of the box to see if you can "read UCU" with ecuFlash. (green flash cables connected under the dash), if it doesn't, then go for the voltage mod
z is offline   Reply With Quote
Old 11-13-2012, 03:27 PM   #227
jthatch12
Member#: 321715
03 Big 16G WRX
Go my cable today, learning view works excellent! Haven't tried ecuflash yet.
Old 11-13-2012, 04:51 PM   #228
z
Member#: 41762
04 STi
Sweet! If LV worked, I assume you got an FTDI cable and you should be good to go with EcuFlash.
... and 3 weeks exactly since you posted that you had ordered!
Old 11-13-2012, 05:03 PM   #229
jthatch12
Member#: 321715
03 Big 16G WRX
Yep 3 weeks lol. I'm still having issues with WOT logging in rom raider. I'm starting to think its interference issues. I'm going to get a ferrite core for the cable to cut back on noise
Edit: Got a pair of ferrite cores from radio shack today. It solved my rom raider logger cutout issue. So I'm all set now!
Old 11-15-2012, 09:48 PM   #230
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
FYI to all- the cable from amazon i linked on the previous page arrived today.
Drum roll please...
FTDI cable for $7.80
mechatricity is offline   Reply With Quote
Old 11-20-2012, 01:47 PM   #231
soberpoet
Member#: 264784
2003 WRX
Subaru Blue
hey everyone just wanted to let you all know i have successfuly read rom image from an 06 wrx using ecuflash version 1.28 and vag-com cable
here is my setup i used
ecuflash version1.28
vag-com cable and drivers
romraider ecuedit
windows 7 starter
first thing i did was install the FTDI drivers for the vag-com cable
installed vag-com program
i assigned the virtual serial port to com2
opened vag-com program and with cable plugged into vehicle
tested cable interface Note: if you have issues with getting a successful interface connections install drivers manually there are 2 drivers that need to be installed i have a pdf that gives you step by step directions by this route
once a successful interface connection is made i installed ecuflash v1.28 Note: do not install openport drivers, they will conflict with the FTDI drivers, just hit cancel
on 06wrx connect test mode connector (green connector under dash)
turn car to run position
plug in vag-com cable to car and computer
run ecuflash
select com2
you should then be able to read the rom image from ecu
be sure not to open or close any doors of the vehicle as this will interupt the process and it will fail to read
after its finished reading save the hex file but be sure to put ".hex" after whatever you name it or you wont be able to open it
and thats it i havent tried flashing it yet that is my next step
if anyone wants the pdf install instructions pm me and ill message it to you any other questions on my setup feel free to ask
happy tuning!!
soberpoet is offline   Reply With Quote
Old 11-20-2012, 03:07 PM   #232
soberpoet
Member#: 264784
2003 WRX
Subaru Blue
flash worked perfectly
Old 11-26-2012, 12:28 AM   #233
TripleEight
Member#: 338168
2006 WRX TR
CGM
2006 WRX
EcuFlash 1.28
VAG-COM ebay cable, (Silver Cable, Blue Connector)
FTDI Drivers from ftdichip.com
RomRaider
Windows Vista 64 bit
-I cant get the VAG-COM program from the CD to work at all, it wont install properly, maybe because my computer is 64 bit.
-I was able to install VCDS-Lite but it isnt recognizing the cable. When I hit test for COM1 it says "Port status OK, Interface not found." Maybe I need to plug it into the car for it to see the interface?
-After the ECU flash install I got an error that said "You have to run the 64 bit version of DPinst.exe on this machine."
-I was able to install the FTDI drivers manually so hopefully this error wont matter.
-EcuFlash is seeing my cable (COM1).
It's dark out right now so tommorrow when I have some daylight I'll try to read from ECU. If it works I'll go forth with trying to delete some CEL codes caused by the stupid secondary air injection system. If it doesnt work I'll try a 32 bit Win7 VM.
TripleEight is offline   Reply With Quote
Old 11-26-2012, 03:34 PM   #234
TripleEight
Member#: 338168
2006 WRX TR
CGM
Success!!!!!!!
