Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 11-12-2012, 04:34 PM   #1
pshwag
Member#: 198497
2002 wrx sedan
black
Default Average coolant temp 208-210 Is this bad!!??
I have a 02 wrx in the process of getting a stage 2 e-tune. I recently did my timing belt, water pump, and thermostat before tuning and have re-bled the coolant system to check for air.
My car will run around 208 while driving normally and while driving agressively. The only time the temp goes down is after a hard pull it will fall to around 185.
Any advice on getting my temps under 200 would be greatly appreciated!
I would rather not replace my new water pump and/or thermostat btw...
Mods: Catless TBE and uppipe, STI FMIC, GM BCS, AEM CAI, BOV...
pshwag is offline   Reply With Quote
Old 11-12-2012, 05:02 PM   #2
pshwag
Member#: 198497
2002 wrx sedan
black
Also no noticeable coolant leaks and fans seem to be working!
Old 11-12-2012, 08:43 PM   #3
Ebal
Member#: 337115
My 2003 wrx stays at186 at all times
Ebal is offline   Reply With Quote
Old 11-12-2012, 09:09 PM   #4
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
mine is around high 180's to low 190's average driving around town. after i do a pull and then come to a stop or in stop/go traffic it will climb. try bleeding any more air out of the system. take the top radiator cap off and squeeze the upper radiator hose with the car running. seems a bit high for a brand new thermostat
WhiteBgeye02 is offline   Reply With Quote
Old 11-12-2012, 10:19 PM   #5
emjp4
Member#: 290926
2005 WRX
This. Your symptoms sound a lot like air in the system OR you bought a faulty thermostat (unlikely).
emjp4 is offline   Reply With Quote
Old 11-12-2012, 10:46 PM   #6
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
You may also have a slightly blocked radiator.
But as said before, try to re burp it first as that is the cheapest fix.
recce02 is offline   Reply With Quote
Old 11-12-2012, 10:56 PM   #7
pshwag
Member#: 198497
2002 wrx sedan
black
I'll try and bleed it again. These things are a pain to fill so ill see what happens.
What do you mean it could be blocked? As in it could be clogged? It feels like it runs the same as it did before I changed the thermostat, but idk if I would notice a 15-20 degree temp change.
Old 11-13-2012, 02:55 AM   #8
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
The blocked radiator comment was just a possibility. If by chance your rad is stock, there is a possibility that some of the rows in the core have built up some sort of deposits and clogged them up. If you re burp the system and you are still having higher temps, I would look into the radiator next.
How did your old water pump look? Any sort of calcium deposits on the fins or passages?
Not trying to scare ya, just giving you another thing to look at if everything else is ok.
Old 11-13-2012, 10:45 AM   #9
pshwag
Member#: 198497
2002 wrx sedan
black
Yea the old water pump looked fine. I couldnt comment on the coolant though because i drained it into a dirty oil pan.
I guess i wouldnt mind getting a shiny new radiator even if its not the problem!
Old 11-13-2012, 05:35 PM   #10
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
If you want it to run cooler, get a cooler thermostat :P
Grimspeed 160 degree works great, is just as beefy as the stock one, and takes like 5 minutes to install after you drain the coolant.
With the grimspeed thermostat my car runs about 170-190.
simon021 is offline   Reply With Quote
Old 11-13-2012, 06:34 PM   #11
pshwag
Member#: 198497
2002 wrx sedan
black
Yea I suppose if i get a new radiator I would change it out.
How bad is it to run ~20 degrees hotter than usual?
I would prefer to finish tuning the car and then do the radiator etc. after christmas...
Old 11-13-2012, 08:03 PM   #12
LatentWagen
Member#: 50315
0508 Saabaru & specB
Stage: Maintenance
Go with a stock thermostat. My GS thermostat stuck 95% closed, causing what could've been a fatal over-heat.
LatentWagen is offline   Reply With Quote
Old 11-13-2012, 08:10 PM   #13
simon021
Member#: 157532
2002 MY03 EJ207 E85
What did grimmspeed say about that? Considering it's supposed to fail Open that's pretty serious.
Old 11-14-2012, 09:54 AM   #14
dacib
Member#: 307828
Get a Mishimoto radiator or any all aluminum 2 core ones, you temp will go down.
dacib is offline   Reply With Quote
Old 11-14-2012, 10:16 AM   #15
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
do not get the GS thermostat to solve the problem! get a new radiator or do a coolant flush of the system esp the radiator itself.
Old 11-14-2012, 10:34 AM   #16
pshwag
Member#: 198497
2002 wrx sedan
black
I will probably replace with a new stock thermostat again... and get a new radiator.
Can anyone comment on whether or not I can wait until after the tune is complete to do this?
Would I be able to get more power out of the tune with the cooler temps?
Old 11-14-2012, 11:00 AM   #17
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well since optimal is 185 then it might start pulling timing in the ecu if the coolant temps get to high. just have the tuner log coolant temp to make sure its not going through the roof. your thermostat is prob fine. try the radiator first. coolant is cheap!
Old 11-14-2012, 11:11 AM   #18
pshwag
Member#: 198497
2002 wrx sedan
black
Ok Thanks! Coolant is cheap, but a new radiator isnt
Old 11-14-2012, 10:14 PM   #19
LatentWagen
Member#: 50315
Stage: Maintenance
There was no harm done; what would they do? I'll skip the discount
It failed because the spring valve came "off track" at an angle, if you can picture that. The only thing that saved me and enabled me to limp home (30 seconds on, 5 min off works well) was the fact that it was cracked open because of the angle it was at. I take it as a learning experience, and don't mess with low-end parts in important places anymore. GrimmSpeed heat shield, check. Parachute straps, I'll pass
Old 11-15-2012, 12:00 AM   #20
amroof
Member#: 211224
2005 Mystical
UniCorn FXTi
I think my mishimoto was like 150 shipped from a vendor on here. Also check your radiator caps as well.
amroof is offline   Reply With Quote
Old 11-15-2012, 11:46 AM   #21
pshwag
Member#: 198497
2002 wrx sedan
black
I only have the one since its an 02 but I replaced it when i went to bleed the coolant for the second time!
