#26 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Yeah, it should. It's really just a piece of material that sits over the top of the turbo. The shape is just contoured to go around the IWG arm. The overall size of the turbine housing doesn't really matter because you just strap it on with wire.
#27 | |
Member#: 301089
NESIC
Vehicle:2011 WRX 5 door TP stage 2 |
the camera has a preloaded adjustable emissivity value for the material that you are looking at. cast iron, aluminum, steel, human skin, plastics, etc. for those that arent sure what emissivity even is--- |
#28 | |
Member#: 301089
NESIC
I can see your point and understand where you are coming from. For me personally while testing, listing the parts that are affected with before and after results and thinking of it as one net result makes sense to me because the goal is to reduce total underhood temps. I like to look at it this way and you do not. Your saying that its misleading because if you are holding a thermometer over the area it would only read 35F +/- less and not 70F. I totally see from that perspective your argument and I agree with you with the information that you presented. I would agree more if I was taking multiple readings from the same componant, then giving a net result. But all things aside, the data is here and there is enough that I would hope that one can see a difference that is proven. Last edited by HeroCrank; 11-09-2012 at 10:35 PM. |
#29 | |
Member#: 301089
NESIC
37F and windy, 2 nights ago. ![]() Last edited by HeroCrank; 11-09-2012 at 09:51 PM. |
#30 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Yeah I am going to get one soon.
#31 |
Member#: 327511
MWSOC
Vehicle:13 WRB GR EL-EWG-E85 |
I, like a few others, just added an original PTP blanket
Now I want lava![]() |
#32 |
Member#: 261612
I got the new turbo blanket. PTP "Lava" version. The black one is the original PTP.
#33 |
Member#: 243992
MWSOC
Vehicle:2006 WRX TR WRB |
I want lava too for less mess bigger size and to match my other wrap. Oh well
#34 |
Member#: 301089
NESIC
Xluben---- nice detailed pics, really shows the differences.
#35 |
Member#: 208216
Vehicle:2013 WRX STI |
Would you guys recommend this for a stock sti? It's a 13 and I already read it fits! Also I know keeping heat low is great for the intercooler, did I just answer my own question? How is hard is installation?
#36 |
Member#: 261612
#37 |
Member#: 301089
NESIC
I would definitely get one, keeping your underhood temps as low as possible is the goal. Installation is super easy and the fit is great.
#38 | |
Member#: 208216
#39 |
Member#: 336966
Vehicle:2013 WRX Satin White Pearl |
And....Mine should be here Thursday. Cheap reliability/performance mod--the 1st one that I've bought (at 889 miles right now on my 13).
#40 |
Member#: 301089
NESIC
#41 | |
Member#: 301089
NESIC
covered internally with an additional material which is called Silica, it's a high temperature rated material that provides extra heat resistance and durability for the blankets. Last edited by HeroCrank; 11-14-2012 at 11:06 AM. |
#42 |
Member#: 336966
#43 |
Member#: 254958
Definitely need to upgrade to a blanket with a better heatshield!
#44 |
Member#: 267212
SWIC
Vehicle:2011 STI Hatch LR |
#45 |
Member#: 301089
NESIC
#46 |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
I think you should ask Perrin to donate one and see how it holds up to the PTP.
#47 |
Member#: 296967
NWIC
Vehicle:2006 spec.B Ti Silver Metallic |
Have always liked my original PTP blanket (in combination with a heatshield lined with DEI Reflect-a-goldŽ). I'll probably get a "lava" when I do a turbo upgrade. Thanks for doing the testing!
#48 |
Member#: 301089
NESIC
#49 |
Member#: 301089
NESIC
Perrin is very busy and tough to get them to follow through. But it would be a fun test to do. I suspect they would be exactly the same or similar, but you never know until I get one in my hands.
#50 |
Member#: 98955
Vehicle:2011 WRX Hatch White |
Did u notice any improvement in spool up or driveability at all? Thanks for sharing this data!