I was able to read from ECU in ECU flash 1.28. Made a copy of the file and turned off my secondary air injection codes with RomRaider. And I was able to write to ECU! I used Windows Vista 64 bit. Yay, no more CEL, and I can use my cruise control now.
I wasnt able to use the VAG-COM program that was on the CD. VCDS-lite may have worked but I didnt even try it.
I had trouble with the silver cable at one point so I gave up on it and started using a blue cable. The blue one appears to have a different looking chip in it, and it had a blue LED that lit up when plugged into the car. The silver cable had a red LED that lit up at all times when plugged into the computer. Also, the silver cable came with drivers that appeared to be different. The drivers for the blue cable appeared to be pretty much the same as the ones on the FTDIchip site.
I followed soberpoet's directions almost exactly. THANK YOU soberpoet!!!
Tip: In device manager, set bits per second to 4800. Also, run all of the programs as administrator. I ran EcuFlash in compatability mode for XP. Not sure if that was needed but it did work so I didnt even try it without doing that.
For reference-
Driver Provider:FTDI
Driver Version: 2.8.24.0
Old 11-26-2012, 03:53 PM   #235
z
Member#: 41762
04 STi
Originally Posted by TripleEight View Post
2006 WRX
EcuFlash 1.28
RomRaider
You don't need to run that program that comes with the cable. You need ecuFlash and/or RomRaider
Old 11-27-2012, 05:06 PM   #236
soberpoet
Member#: 264784
2003 WRX
Subaru Blue
i found the link for installation guides for the FTDI drivers here: http://www.ftdichip.com/Support/Docu...tallGuides.htm
step by step instructions helped me out a lot
also for those of you who also want to use your computer as a scan tool i found a knock off version of subaru select monitor
does everything the dealer can do and works flawlessly with the vag-com cable
Note: plug cable into vehicle and your computer before running the software or the com port wont show up
http://www.softpedia.com/get/System/.../FreeSSM.shtml
with this you will now have a flash tool and subaru scanner ultimate tool
enjoy!!
also im using the blue vag-com cable that i bought from amazon here:
Amazon.com: link live the last version USB Obd2 Obd-ii VAG KKL Cable for 409.1 VAG-COM VAG 409 Audi Vw Skoda seat: ElectronicsAmazon.com: link live the last version USB Obd2 Obd-ii VAG KKL Cable for 409.1 VAG-COM VAG 409 Audi Vw Skoda seat: Electronics
the program on the cd only works with volkswagon/audi
Old 11-27-2012, 08:56 PM   #237
TripleEight
Member#: 338168
2006 WRX TR
CGM
Here is the $10 cable that worked for me. http://www.ebay.com/itm/VAG-COM-OBD-...item416d6f0e51
Ebay Seller: etopmarket
Lol, when it finally worked I was so happy I didnt have to dish out $600 for an AccessPort, or even $200 for a Tactrix cable. I cant wait to get my TBE, and K&N filter this weekend. I'm planning on going with XPT's stage 2 tune.
Old 02-19-2013, 12:48 AM   #238
mstkenny04
Member#: 261358
2015 STI
World Rally Blue
do they make one for 08+ models?? Like the 2.0 tactrix.. pm me
mstkenny04 is offline   Reply With Quote
Old 03-12-2013, 04:48 AM   #239
Dori Ninja
Member#: 73974
04 RSTi
anyone using this on Linux?? i have a set up in mind but it will have to run linux....
i have an 06 wrx set up
Dori Ninja is offline   Reply With Quote
Old 03-15-2013, 07:50 AM   #240
WR-ex
Member#: 314348
2002 WRX Bugeye
so i just ordered an all blue KKL vag-com cable...My 02 has a prodrive y pipe and exhaust (not sure if factory). Does this mean i may have ecuTec?
It would suck if thats the case...will update when it gets here
WR-ex is offline   Reply With Quote
Old 03-31-2013, 12:51 PM   #241
WRXGOBerserk
Member#: 328413
2004 Impreza WRX
Just bought a VAG-COM for my 04. Did my best research, asked around, and apparently my model is plug-and-go so no chip modification or searching for old ECUFlash versions (from what I've determined).
Will def. need some help when it shows up, but I'm confident. Going to take a Stg2 map from ROMRaider forums and get rid of this AP.
