Mid Atlantic Impreza Club
Old 11-12-2012, 05:49 PM   #1
Wumpus02
Member#: 250233
2002 WRX Wagon
Default Anyone on the MD/PA/DE border able to help?
Looks like I'll be needing to drop the trans in my '02 WRX I unfortunately do not have a garage to work in nor the tools or know how really to perform a job like this. I was hoping someone in the area wouldn't mind lending their knowledge, tools, and garage to a Subie owner in need.
I'm not sure but I think I need to replace the throw out bearing.
Wumpus02 is offline   Reply With Quote
Old 11-12-2012, 08:57 PM   #2
Tut4u2
Member#: 40424
05 STi
I like in Philly by KOP if you want to make the drive.
Tut4u2 is offline   Reply With Quote
Old 11-12-2012, 11:32 PM   #3
Wumpus02
Member#: 250233
2002 WRX Wagon
I'll keep you in mind, though I'm looking for something a bit closer to me. The car needs to be towed. Unless I can rent a roll on trailer.
PS I'm in Elkton, MD
Old 11-12-2012, 11:36 PM   #4
ChefRacer
Member#: 287000
05 LGT wagon 5mt
I might be able to come down and help if you could throw me some gas money after I put my own trans back in
ChefRacer is offline   Reply With Quote
Old 11-13-2012, 02:21 AM   #5
Rymaster
Member#: 296277
2002 Impreza WRX
I've personally never dropped a subie trans but i wouldn't mind lending a hand if you guys end up doing this on a day I'm available. I could bring odds and ends tools, jacks/stands. Possibly a trans jack too. This is something I'm probably doing next summer myself anyways
Rymaster is offline   Reply With Quote
Old 11-13-2012, 07:36 AM   #6
02bugeye1
Member#: 270483
2005 impreza wrx sti
World rally blue
It's really easy to pull the transmission out of these things. If your doing throw out bearing makes sense to replace clutch since you have it down to that point
02bugeye1 is offline   Reply With Quote
Old 11-13-2012, 08:01 AM   #7
Wumpus02
Member#: 250233
2002 WRX Wagon
The clutch was replaced not very long ago. I'd say it's less than 6 months old. for some reason something just gave out. Whether it's the throw out bearing or a clutch fork or something worse I don't know. All I know is the car isn't moving without a tow.
Old 11-13-2012, 08:29 AM   #8
02bugeye1
Member#: 270483
World rally blue
Throw out bearing would make a noise when the clutch is pressed
Old 11-13-2012, 10:23 AM   #9
ChefRacer
Member#: 287000
05 LGT wagon 5mt
What do you mean that the car isn't moving? Will it start? Does it go into gear? What exactly is the problem?
Old 11-13-2012, 11:02 AM   #10
Wumpus02
Member#: 250233
2002 WRX Wagon
Car starts but will not go into gear. The shift fork moves freely by hand. I've been told this may be a clip that popped off the throw out bearing/bad throw out bearing/broken shift fork.
Link to the discussion.
Old 11-13-2012, 09:29 PM   #11
ChefRacer
Member#: 287000
05 LGT wagon 5mt
Sounds like the clutch fork is broken
Old 11-27-2012, 10:02 AM   #12
Wumpus02
Member#: 250233
2002 WRX Wagon
Alright. Parts are on order. I picked up a new fork and T-out bearing. Who is available this weekend to do a parking lot trans drop with me? Will need tools jacks and jack stands. I will provide pizza and beer. I want to get this car back up and running ASAP my loner truck from work is a POS.
Old 11-27-2012, 10:25 AM   #13
ChefRacer
Member#: 287000
05 LGT wagon 5mt
I might be able to help. Did you order a new clutch while you've got the trans out?
Old 11-27-2012, 10:51 AM   #14
Wumpus02
Member#: 250233
2002 WRX Wagon
No I just put a new clutch in it a couple months go. I can't really afford ANOTHER clutch. The last clutch job nearly drained my funds. My problems all started after the new clutch was installed.
Old 11-27-2012, 12:00 PM   #15
Rymaster
Member#: 296277
2002 Impreza WRX
I'll know my work schedule in 2 days
Old 11-27-2012, 12:21 PM   #16
ChefRacer
Member#: 287000
05 LGT wagon 5mt
You should check the tranny dip stick and make sure that a: there is fluid in the trans, and b: that the fluid doesn't look terrible. It should be reddish and somewhat translucent. I would also recommend getting at least a qt of trans fluid to compensate for any fluid that spills out when we drop the trans.
Is this parking lot anyplace that you could leave the car for awhile if the problem is in the trans itself?
You are also going to need to get a 32 mm axle nut socket, they are usually a free rental at most auto parts stores unless someone else has one who is coming.
Old 11-27-2012, 03:17 PM   #17
X Mon
Member#: 156443
2006 WRX Wagon WRB
2001 Forester S, EJ205/5m
The proper transmission fluid, for a MANUAL transmission (the clutch is the key word here) is NOT reddish. One can use a typical shallow well 32mm for a Subaru axle nut, although you don't HAVE to take the stub axles out of the hubs.
X Mon is offline   Reply With Quote
Old 11-27-2012, 03:36 PM   #18
ChefRacer
Member#: 287000
05 LGT wagon 5mt
I just drained /filled my trans fluid last week in my MT subaru last week and what came out and went in were both red. Maybe oem gear lube is a different color. My real point about the axle socket is that most people don't keep a 32 mm socket in their set whether it's deep or shallow, but a free rental keeps the costs down for someone who doesn't have much money nor much necessity for suc
Old 11-27-2012, 03:37 PM   #19
ChefRacer
Member#: 287000
05 LGT wagon 5mt
A rarely used socket. Taking the axles out makes removing and installing the trans mu
Old 11-27-2012, 03:38 PM   #20
ChefRacer
Member#: 287000
05 LGT wagon 5mt
Much easier... This nasioc app is a pita. Every time I try to type quickly, I accidentally hit the send button
Old 11-27-2012, 04:54 PM   #21
Wumpus02
Member#: 250233
2002 WRX Wagon
I have a 3/4" drive wrench with a 32mm socket. That's a big mama jama.
Old 11-27-2012, 05:03 PM   #22
ChefRacer
Member#: 287000
05 LGT wagon 5mt
I have a 1/2" drive electric impact gun that works very well for the job and it's very portable
Old 11-27-2012, 05:10 PM   #23
Wumpus02
Member#: 250233
2002 WRX Wagon
I have a 3/8 drive torque wrench also. I have basic hand tools. All of my air powered tools are at my in laws house. Along with my jack and jacks stands. So all I have is hand tools.
Old 11-30-2012, 03:07 PM   #24
Wumpus02
Member#: 250233
2002 WRX Wagon
Anyone who is willing able to come help me fix my car tomorrow shoot me a text @ 814 380 8584. I'll send you my address. I have the parts. This will be in Elkton, MD and I would like to get started as early as possible seeing as it gets dark out early now.
Thanks to all who respond.
Old 12-01-2012, 10:34 AM   #25
Wumpus02
Member#: 250233
2002 WRX Wagon
I've got one person coming out today so far. THERE WILL BE BEER AND FOOD!
