Old 11-14-2012, 07:38 AM   #26
WRXLTD
Member#: 136314
2014 Grand Cherokee
Originally Posted by MaddMax View Post
I love how everyone blames this initial lean condition at the on-set of boost yet no one has been able to confirm that it truely is the culprit.
It also has nothing to do with emissions. Ford manages to get their Focus ST (turbo) to run a 13:1 or less AFR at 3500rpms.
When I've logged my 2012 WRX with the Torque App, it shows an AFR at ~13.5:1 at the on-set of boost and the richening up into the 12s shorterly thereafter (~4200rpms).
You don't get out much, do you...
WRXLTD is offline   Reply With Quote
Old 11-14-2012, 08:33 AM   #27
shaX 07
Member#: 214530
2013 Veloster Turbo
I thought the Ringland issues were with the STi's, not the WRX? That's been my understanding for the past 3 years.
shaX 07 is offline   Reply With Quote
Old 11-14-2012, 08:38 AM   #28
luan87us
Member#: 335013
2013 Premium WRX 5dr
Can someone shred some light on this?
Old 11-14-2012, 08:44 AM   #29
shaX 07
Member#: 214530
2013 Veloster Turbo
Please do. I do remember the 09 WRX random blown motor issue, but was under the impression that 2010-2013 WRXs had no known major motor/ringland issues...
Old 11-14-2012, 09:29 AM   #30
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Thank you, this is what I was going to post.
And Maddmax, isn't the Torque App just a Bluetooth OBD2 dongle that relays info to a smart phone? I have heard that you shouldn't trust the OBD2 port fr AFR since the stock O2 sensor doesn't have the same range or resolution of a true UEGO. I would only trust what a wideband is telling me for my AFR.
JSchell1309 is offline   Reply With Quote
Old 11-14-2012, 09:37 AM   #31
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
That car can also run on 87oct and be "happy", it just lowers its power output. Subaru needs to step up their game.
shamrock 05 is offline   Reply With Quote
Old 11-14-2012, 10:45 AM   #32
SWP n Gold
Member#: 110783
2010 WRX
It is because of emissions, Clark Turner has confirmed this as he has experience on this topic. Also, look at the graph WRXLTD posted. The AFR is 14:1 until 4,250rpm and doesn't drop to 11:1 until 4,900rpm.
It has affected every WRX engine since the 2004 model year and I believe it's the same model year with the STi.
The 2009 WRX issue was unrelated to this. There was a contamination in one of the materials used in the building process and it affected July-September 2008 build dates for the 2009 WRX. 2009 WRXs built after September 2008 and all subsequent WRX model years don't have this problem, but they still suffer from the lean condition that all WRXs and STIs have since 2004.
The problem won't be resolved until Subaru ditches the EJ-series engine; it's antiquated and eventually won't be able to keep up with modern emissions requirements. Technically, it can't even keep up now unless it runs dangerously lean stock AFRs.
SWP n Gold is offline   Reply With Quote
Old 11-14-2012, 11:20 AM   #33
SLO_Flat4
Member#: 284425
2016 Brocoma 4x4 OR
1973 Porsche 914
The issue still lingers, though it's not really widespread on the wrx. From my experience here and with different techs I've talked to, I've see more issues come as a result of aftermarket tunes than the stock 'crappy tune.' There are plenty of reasons for that though (abuse, bad tuner, etc).
SLO_Flat4 is offline   Reply With Quote
Old 11-14-2012, 07:21 PM   #34
MaddMax
Member#: 9264
2016 BMW M235i 6MT
I do get out quite a bit. Thanks for asking.
I could have sworn this thread was about WRXs and not STIs, concerns about ringland issues, and questions about this lean issue which so many blame on the ringland failures. If that's the case, here's a dyno plot of a stock 2011 WRX from Cobb. Note the AFR compared your STI dyno.
Old 11-15-2012, 10:31 AM   #35
SpicyPeaNut
Member#: 43310
1978 Brat
I for one would like to see a dyno graph from and independent company or person. No offense to Cobb but they are selling a product and marketing it as safer than stock. I hope someone jumps in and posts said dyno graph...
SpicyPeaNut is offline   Reply With Quote
Old 11-16-2012, 05:39 PM   #36
fr0st
Member#: 41618
2008 WRX Hatch
wrb
I assume you mean stage 1 Cobb map ??
No way a stock wrx makes that much power do the ground. 265 hp do not go down to 251 at the wheels. If so, i'm more than surprised.
if it's a stage 1 mapping, then the AFR has been "ajusted" to make it safe.
That's the main reason why i put a cobb stg 1 on mine...reliability... that and a CBE.
fr0st is offline   Reply With Quote
Old 11-16-2012, 06:48 PM   #37
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Depends on the dyno that run was made on. Other dynos will report lower numbers.
