Mid Atlantic Impreza Club
Old 11-13-2012, 04:39 PM   #1
psok80
Member#: 295875
Default Please help...Burning smell from engine bay!
Hello MAIC,
I was driving my 2002 WRX last week and noticed a very bad burning smell coming from my engine bay. At first I thought it was someone else's car so I ignored it. The smell went away but then it came back but this time not as strong. I pulled over to investigate. I opened the hood and couldn't smell anything and didnt see anything leaking. I drove home and the smell was gone. I've driven my car a few times since and the smell comes and goes. I cant pin point the problem. It smells almost like a burnt clutch or belt. I have an automatic so its not me burning the clutch and I checked the drive belts and they look fine. Could this be my timing belt??? Or maybe a coolant leak somewhere I cant see??? The smell is very faint when I have the hood open but I can smell it when I have the heat on and the vent open from inside the car as well. The smell seems to be coming from towards the front of the engine bay. The car seems to be driving normal.
Any advice, solution, or point me to a good Subaru mechanic would be great!
addition info: The car has no engine mods.
psok80 is offline   Reply With Quote
Old 11-13-2012, 06:08 PM   #2
DKDunn04
Member#: 275640
1968 Corvette-Yellow
2004 STI-Silver
If it was coolant it would smell sweet. It could be oil burning on the manifold. How many miles are on it? When was the timing belt last changed?
DKDunn04 is offline   Reply With Quote
Old 11-13-2012, 06:25 PM   #3
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
It could be a few issues:
1. Feel the underside of both valve covers. If your hand comes back with oil, you have a leaking or seeping valve cover gasket, which is very common with WRXs and STis above 90K miles. That oil will burn off, and as it gets progressively worse, you can sometimes see some faint smoke coming out of the hood scoop.
If it does turn out to be a leaky valve gasket, do your best to find a knowledgeable friend to help you change them, many shops will charge way too much for this job that realistically takes no more than two-three hours.
2. Gas line seepage under pressure. Look into the gas line recall for Bugeyes. I live in Virginia and got mine changed out for free.
Smurftastic is offline   Reply With Quote
Old 11-13-2012, 09:47 PM   #4
psok80
Member#: 295875
I bought the car used last year. I'm not sure when the timing belt was changed. The car just hit 90k miles.
Old 11-13-2012, 09:53 PM   #5
psok80
Member#: 295875
I havent seen any smoke yet but I'll check these things the next time I have a chance. Thanks
Old 11-14-2012, 01:34 PM   #6
Ls3
Member#: 160895
2003 Impreza WRX
2014 Impreza WRX
Are the passenger side drive axle boots intact?
Ls3 is offline   Reply With Quote
Old 11-14-2012, 01:55 PM   #7
psok80
Member#: 295875
I took a quick look at the axle boots a couple days ago when i put on my stock wheels and the looked good.
Old 11-14-2012, 02:06 PM   #8
2.5_IMP
Member#: 163604
Check your exhaust. I drove over a garbage bag, it stuck to the exhaust and melted. It smelled terrible, but wouldn't smoke. Took a wire wheel on a drill to it, and removed what was left with brake cleaner.
2.5_IMP is offline   Reply With Quote
Old 11-14-2012, 04:18 PM   #9
psok80
Member#: 295875
ill all that to the list of things i have to check
Old 11-14-2012, 04:24 PM   #10
psok80
Member#: 295875
I think i will start gathering parts for my 90k tune up. ill prolly do my water pump and timing belt now instead of at 105k miles. hopefully the problem will be more apparent once i get started.
Does anyone know of a good shop that can do the timing belt/water pump? Im somewhat mechanically inclined but not sure if im up for the task since i live in an apartment building.
Old 11-14-2012, 04:58 PM   #11
05GrayWRX
Member#: 80093
I had a power steering pump going out/leaking on mine a few weeks ago. Didn't recognize the smell at all - sort of a combination of burnt brakes and plastic.
05GrayWRX is offline   Reply With Quote
Old 11-14-2012, 05:22 PM   #12
psok80
Member#: 295875
Were there any other symptoms other than the smell? Were you leaking power steering fluid?
Old 11-14-2012, 05:32 PM   #13
DKDunn04
Member#: 275640
2004 STI-Silver
Where do you live?
Old 11-14-2012, 05:41 PM   #14
psok80
Member#: 295875
Where do you live?
In DC
Old 11-14-2012, 05:58 PM   #15
XxNitr0xX
Member#: 288380
2006 STI
Any coolant loss, looking at the overflow tank? Mine was steadily losing some at a noticeable rate, turns out I had 2 small pin holes in the radiator. Smell was similar to what you're describing, almost burn't clutch.
XxNitr0xX is offline   Reply With Quote
Old 11-15-2012, 04:53 PM   #16
05GrayWRX
Member#: 80093
Yes, you could see fluid on the back and bottom of the pump as well as on the front engine cover. If that is whats causing the smell you should be able to see that the steering fluid is low too.
Old 11-17-2012, 02:31 PM   #17
psok80
Member#: 295875
I found the problem. My valve cover is leaking. I went underneath the car and followed the trail of oil up to the valve cover. It looks like a huge pain in the ass to change though.
Thanks for all the replies and suggestions!
Old 11-17-2012, 02:41 PM   #18
jeffie7
Member#: 321791
05 STi
Although it sounds like you found your problem. For others that find this thread later on. Check the axle seals and the seal between the transmission output shaft and drive axle.
Gear oil makes for a wonderful smell, even more so when it's a blue cocktail.
jeffie7 is offline   Reply With Quote
Old 11-25-2012, 02:23 PM   #19
psok80
Member#: 295875
Axles and seals seem fine.
I decided to do the gasket myself. It wasn't that hard but a pain to get to the bottom bolts.
No more leaking oil!
I change all my spark plugs while I was there to ngk iridium bkr6eix pre gapped to 0.030. Now my engine has a slight hesitation. Any thoughts?
Old 11-25-2012, 03:28 PM   #20
psok80
Member#: 295875
It hesitates when I rev to 1500 rpm. I heard my exhaust backfire once. When I started the engine cold. The rpm jumped to almost 2000 rpm. I can't remember if that was normal or not. The rpm gradually lowers. After its warm it idles fine.
Old 12-02-2012, 03:27 PM   #21
psok80
Member#: 295875
The hesitation is fixed with an $8 can of crc maf cleaner
Old 12-02-2012, 04:20 PM   #22
05wrx89
Member#: 274159
06 sti
obp
Oil could be leaking around the turbo and burning off could be the oil line leaking or something
05wrx89 is offline   Reply With Quote
Old 12-08-2012, 04:45 PM   #23
VoodooGTR
Member#: 103200
2008 Legacy GT SpecB
Gray
I delayed my Transmission fluid once for about 3-5 months because it can be pretty expensive to replace. But when I did, it was a rancid dead animal smell. Funny thing is when I got the nut out, it splashed all over me. Now I smelt like a burnt dead animal. May not be your cause, but it is pretty good FYI of a different smell from your car.
VoodooGTR is offline   Reply With Quote
