Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 11-09-2012, 04:02 PM   #26
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Originally Posted by juanmedina View Post
will it fit a FP black? I am running no head shields or anything right now
Yeah, it should. It's really just a piece of material that sits over the top of the turbo. The shape is just contoured to go around the IWG arm. The overall size of the turbine housing doesn't really matter because you just strap it on with wire.
xluben is online now   Reply With Quote
Old 11-09-2012, 09:18 PM   #27
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by ecbmxer View Post
Those cameras typically have an adjustable emissivity value, correct? Out of curiosity, what did you have it set to for testing?
the camera has a preloaded adjustable emissivity value for the material that you are looking at. cast iron, aluminum, steel, human skin, plastics, etc.
for those that arent sure what emissivity even is---
Old 11-09-2012, 09:31 PM   #28
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Originally Posted by the suicidal eggroll View Post
That is not a valid assessment of the results, and is incredibly misleading. Your "total temperature difference", be it 70, 120, or 700 degrees, will change depending on the number of different parts you take a measurement of and add together, making that number by itself entirely useless. At a minimum you should be posting the average temperature drop of all components, definitely not the sum.
You wouldn't stick three pots of water outside, measure a 10 deg drop in each, and say that the outside temperature dropped by 30 degrees would you? Add another pot and it's now a 40 deg drop. When you start doing that, the numbers become meaningless. It's really detracting from the validity of your tests for anybody who knows what they're looking at. I promise you, anybody who looks at the numbers and sees what you've done to get that "70F" number will start to question the legitimacy of the rest of the test setup. Especially since no outside temperature is listed for the tests, just the 68F room in which you're doing the tests, which, since the car is spending almost no time in there, doesn't matter.
If the outside temp really didn't change at all, and the idle time is the same in both tests, then those are impressive results.
I can see your point and understand where you are coming from. For me personally while testing, listing the parts that are affected with before and after results and thinking of it as one net result makes sense to me because the goal is to reduce total underhood temps. I like to look at it this way and you do not. Your saying that its misleading because if you are holding a thermometer over the area it would only read 35F +/- less and not 70F.
I totally see from that perspective your argument and I agree with you with the information that you presented. I would agree more if I was taking multiple readings from the same componant, then giving a net result. But all things aside, the data is here and there is enough that I would hope that one can see a difference that is proven.
Old 11-09-2012, 09:45 PM   #29
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
you may want to seriously reconsider that. this is a bare turbo after a hard 1,2,3 wot pull, X2, then popping hood and running to take image. after about a minute it will cool back down to a normal driven 500-550F
37F and windy, 2 nights ago.
Old 11-10-2012, 01:07 PM   #30
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Yeah I am going to get one soon.
juanmedina is online now   Reply With Quote
Old 11-10-2012, 01:58 PM   #31
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
I, like a few others, just added an original PTP blanket Now I want lava
SenorDucK is offline   Reply With Quote
Old 11-10-2012, 08:48 PM   #32
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
I got the new turbo blanket. PTP "Lava" version. The black one is the original PTP.
Old 11-10-2012, 09:09 PM   #33
WhatTurboLag?
Member#: 243992
2006 WRX TR
I want lava too for less mess bigger size and to match my other wrap. Oh well
WhatTurboLag? is offline   Reply With Quote
Old 11-11-2012, 07:56 PM   #34
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Xluben---- nice detailed pics, really shows the differences.
Old 11-11-2012, 08:56 PM   #35
supermaxx123
Member#: 208216
2013 WRX STI
Would you guys recommend this for a stock sti? It's a 13 and I already read it fits! Also I know keeping heat low is great for the intercooler, did I just answer my own question? How is hard is installation?
supermaxx123 is offline   Reply With Quote
Old 11-11-2012, 09:28 PM   #36
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Do you know if the material inside the blanket is different, or is it the just the outer layer? It is very clear that everything externally is different/better.
Old 11-11-2012, 09:29 PM   #37
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
I would definitely get one, keeping your underhood temps as low as possible is the goal. Installation is super easy and the fit is great.
Old 11-12-2012, 12:57 PM   #38
supermaxx123
Member#: 208216
2013 WRX STI
Thanks, I'll definitely be ordering this soon
Old 11-13-2012, 04:38 PM   #39
Syndr78
Member#: 336966
2013 WRX
And....Mine should be here Thursday. Cheap reliability/performance mod--the 1st one that I've bought (at 889 miles right now on my 13).
Syndr78 is offline   Reply With Quote
Old 11-13-2012, 10:51 PM   #40
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Nice choice on your first mod! .....and congrats on your 2013
Old 11-13-2012, 11:01 PM   #41
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
According to ptp, The Lava blankets are made of the same material as the original but then
covered internally with an additional material which is called Silica, it's a high temperature rated material that provides extra heat resistance and durability for the blankets.
Old 11-14-2012, 08:14 AM   #42
Syndr78
Member#: 336966
2013 WRX
Thanks for the congrats, and thanks again for the testing that you've provided the community.
Old 11-14-2012, 11:31 AM   #43
Ghostwhite
Member#: 254958
Definitely need to upgrade to a blanket with a better heatshield!
Ghostwhite is offline   Reply With Quote
Old 11-14-2012, 01:12 PM   #44
Sp2Pilot
Member#: 267212
2011 STI Hatch
LR | 15 FXT
Originally Posted by Philbertio View Post
Arg. so this comes out a month after I bought the original ptp blanket...I feel like I just bought last year's iPod.
P
I feel the same. Mine is still BNIB. Dammit!
Sp2Pilot is offline   Reply With Quote
Old 11-15-2012, 01:37 PM   #45
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Should be an easy sell then, think of it that way
Old 11-15-2012, 02:06 PM   #46
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
I think you should ask Perrin to donate one and see how it holds up to the PTP.
tazswing is offline   Reply With Quote
Old 11-15-2012, 05:50 PM   #47
jaymmmbee
Member#: 296967
2006 spec.B
Ti Silver Metallic
Have always liked my original PTP blanket (in combination with a heatshield lined with DEI Reflect-a-goldŽ). I'll probably get a "lava" when I do a turbo upgrade. Thanks for doing the testing!
jaymmmbee is offline   Reply With Quote
Old 11-15-2012, 08:42 PM   #48
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
you're welcome, and you will be very happy with the lava blanket
Old 11-15-2012, 08:51 PM   #49
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Perrin is very busy and tough to get them to follow through. But it would be a fun test to do. I suspect they would be exactly the same or similar, but you never know until I get one in my hands.
Old 11-16-2012, 02:39 AM   #50
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Did u notice any improvement in spool up or driveability at all? Thanks for sharing this data!
0BlueSTi4 is offline   Reply With Quote