You know the drill. "Your results will vary. Subject to terms and conditions. Void where prohibited."
Gallo2011 is offline   Reply With Quote
Old 11-16-2012, 09:46 PM   #38
MaddMax
Member#: 9264
2016 BMW M235i 6MT
That is a stock plot straight from Cobb.
Old 11-16-2012, 11:32 PM   #39
turbolvrwrx
Member#: 335784
2013 WRX
Crystal Black Silica
It has been stated many times that the 265hp factory rating is underrated.
turbolvrwrx is offline   Reply With Quote
Old 11-17-2012, 12:00 AM   #40
JustyWRC
Member#: 153088
2005 Baja Turbo
06 Forester 04 Forester
Originally Posted by yenny View Post
good discussion guys
I guess it comes down to...a very small % sees these failures. But these failures can and still do occur with current models. It does suck if you happen to be one the few with a bad one. I'm sure if subaru had some way remedied the issue more, sales would be better. They have a good product i.e. AWD, boxer rumble, great aggressive exterior looks, fast, fun to drive, under $30k (WRX)
That is just funny to me. Sorry....
Oh yeah I agree if those kind of things you metioned are the driver's fault and subaru shouldn't take the blame for that. I'm talking about people that drove the car with common sense but got a manufacture design problem should not be denied warranty.
I just have issue with people that have these issues saying they don't drive them hard. Sorry. With my experience at my dealership and reading posts on here for 10 years(5 as a registered user), I just don't have sympathy. I have owned an 04 STi, 08 STI, and currently an 09 WRX with 83K miles and never had even a hiccup in any of those cars.
The new DIT in the Forester can run regular. Maybe the next WRX/STI will be able to.
JustyWRC is online now   Reply With Quote
Old 11-28-2012, 07:14 PM   #41
2011rex18
Member#: 321728
2011 WRX Limited
The plot is from an Sti read te bottom stick sti
2011rex18 is offline   Reply With Quote
Old 11-28-2012, 10:00 PM   #42
SWP n Gold
Member#: 110783
2010 WRX
It says "2011 Impreza WRX" on the dyno graph.
Old 11-28-2012, 11:05 PM   #43
JSchell1309
Member#: 321321
Tuxedo Black
shhhh he doesn't know how to read
Old 11-29-2012, 09:31 AM   #44
erik11876
Member#: 275888
2011 WRX Limited
I have it on good authority from two different sources, one is a major player in Subaru tuning game, the other is my uncle who is a machinist on contract to repair Subaru engines for a dealer in Boston, that the ringlands in the 2011 and up EJ25's now have a ceramic coating on the ringlands to help reduce failure. It's very non scientific though, take it as a grain of salt, the engineers from Subaru haven't confirmed this.
erik11876 is offline   Reply With Quote
Old 11-29-2012, 09:36 PM   #45
yenny
Member#: 143116
ooh me like
yenny is offline   Reply With Quote
Old 11-29-2012, 10:57 PM   #46
heavyD
Member#: 194216
2015 FST
The Ecoboost 2.0L is a brand new design with DI which means it can run much higher compression. The EJ25 is an old design that wasn't originally made with today's emission restrictions in mind. There is no doubt that emissions plays a role in the factory tune.
heavyD is offline   Reply With Quote
Old 11-30-2012, 09:17 AM   #47
Djent
Member#: 335681
can someone conffirm this ?
Djent is offline   Reply With Quote
Old 11-30-2012, 11:58 AM   #48
SWP n Gold
Member#: 110783
2010 WRX
This is the first I've heard of that claim through word-of-mouth and I can't find anything supporting it on the internet.
Old 11-30-2012, 02:57 PM   #49
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
just my .02
2010 WRX, stock motor/tune
78,000+ mi and counting
all oil changes performed by the dealer every 3000-3500 mi.
30k and 60k services performed by IAG Performance with K&N air filter.
never a single problem. i do NOT baby my car either. i think if there was a problem with the tune, it probably would have happened to a lot more people. i thnk most of the failures are more probably a result of a defect in the engine, not the tune.
soon i will have a Speaco TMIC + DP + "stage 2" protune with COBB AP, though. so itll be a bit moot after that.
gsrcrxsi is offline   Reply With Quote
Old 11-30-2012, 03:20 PM   #50
SWP n Gold
Member#: 110783
2010 WRX
Originally Posted by gsrcrxsi View Post
just my .02
I don't think it's the tune alone. I think failures occur when you have a fragile tune and owners who:
-don't warm up their car properly before driving "spiritedly"
-use less than optimal gas
-don't follow the maintenance schedule
etc. All of these things together could explain the failures. But there's no denying that these tunes are absurdly lean by aftermarket standards.