Will update in a few days when it arrives
WRXGOBerserk is offline   Reply With Quote
Old 04-15-2013, 04:11 PM   #242
WRXGOBerserk
Member#: 328413
2004 Impreza WRX
So I'm trying to read my ECU with my VAG-COM
Tried the newest version of ECUFlash (1.4 something) and I'm getting a "Unable to connect to vehicle interface". All test mode connectors are set, and the flash jump block is plugged in.
Click "Read from ECU" then pick my vehicle from the list, click "Read" and get the error.
I just put my stock map back on. I'm going to try to use an older version of ECUFlash (1.29) and see if that works.
EDIT: OK so I installed ECUFlash 1.29 and I think I got it to read my stock map..
Now I tried to test write to the ECU and when it was finished a dialog box popped up basically telling me if I was finished to disconnect the green test connectors.
I then tried to flash a map to the ECU and kept getting the "Voltage is out of range" and that it's 4.32. I turned on my lights, my AC, my rear defroster AND had the jump block in and it still tells me the voltage is low.
Any ideas?
Old 04-15-2013, 05:13 PM   #243
BrokenWrench
Member#: 345289
2005 OBS
I've torn this thread apart and am having a hard time seeing if anyone has successfully used the Ross-Tech cable (mine is a Key-USB) with any of the software in the thread. I got ecuExplorer to recognize the cable in the lower right hand corner, but won't read my DTC's or connect with the car.
Also, I am not sure how many of you have used VCDS, but it is amazing and I was wondering if anyone has made something close to it that works with a Subaru. I'd like to set readiness and it worked like a charm on my Jetta.
BrokenWrench is offline   Reply With Quote
Old 04-15-2013, 07:42 PM   #244
WRXGOBerserk
Member#: 328413
2004 Impreza WRX
Update from my post above ^
Still couldn't fix the voltage problem.. So I re-flashed, using my Cobb AP, to my old Cobb Stg2 map and got a voltage error. Turn on my lights and AC, and it worked.
WTF!
Old 04-25-2013, 11:08 AM   #245
japanesestar
Member#: 212037
2005 wrx sedan
black
I hope that pic works. I used the pic from another thread. I do not own the photo. This is what I did to fix the low voltage problem.
japanesestar is offline   Reply With Quote
Old 04-25-2013, 12:42 PM   #246
WRXGOBerserk
Member#: 328413
2004 Impreza WRX
Really? Even with a 2004-2005? I thought you only had to mod the 02-03 cables to flash? I'll give it a try. You had to jump your jumper plug under the dash as well then, yes?
Old 04-25-2013, 01:01 PM   #247
japanesestar
Member#: 212037
2005 wrx sedan
black
Redundant reply .....yes I did.
Old 05-09-2013, 08:55 PM   #248
Dori Ninja
Member#: 73974
04 RSTi
so running with my 06 WRX motor i can log...dont get anything from romraider ecu editor though...i dont know what im doing and dont want to try to tune, just looking around...but i would like to set me launch control cause that sounds simple enough...but i cant get my ECUFlash 1.28 i downloaded to work...anyone have a known good file for me to download?? im also not runnign XP but Win 7 32bit...can i use that or no?? see couple ppl having sucess...really i want to be able to re flash on my own so i can get my big power map made and still have my safe map availible cause i cant get 93 everywhere and dont wanna be stuck some where.... :/
Old 05-09-2013, 09:50 PM   #249
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Use a newer version of ecuflash.
Old 05-09-2013, 10:00 PM   #250
Dori Ninja
Member#: 73974
04 RSTi
Ppl were saying u needed the older version for the 06+...
I Got VAG-COM cable and I need help!!!!! subi-bartimioli02 Open Source Reflashes 148 06-24-2015 08:36 PM
WTB Service: Get my Vag Com cable to work el dude MAIC Private Classifieds 3 10-04-2009 08:25 PM
Anyone in Phila. willing to share their Tactrix or vag-com cable? eek1 Tri-State Area Forum 4 09-12-2009 04:32 PM
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 12:35 AM
VAG-COM cable btlegacy Open Source Reflashes 4 05-31-2009 07:10 PM
