Old 10-27-2012, 05:10 PM   #1
colt_4590
Member#: 306908
Angry modded injectors
I have a 03 wrx and romraider. i modded my injectors and am having a hard time what the scaler, tip in enrichment, and latency should be at ive tried some that people have had work for them but they arent for me. i put my stock map and intake back on my car. How can i get these right?
colt_4590 is offline   Reply With Quote
Old 10-27-2012, 09:07 PM   #2
colt_4590
Member#: 306908
My af correction goes down to about -20 then raises to 16 then zeroes out after restarting the ecu but my af#3 for 16 bit ecu is -.78
Old 10-27-2012, 11:44 PM   #3
02htownwrx
Member#: 136566
2002 Impreza WRX
Clear you inbox, it is fulled.
02htownwrx is offline   Reply With Quote
Old 10-27-2012, 11:52 PM   #4
colt_4590
Member#: 306908
Cleared
Old 10-30-2012, 10:22 PM   #5
sonic_wrx189
Member#: 207905
2003 subaru wrx
sonic yellow
Correction. You mean my stock intake.
Get that car tuned and quit sleeping.
sonic_wrx189 is offline   Reply With Quote
Old 11-12-2012, 09:04 PM   #6
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
How did you "Mod" your injectors? Did you get them on a flow bench?
Old 11-14-2012, 06:03 PM   #7
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
the scaling that i use that gets pretty close is 750cc. Latency they are the same injectors so you shouldn't be playing with those. After you get the car running i normally take the lowest maf value up to about 1.6-1.9 volts and look at the front af correction. if it says -20 then i hit the - button about that many times, interpolate from the 1.9 up to say 2.4 and start it again. You should get it pretty dang close from that then romraider will do its magic... but WOT you are gonna have to play a bit to get it where you want
Bamofo is offline   Reply With Quote
Old 11-29-2012, 07:16 PM   #8
atomicfire
Member#: 136296
2005 STi
When doing a baseline for a car, you can only tune for EITHER the intake, OR the injectors. You can't do both at the same time. Put a stock intake back on the car and tune the injectors. Once you have the injectors dialed in, put your aftermarket intake back on and do your scaling there.
atomicfire is offline   Reply With Quote
Old 11-29-2012, 07:19 PM   #9
rocketperson7
Member#: 283968
MBP
just stop
http://www.injectordynamics.com/WhosGettingDrilled.pdf
Old 11-29-2012, 09:25 PM   #10
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Set the car up like you want it to be, with all the mods. You sure as hell can tune everything at once.
Set the injector scalar to 820CC and latency of
6.5V-4.36
9.0V-1.98
11.5V-1.42
14.0V-1.16
16.5V-1.00
turn the timing way down and go do some pulls. If the WOT fueling is lean decrease the scalar by 10cc and try again, if it is rich increase the scalar by 10CC till you are close to your target fueling at >3V MAF. Scale your closed loop MAF scaling. IF you have any fueling issues you may need to tweak your MAF scaling at specific points.
Your fueling should be pretty much set then work on your timing.
Old 12-07-2012, 01:11 AM   #11
04ScottWRX
Member#: 155412
2004 WRX Wagon
Are your injectors re-drilled or do they just have the spray pattern cap taken off?
04ScottWRX is offline   Reply With Quote
Old 02-02-2013, 09:40 AM   #12
colt_4590
Member#: 306908
Spray caps are takin off.
Old 02-04-2013, 07:52 PM   #13
04ScottWRX
Member#: 155412
2004 WRX Wagon
Get them cleaned and flow tested...that way the guessing game will be alot shorter when scaling and tuning. Let us know how it goes.
Old 02-14-2013, 05:31 PM   #14
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^Yeah....the real fun is gonna begin when you get those injectors back and there flow rates are sketchy
ie... 820,825,810,830
mine were 816,820,820,830......wasnt fun gettin em to act equal
Still ****in wit it actually lol
Old 02-14-2013, 06:58 PM   #15
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Personally, I'd deal with 816, 820, 820, 830 by putting 816 in cyl 4 (rear driver side) and the others wherever.
Cut stockers aren't going to get you perfectly matched injectors... It's a cheap way to get ~820cc injectors. There are downsides to that.
You put the lowest flow in #4, as that's what's most closely monitored by the knock sensor and you start tuning with a scalar close to the average of all 4. If you need better than that, you buy aftermarket injectors that are flow matched. You got injectors that are within +/- 1%. That's really not the end of the world.
Old 02-15-2013, 01:05 PM   #16
thorne
Member#: 130063
Silb
I've tuned tons of modded injectors. I've done so many for a while there I was modding a set every weekend. Here's my Experiance
Scalar on 93. 820
Take stock lats and multiply them by 1.05
You should be golden then, If your still having issues do you have a intake on the car?
thorne is offline   Reply With Quote
