#26 | |
Member#: 52726
#27 |
Member#: 320594
NESIC
Vehicle:2012 Impreza Limited Dark Gray Metallic |
#28 |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
#29 |
Member#: 52726
#30 |
Member#: 52726
#31 | |
Member#: 313093
VIC
#32 |
Member#: 293678
Vehicle:2012 Impreza 2.0i 5 Door Limited. Silver |
Newbie question: I know if you don't install TPMS on your winter tire/wheel setup, you get the light on the dashboard. But what happens when you install your summer tire/wheel setup after a few months, when winter is over? Will the light on the dashboard not light up like normal, or since the wheels/tire haven't been on for a while you have to "reset" something?
#33 |
Member#: 313093
VIC
The TPMS light will turn off once you have your OEM rims and tires with TPMS mounted again. I haven't had to "reset" anything yet.
#34 |
Member#: 318622
Vehicle:2012 Impreza |
What's the offset of these Tirerack wheels? The rear looks like a space saver spare. Does these wheels need hub rings?
#35 |
Member#: 52726
Offset on these is 50mm. So only 2mm difference. Reason they look weird is probably because tires are 195/60/16.
I really hate doing tirerack job and free advertising since they really messed up my wheels. Every single one came scratched up. I imagine they have monkeys mounting tires Ha! Amazon sells the same for cheaper. But last time I checked no winter tires and no free mounting. They will ship for free though. If I could do it again I would get them from amazon. I am really mad about all the scratches. |
#36 | |
Member#: 320594
NESIC
#37 |
Member#: 52726
Two years ago they just left tires on my porch even though I have sign "do not leave packages here" I don't live in bad area but packages get "lost" So this year I went to distribution center to pick it up myself.
#38 | |
Member#: 293678
However, if your state requires you to have TPMS, then you need them regardless of who does installation. I live in Missouri so TPMS is not required to pass inspection, but for the states who require them, just place your summer tires on. I have never heard anyone getting a ticket for not having TPMS installed. |
#39 | |
Member#: 320594
NESIC
#40 | |
Member#: 313093
VIC
#41 |
Member#: 52726
True and I don't mind doing that especially when wheels are on the car for some time. You are bound to collect some scratches. But to have them look all scratched up BEFORE you even put them on blows my mind.
#42 | |
Member#: 308400
Tri-State
Vehicle:2012 Imp Sport Pr. Dark Gray Metallic |
-Brian |
#43 |
Member#: 52726
I would if they were aluminum rims. Thanks for advice nonetheless
#44 | |
Member#: 308400
Tri-State
#45 |
Member#: 312236
Vehicle:12 Imp Sport black 12 Imp Prm sdn DGM-wife's |
Bump.
Anyone else have steelies on their '12 or '13 Impreza? I'm thinking about getting some for my '12 Sport and wondering if anyone has a black set on their black Sport and could graciously provide pics? |
#46 |
Member#: 333446
NESIC
Vehicle:2013 Impreza SL CVT DGM |
if I go with steel wheels I'm thinking of getting black covers for the wheels. I like to try to protect the hub and lugs a little bit from extra snow/salt/ice if possible.
#47 |
Member#: 308400
Tri-State
#48 |
Member#: 312236
This might be a total n00b question, but when you say "OEM steelies" do you just mean the size? Or did you actually get these from Subaru? I'm presuming that they didn't come with your car since it looks like you have a Sport... And if you don't mind me asking, what are the size specs and how much did you pay for them?
Tirerack has a set of 16x6.5 for $58 each. I'm wondering if I can get some cheaper somehow... |
#49 |
Member#: 89967
NESIC
Vehicle:2012 Impreza Sport DGM |
I got a set of WRX wheels for mine with winter tires already on them for about $500 from a member on here. That's another option for some
#50 |
Member#: 333446
NESIC
