Old 11-14-2012, 01:43 PM   #1
paulpat
Member#: 237145
02 WRX
12 FXT
Default Identify 6mt clutch flywheel and pressure plate please!
So I just purchased a 6mt swap from a dismantler. Can you please help me identify these parts. I have seen a Sti flywheel but this one has a recess. Is it because a pull type clutch?
The clutch has markings of fjdo3ou and 1g13a.
flywheel
Thanks in advance. I know its an exedy but what type?
-paul
paulpat is offline   Reply With Quote
Old 11-14-2012, 01:44 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
Yes that is a 6 speed clutch
novacivic is offline   Reply With Quote
Old 11-14-2012, 02:36 PM   #4
paulpat
Member#: 237145
02 WRX
12 FXT
Wow exedyusa emailed me back quickly. Its an OEM flywheel and exedy replacement for OEM. If only I had a picture of the pressure plate.
Old 11-14-2012, 02:54 PM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It wouldn't matter it's likely simply an OEM replacement... said to be good up to and over about 400hp depending on how you drive..
Old 11-15-2012, 10:32 PM   #6
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Iit is a oem 6speed clutch and flywheel and looks to be great shape!5mt is a 6 bolt with no step and 6spd is a 9 bolt with a step on the flywheels,always remember this!
EROCS04SBRUSTI is offline   Reply With Quote
