Old 11-12-2012, 11:21 PM   #1
johnnyfyv
Member#: 188073
2005 STi
Default Buying a new Turbo for 05 STi
Hey guys
I have a 05 STi and the Turbo is smoking a bit. There are no oil problems or leaks on the outside at least. I'm guessing the problem/leak is internal, inside the turbo. I figured instead of ripping it out and inspecting it, I should just purchase a new one.
This is my first major upgrade/maintenance/purchase for my STi and needed some advice. Did anyone have a good experience with some Turbos? Any suggestions? I don't mind a stock one, but an upgrade is always a plus.
I'm in the Richmond, VA area and also wanted to see if you've had any experience w someone trustworthy that could do the Turbo installation and Tuning?
Thanks for you help.
johnnyfyv is offline   Reply With Quote
Old 11-13-2012, 03:17 PM   #2
johnnyfyv
Member#: 188073
2005 STi
t t t
Old 11-14-2012, 11:35 AM   #3
johnnyfyv
Member#: 188073
2005 STi
t t t
Old 11-14-2012, 01:41 PM   #4
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
Your in the wrong technical section of the forum.
To answer your question, there are way too many options and it all depends on your goals and how much you are willing to spend, if you want to tune it or just swap it out, etc... I recommend you go to the newbie section and look at the stickies for turbos as a good starting point.
gutie04 is offline   Reply With Quote
Old 11-14-2012, 03:32 PM   #5
johnnyfyv
Member#: 188073
2005 STi
Will do thanks!
