Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 11-12-2012, 11:41 PM   #14576
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Originally Posted by chuckywang View Post
Stupid question but does the 2012 Impreza have a low tire pressure warning light?
Yes, it has a tire pressure monitoring system (TPMS).
ST Eye is offline   Reply With Quote
Old 11-13-2012, 12:51 PM   #14577
Paradis
Member#: 334647
2012 POS Impreza
Not the Canadien model
Paradis is offline   Reply With Quote
Old 11-13-2012, 07:18 PM   #14578
ST Eye
Member#: 73068
Yep, I had read that before. But the poster is from the US. We tend to have more mandates.
Old 11-13-2012, 08:19 PM   #14579
MattD87
Member#: 126930
2015 Legacy
CGM
While parked on a very steep downhill slope, my 5spd took four tries to go in reverse. It was pretty scary as each time I tried backing up, my car jerked further ahead as if I was in first gear. . Thankfully the fourth try worked as I was 2ft from going down a mountain.
Anybody else have this happen? Maybe a faulty hill assist?
MattD87 is offline   Reply With Quote
Old 11-13-2012, 08:37 PM   #14580
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Yeah I'd get that checked out... my hill start assist is great when I need to reverse. Did you have the car in reverse before you let off the break?
kinger37 is offline   Reply With Quote
Old 11-13-2012, 08:38 PM   #14581
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Put it into 1st gear first or let the clutch up while in neutral . Common issue with Subaru transmissions.
Old 11-13-2012, 08:38 PM   #14582
Zeeper
Member#: 299286
2015 WRX CVT
Reverse gear is not synchronized, and occasionally it will be hard to shift into reverse.
Try shifting first into 2nd or 1st gear to line up the gears then shift into reverse and it should go right in (you don't need to drive in these gears, just keep the clutch in and move the lever into 1st or 2nd to borrow those syncros and line everything up).
I also found it to be a less common problem after putting Amsoil Severe Gear in the front differential/transmission case.
Old 11-14-2012, 01:24 AM   #14583
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Really? Is this Canada wide? I guess that's awesome news, seeing that I don't need to buy a set of TPMS for my summer tires (or masking off the light on the dash for that matter).
Old 11-14-2012, 04:24 AM   #14584
MattD87
Member#: 126930
2015 Legacy
CGM
The car was clearly shifted into reverse each time.
Old 11-14-2012, 05:57 AM   #14585
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Oh, the way you originally described the situation, I thought the problem was that you were having trouble engaging reverse gear, not that you were having a problem with the hill assist.
Old 11-14-2012, 06:33 AM   #14586
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I think hill assist only works when facing uphill
Old 11-14-2012, 06:39 AM   #14587
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^ No, I don't think that's true. I've experienced it facing up and down hill.
Old 11-14-2012, 06:41 AM   #14588
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Time to check the manual (me)
Old 11-14-2012, 07:07 AM   #14589
mckinnon99879
Member#: 314199
2013 WRX
ISM
Hill assist only works facing uphill for me... not reverse
mckinnon99879 is offline   Reply With Quote
Old 11-14-2012, 10:07 AM   #14590
kinger37
Member#: 324423
2012 Impreza Sport
ISM
When did I ever assume it didn't shift into reverse?
Old 11-14-2012, 10:19 AM   #14591
MattD87
Member#: 126930
2015 Legacy
CGM
Wrong quote, relax.
Old 11-14-2012, 11:14 AM   #14592
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Same here, but I need to check the book
Old 11-14-2012, 02:11 PM   #14593
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Anyone else wearing through their floor mats rather quickly? 9000 miles and I've got a good heel mark under the gas pedal.
foghelmut is offline   Reply With Quote
Old 11-14-2012, 02:25 PM   #14594
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Yeah, same here with my OEM rubber mat. Have had them in for about 10000 miles. Just ordered WeatherTechs the other day. Can't wait to get them in the car.
jr0bb5 is offline   Reply With Quote
Old 11-14-2012, 03:32 PM   #14595
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Hill start assist keeps you from rolling backward if in a forward gear, and from rolling forward if in reverse.
Old 11-14-2012, 05:12 PM   #14596
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i found that. i have never had the opportunity to try facing downslope and trying to go in reverse upslope. if that makes sense
Old 11-14-2012, 05:36 PM   #14597
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i think i am going to have to try and add lights in the hatch, just not sure yet if i want to go the led strip method or not
Old 11-14-2012, 05:38 PM   #14598
Paradis
Member#: 334647
2012 POS Impreza
I think Yes
This is a good thing. It takes 1 minute to check the pressure
Old 11-14-2012, 06:05 PM   #14599
Zeeper
Member#: 299286
2015 WRX CVT
It is pretty easy, not as clean an install as drilling the plastic on the hatch door for individual led's though. Much much better lighting though.
Old 11-14-2012, 09:38 PM   #14600
ans2k
Member#: 315631
2012 Impreza Sport
it is a whole lot brighter
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
