Old 11-14-2012, 12:27 AM   #1
lowlifeSTI
Member#: 288266
Default legit fuel system?
hey guys,
I'm looking at a used Perrin rotated GT35R kit I found on craigsilst. the seller said he would throw in his pump and injectors for an extra $250, he has DW 850cc top feeds and a DW65c pump. the injectors seem small to me, would those be enough to run this turbo at its maximum efficiency on pump gas? I'm guessing no but he's saying yes, presumably to get more money out of me. I can't find anyone giving out a ballpark HP figure for the pump either.
so I guess the second part to this question would be, if his fuel system components aren't sufficient for 500+ whp on 93, what do I need?
car is a 2009 STI btw. thanks.
lowlifeSTI is offline   Reply With Quote
Old 11-14-2012, 12:56 AM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS and PAR powered.
You're posting this in the factory 2.5L section, so I'm assuming you don't have a built motor. You want 500+whp, you're going to need a built motor, especially on 93. As for the injectors, they do seem small to me too, but I'm an E-85 guy. I know nothing about that pump either.
Old 11-14-2012, 12:58 AM   #3
lowlifeSTI
Member#: 288266
a built rotating assembly is in the plans. this kit won't be going on until I have a shortblock but it's a good deal so I'm just buying it now.
Old 11-14-2012, 10:23 AM   #4
06rexwagon
Member#: 114730
2006 WRX Limited Wag
850cc is fine for a 35R on pump gas.
06rexwagon is offline   Reply With Quote
Old 11-14-2012, 12:52 PM   #5
lowlifeSTI
Member#: 288266
thank you, is the DW65C fuel pump adequate as well?
Old 11-14-2012, 01:12 PM   #6
imma_stocker
Member#: 97043
08 STI - 02 Z28
07 GSXR - 96 CBR
No, you will max out those injectors before you reach a 35R's full potential. Unless they are the best injectors out there and you raise fuel pressure a LOT. For reference, I'm running a slightly smaller turbo and ID1000s with meth. Look in the power proven bragging section to see what a 35R needs (check comparable 35R, a/r must be very close to be apples to apples comparison).
Old 11-14-2012, 05:29 PM   #7
lowlifeSTI
Member#: 288266
so 1200s then? I'd need more injector since I don't plan to use meth, right?
Old 11-14-2012, 06:27 PM   #8
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
What's your IDC with the ID1000's and what turbo are you running.
kellygnsd is online now   Reply With Quote
Old 11-14-2012, 06:41 PM   #9
robduf
Member#: 171837
1999 2.5 RS
Orange-Black
I have a Garrett GT3076R BB Turbo with 850 top feeds. I'm currently sitting just over 400 HP with Meth.
I'm not sure how much bigger the 35 is though.
robduf is offline   Reply With Quote
Old 11-14-2012, 06:46 PM   #10
drewvdw
Member#: 255776
2010 LR WRX
Guys, Kelly brings up a good point, unless you've got the same setup as he's proposing, be sure to include your IDC.
Old 11-14-2012, 09:40 PM   #11
06rexwagon
Member#: 114730
Id1000's flow 870ish.
Old 11-14-2012, 09:53 PM   #12
imma_stocker
Member#: 97043
08 STI - 02 Z28
07 GSXR - 96 CBR
How did you come up with that? Straight from ID's site...
12V feed, 43.5 psi fuel, 125*F. flows 1015cc maxed out.
Not saying you're wrong, I'm missing something.
Old 11-14-2012, 10:16 PM   #13
06rexwagon
Member#: 114730
When they first came out I put a set in a customers car that had maxed out dw850's. they maxed at the same psi as the 850's so I sent them to witchhunter for flow testing. They tested 870-880. I still have the test sheet. Id rates their injectors when tested with gasoline but the industry standard is heptane. Don't get me wrong they are great injectors. I'm a tuner and have tuned dozens of cars with id's and run their 2200's in my personal car.
Old 11-14-2012, 11:45 PM   #14
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
What's your IDC and what turbo do you run please?
Old 11-15-2012, 11:37 AM   #15
imma_stocker
Member#: 97043
08 STI - 02 Z28
07 GSXR - 96 CBR
T60R, idk my IDC as I just leave the tuning stuff to my tuner. He hooked up a conservative stock motor tune so I doubt he past the 85% mark. Same power without meth between ID1000 and WH850. Same flow explains that Guess I'll throw in true 1000 or 1200cc injectors with built shortblock.
EcuFlash doesn't work on windows 8 yet so I can't hookup my laptop. If you really want I can ask my tuner or get a local to log a run.... after I fix my bov gasket leak.
Pressurized meth + 26psi boost + leak =
Message Board Statistics All times are GMT -4. The time now is 06:58 PM.
