Old 11-11-2012, 03:21 PM   #1851
stevejones19
Member#: 275250
2006 WRX
I agree with the airbag. But how long you think it would last on the wheel? Seems like it would just look like crap really quick. But I guess you could always just take it off.. haha
stevejones19 is offline   Reply With Quote
Old 11-11-2012, 03:25 PM   #1852
garudatwo
Member#: 322385
I've seen many older BMW M's with Alcantara steering wheels, and considering their age the wheels are still holding up okay. That's why I'm trying to make a template for the wheel though, so I can simply cut out a new one and restitch whenever it goes bad.
garudatwo is online now   Reply With Quote
Old 11-11-2012, 05:34 PM   #1853
Andrew025
Member#: 303408
04 STi
As long as you're using real alcantara or some high quality suede then it'll hold up fine.
Andrew025 is offline   Reply With Quote
Old 11-12-2012, 12:07 AM   #1854
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Any one else have any cool ideas to share?
NutWagon is offline   Reply With Quote
Old 11-12-2012, 12:12 AM   #1855
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Working on a really nifty OEM looking gauge mounting solution.
Will update with pics once I get a little further into the process.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 11-12-2012, 02:41 AM   #1856
northpolerex
Member#: 192408
2002 wrx
Any pics of them headlights installed and turned on outside in the dark?? Good idea.... Not so good outcome.
northpolerex is offline   Reply With Quote
Old 11-13-2012, 12:47 AM   #1857
kurlyfries
Member#: 282131
2003 wrx
blue
Anyone have any pictures of gauges mounted under a single din radio in the open spot? Thinking about making one sometime soon, and I didn't know if anyone had made one yet?
kurlyfries is offline   Reply With Quote
Old 11-13-2012, 01:39 AM   #1858
gregroot198521
Member#: 280844
2006 STi
Is it possible to mount the single din in the bottom slot? I'd think that it'd be a lot easier (and safer) to read them while moving if they were closer to your view of the road ahead.
gregroot198521 is offline   Reply With Quote
Old 11-13-2012, 01:57 AM   #1859
sfk1412
Member#: 290974
2005 WRX Wagon
I know there not a good brand but glow shift makes a din gauge mount for like $13 or something. If you Google image "din gauge mount" there's some cool pics. Oh and of course the sweet defi cluster
http://www.jscspeed.com/catalog/Univ...e_Cluster.html
sfk1412 is offline   Reply With Quote
Old 11-13-2012, 03:51 AM   #1860
Bradrcr
Member#: 276382
2005 SaaBeeru
Default DIY Backseat Quick Release
I'm working on a full time backseat down flat/wagon tub setup. I'll put the tub DIY up in a couple days when it's done, but I made the quick release pins for getting a truly 'flat' cargo area today, looks rough, but you don't see it in the car:
Here's the link to the DIY: http://forums.nasioc.com/forums/show....php?t=2431817
Bradrcr is offline   Reply With Quote
Old 11-13-2012, 01:57 PM   #1861
hermanclick
Member#: 285656
Originally Posted by hoofhearted View Post
I know this has been done before but just thought i would share. Suede headliner.
I see your headliner and raise you 1 visor and a maplight
hermanclick is offline   Reply With Quote
Old 11-13-2012, 02:34 PM   #1862
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Nice..
krzywhtboi82 is offline   Reply With Quote
Old 11-13-2012, 03:25 PM   #1863
Scooby STIle
Member#: 277027
2004 Impreza WRX STI
How hard is it to do this?
I was thinking of doing it with carbon fiber wrap.
What kind of glue did you use to stick it?
& has it lasted thru the heat?
Scooby STIle is offline   Reply With Quote
Old 11-13-2012, 03:30 PM   #1864
sfk1412
Member#: 290974
2005 WRX Wagon
Somewhat unique cause there pink.
Untitled by sfk 1412, on Flickr
Old 11-13-2012, 03:30 PM   #1865
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
I somehow don't think vinyl wrap of any kind will look good, primarily because of the cushion effect on the visor. It won't affect the Suede because it's a soft material that flexes, but Vinyl is a hardened plastic base.
Kinda like putting tape on a pillow. It will stick, but I'm not sure how long it will last.
spyrule is offline   Reply With Quote
Old 11-13-2012, 03:32 PM   #1866
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
That's sweet but might wanna clean out the leaves a bit
Old 11-13-2012, 03:39 PM   #1867
sfk1412
Member#: 290974
2005 WRX Wagon
I realized that after I posted lol
Old 11-13-2012, 03:40 PM   #1868
Scooby STIle
Member#: 277027
Carbon Fiber wrap is different than carbon fiber vinyl.
Its not a printed sheet like the stuff from autozone or 3M dinoc stuff.
The wrap is actual fabric woven to look like carbon fiber, and you can feel the texture on the weaves.
That's why I was considering doing either my headliner or headliner + sunvisors with it.
Or maybe switch it up and do the headliner with alcantara & have the visors in cf wrap?
I'm just concerned about how hard it might be to take everything out without damaging it as I've never pulled my headliner, or any headliner, out before.
The question about the glue type also. Not sure what will stand up to the heat, as my friend who works for subie specialties tried redoing her headliner, and within a week it was drooping down from the glue warming up and just becoming goo again.
Old 11-13-2012, 03:52 PM   #1869
sfk1412
Member#: 290974
2005 WRX Wagon
I definitely don't have a lot of experience with the Alcantara but with my personal experience I used permatex spray adhesive from the local hardware store. It holds up pretty good, I'm just not to good at laying the fabric. I think most people just use 3M spray adhesive.
Old 11-13-2012, 04:00 PM   #1870
hermanclick
Member#: 285656
It is not hard to do. I would recommend having plenty of work space and patience( I did a full day of prepping on all the pieces to be covered )
Last summer was one of the hottest in Atlanta and i have had no issues with the headliner/maplight or any other pieces that have been covered.
I also treated the fabric with a UV blocker and generally reapply when the interior is getting detailed.
The visors were slipped on like a sock then stitched up on the open end so no glue there.
cheers
Old 11-13-2012, 04:08 PM   #1871
hermanclick
Member#: 285656
Once you remove all your pillars 6 total , dome light,map light,visors and o**** handles it will drop right down. I was able to angle the headliner and slide it out the rear passanger side door ( fully recline your front seats)
cheers
Old 11-13-2012, 04:39 PM   #1872
garudatwo
Member#: 322385
Use DAP Weldwood HHR contact adhesive, it's high heat resistant, more so than the sprays.
Old 11-13-2012, 04:58 PM   #1873
Scooby STIle
Member#: 277027
Thank you alll for the input.
I think I'm gonna buy some wrx door cards and test out the cf wrap and super77 adhesive to see how that holds up before I attempt to do my headliner.
With that said, anyone wanna sell me some 04 wrx door cards? :P
Lol
Old 11-13-2012, 05:24 PM   #1874
Bradrcr
Member#: 276382
2005 SaaBeeru
If 9-2X cards work, I have a set for sale, finally ready to break up the set with the seats- make me an offer.
Old 11-14-2012, 02:02 PM   #1875
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
burkart is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
Message Board Statistics All times are GMT -4. The time now is 06:54 PM.
