Old 06-19-2010, 09:14 PM   #1
lifwanian
Member#: 232497
02 WRX
Default Exedy - KSB03 vs 15802 Help.
Hey guys,
So my clutch on my 02 Cobb Stage 2 WRX is going out and its time for a new one ASAP.
I make 280hp and 285trq and will be having a new map put on by a buddy of mine that should bump it up a bit more...
Here are my current options -
1. Spend $450 on a Exedy 15802 and not worry about the clutch slipping. I would have to worry about the tranny though, since Im at 100k miles.
2. Buy a slightly used Exedy Stage 1 and lightweight flywheel combo for $300. Has about 5000 miles on it, and is said to be in good condition. The guy said he upgraded to a 6spd and has had it out of his car for a year. I know buying a used one is risk, but what are your thoughts?
3. Buy an Exedy KSB03. Its stock, which is what my Stage 2 made my current clutch slip, but I am low on funds and I did find a great deal. $75 new, but without a throw out bearing, which is around $60 new? So $135 for a new Exedy OEM clutch.
How long do you guys think a new OEM would last with a Stage 2? I drive pretty aggressive at times, and do want to AutoCross in the summer.
Thanks guys!
lifwanian is offline   Reply With Quote
Old 06-19-2010, 10:05 PM   #2
aaron04
Member#: 146569
2009 A4
aaron04 is offline   Reply With Quote
Old 06-19-2010, 10:33 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by lifwanian View Post
Hey guys,
First... 280 Hp / 285 torque from stage 2... I hope those are estimated crank numbers. They're not WHP numbers.
Stock clutches are generally fine for stage 2, your clutch probably had some miles on it anyway and it was just time for your clutch to be done. I wouldn't have any problems putting a stock clutch back on a stage 2 WRX. In fact I did on my own car about 10k miles ago. Stage 2 + E85, holds fine.
Old 06-20-2010, 08:24 PM   #4
lifwanian
Member#: 232497
02 WRX
Ohh Crank for sure! haha...
Thanks guys! I went ahead and got the Exedy KSB03 for $70 and will just stick with that for now. I heard the Stage 1 from Exedy isnt that much of a difference anyways..
Old 11-13-2012, 09:52 PM   #5
zman519
Member#: 118086
Hows it holding?
I have the just about the same setup. I have a 15802 & a Group-S Lightweight Flywheel in my 03 right now that's starting to slip. Its got about 50K on it.
I'm debating putting the same thing back in or trying the KSB03
zman519 is offline   Reply With Quote
Old 11-17-2012, 11:19 PM   #6
XLR8T
Member#: 266684
Where are you buying a KSB03 for 70 bucks new?!?!
XLR8T is offline   Reply With Quote
Old 05-07-2013, 09:07 PM   #7
V-Dub91
Member#: 277461
2005 WRX "STi"
Black Like Me
I call BS, because my stage 2 wrx is pushing about 265whp and 255wtq
V-Dub91 is offline   Reply With Quote
NEW Act Streetlite Flywheel and Exedy KSB03 Clutch kit F.S. koloumb Drivetrain 6 10-03-2009 03:12 PM
oem replacement exedy ksb03 wrx vien Transmission (AT/MT) & Driveline 6 09-22-2009 09:06 PM
Exedy Organic vs Act 6 puck on ej20g w/2.5rs 5mt JDMFLCL Transmission (AT/MT) & Driveline 2 11-20-2008 07:30 PM
exedy hypersport vs exedy sport wrxspdr Transmission (AT/MT) & Driveline 0 07-16-2004 09:17 PM
Exedy single vs. twin plate? ScoobieSnaX Transmission (AT/MT) & Driveline 5 07-29-2002 07:38 AM
