Mid Atlantic Impreza Club
Old 11-14-2012, 03:35 PM   #3776
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
When my 4G stops working I'm blaming you Shek. Verizon will get a pass.
saabarupp is offline   Reply With Quote
Old 11-14-2012, 04:49 PM   #3777
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
Originally Posted by Moore Performance View Post
Speaking of changing brake pads.....don't forget to change your timing components! We found this beauty today when doing head gaskets on an 04 sti.
Contact us today about our timing component parts and service packages for all your Subarus!
What happened here? That's not normal for a belt with 100k miles, the owner had to know something was wrong...
BoozeRS05 is offline   Reply With Quote
Old 11-14-2012, 06:17 PM   #3778
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
I would suspect blame would lie with the timing belt guide on the crank pulley
bettner12 is offline   Reply With Quote
Old 11-14-2012, 06:22 PM   #3779
garagedefeat
Member#: 101399
2001 Forester L
Originally Posted by bettner12 View Post
hopefully the pinout is undersized to serve as one last fusible link in order to protect the ECU... maybe someone had already thought about this scenario?
Your mom prefers over-sized pin-outs.
garagedefeat is offline   Reply With Quote
Old 11-14-2012, 10:10 PM   #3780
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
I had a timing belt do that after 100k miles. For probably 60-70k I had a catch can tucked in front of the airbox. When the engine torqued to the side, it pressed the timing belt cover against the catch can. Eventually the cam-pulley guides bit into the belt.
If you want, I can draw a picture of your moms can pressing on my belt
isis is offline   Reply With Quote
Old 11-15-2012, 10:14 AM   #3781
DapRex
Member#: 53308
2004 Impreza Wrx
the bestest colour
I lie with your mom while she cranks my pulley.
DapRex is offline   Reply With Quote
Old 11-15-2012, 01:56 PM   #3782
sk84fun21
Member#: 113300
WRB, LOUD
looking for a td05 8cm housing if anyone has one laying around
sk84fun21 is offline   Reply With Quote
Old 11-15-2012, 03:47 PM   #3783
Moore Performance
Member#: 231489
Originally Posted by MRF582 View Post
^How many miles on that?
58k. It looks like someone else was in this engine before and a timing guide on the plastic covers was loose and rubbing the belt. That'll do it!
Moore Performance is offline   Reply With Quote
Old 11-15-2012, 04:32 PM   #3784
Moore Performance
Member#: 231489
Speaking of td05 8cm housings, make sure you run quality oil in your turbocharged vehicle, especially in modified or high hp applications or else this might happen..........
This was the result of old/low oil level and general maintenance neglect. We have available a full line of Red Line, Brad Penn, AMSOIL, Joe Gibbs, and Rotella products, along with other brands. Contact us today about a oil maintenance program for your specific Subaru.
Old 11-15-2012, 04:56 PM   #3785
stealthx32
Member#: 30990
'93 FD3S
Isn't that like, 95% of all EJ failures? +/- .5 qt = spin your bearings.
Porsche makes reliable boxer motors, and guess what, they're all dry sump/semi-wet.
stealthx32 is offline   Reply With Quote
Old 11-16-2012, 12:20 PM   #3786
MRF582
Member#: 48219
. Always drive
the race line .
PSA - There's a burgundy red 2009 Impreza 2.5i Sedan at Cockrun of Monroeville. 27,900 miles and advertised for $13,800. It has a clean CarFax. I was looking over it yesterday and checking body panels to see if they were hellaflush. The trunk lid was just a tad more recessed than I thought it should be on one side so I opened it and found the bottom side of the rear parcel shelf was painted after an accident. It wasn't a uniform red color like it should've been and you could clearly tell that someone had sprayed red paint on it but missed a LOT of spots! All the other Impreza trunks I've seen all are a nice uniform color that match the color of the car. Also, the power steering belt squeals and the shifter is difficult to move around. And the kicker... That vehicle is 'Subaru Certified'. And of course the salespeople and their manager didn't seem to know about any of this...
MRF582 is offline   Reply With Quote
Old 11-16-2012, 01:02 PM   #3787
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
two mistakes: looking at a GR sedan and going to cockrun.
glhs377 is offline   Reply With Quote
Old 11-16-2012, 01:55 PM   #3788
CodeGT
Member#: 243940
Does anybody need a set of 2004 wrx springs (oem) w/ 45k on them. Free to good home.
CodeGT is offline   Reply With Quote
Old 11-16-2012, 04:09 PM   #3789
BoozeRS05
Member#: 137797
'05 LegacyGT
wagon, 5mt
When I bought my LGT wagon it had 106k miles on it and a new Tbelt, tensioner, pulleys, WP, t-stat, radiator, belts, hoses, ....
Next day after getting it home there was a flapping noise under the timing cover for the first 10 minutes driving so I asked my shop to open it up and they found the same grooved timing belt with punctures every inch or more. Said it was likely the cam guides being too tight. Wasn't very happy.
Old 11-16-2012, 04:57 PM   #3790
MRF582
Member#: 48219
. Always drive
the race line .
Not many other AWD options out there. Plus, the Subaru expertise and support in Pittsburgh is fantastic if it ever needs anything thanks to Moore Performance.
Old 11-16-2012, 05:11 PM   #3791
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Let the fun begin
Old 11-16-2012, 05:36 PM   #3792
MRF582
Member#: 48219
. Always drive
the race line .
^ I hope your recent spending proves to be wasteful this winter! Who's with me?!
Old 11-16-2012, 05:39 PM   #3793
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
I hope so too really.
Old 11-16-2012, 05:41 PM   #3794
stealthx32
Member#: 30990
'93 FD3S
I'm down for snowmageddon pt 2.
Old 11-16-2012, 06:58 PM   #3795
glhs377
Member#: 125388
97 240hp NA GF6
it's winter again? already? i missed out on summer and spring and fall. faaaaaakk!
Old 11-17-2012, 06:02 PM   #3796
MRF582
Member#: 48219
. Always drive
the race line .
Another Subaru owner joins our ranks. Though this one was smart and decided to get a NA model. LOL.
Old 11-17-2012, 06:30 PM   #3797
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
Is that the one from Cochran?? Lol
Jiffy
SubaruWRC is offline   Reply With Quote
Old 11-17-2012, 10:07 PM   #3798
MRF582
Member#: 48219
. Always drive
the race line .
Hell no! This is from a chevy dealership in Freeport.
Old 11-18-2012, 02:17 PM   #3799
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I used to live out that way. Off of Rt. 28 North right?
Old 11-18-2012, 07:28 PM   #3800
ruby-ru
Member#: 44535
2003 PSM WRX
Twinscroll Goodness!
Anyone have in-wall speakers for their home theaters? I'm trying to figure out what I want but live listening options are few around here. So if you have in walls where did you get them from?
I've listened to speakercraft and various contractor grade options but that is about it.
ruby-ru is offline   Reply With Quote
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 07:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 11:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 04:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 10:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 08:23 PM
