#51 |
Member#: 152685
NESIC
Vehicle:2005 VF34 WRX Wagon WRB |
The necessity of a splitter has NOTHING to do with intercooler size! For any intercooler to work properly you need to force air through it, which is why the WRX comes WITH a splitter.
#52 |
Member#: 267793
MWSOC
Vehicle:2007 WRX 320HP/320TQ CGM |
Lol this is getting confusing. I know I need turbo Tmic fuel pump and tune. But now half the people say I dont need splitter half the people say I do. And then from that half say I need to cut it and yadayada
Confused ?? ![]() |
#53 |
Member#: 332887
Tri-State
Vehicle:2012 WRX stage 2+ DGM (sedan) |
For ANY TMIC to properly be used, you NEED a splitter. Otherwise you're just sucking all that air around the engine and the TMIC barely sees any of it. Do yourself a favor and just buy the STI splitter if you get the TMIC lol
#54 | |
Member#: 117767
RMIC
Vehicle:2007 WRX Limited OBP - VF48 |
I'm late to the party but have the setup you seem to be looking for... - VF48 (bolts up just the same as a VF39 & VF43) - STI TMIC & STI splitter (both from an '07 STI) - SPT intake (not a necessity) - Perrin turbo inlet (*read note below) - Walbro 255 fuel pump - Stock injectors (*read note below) - COBB 3" catted TBE - Grimmspeed 3 Port EBCS When I was looking to do this upgrade I looked here then contacted 2 local reputable tuners. The above setup was the general consensus to make the upgrade work properly. If you have the stock intake on the car, keep it. My tuner liked the SPT intake but said he could have achieved the same numbers with the stock intake as well. I already had the SPT intake installed so I just stuck with it. * When installing the VF48 we discovered that my stock turbo inlet had a couple of small tears near where it connects to the turbo. So I installed a new Perrin one in its place. I've read that the stock inlet has a tendency to tear/rip like mine did on the '06-'07 models. Because of this I recommend planning ahead and just replacing/upgrading the inlet when you upgrade the turbo. * The stock injectors should be plenty adequate for the VF39/VF43/VF48 with 91-94 octane fuel. My tuner recommended that I stick with the stock injectors since I wasn't planning on going e85. with the tune, at 19psi, I believe my maximum duty cycle on the injectors is around 85% so there is plenty of headroom. (Note that if you plan on going with e85 you will want to upgrade the injectors.) Last edited by sc00ter; 11-13-2012 at 12:57 AM. |
#55 | |
Member#: 267793
MWSOC
Okay! Ill look for sti splitter then and the turbo inlet as well. I have spt intake and tbe already! |
#56 | |
Member#: 208817
Tri-State
Vehicle:2006 WRX TR Stg2++ CGM |
#57 |
Member#: 322035
BAIC
Vehicle:2003 16g Wrx Sedan Sonic Yellow |
my opinion. Headers, up pipe (if 07 wrx is catted), turbo inlet, sti splitter, ebcs, 255 fuel pump, i say go bigger on the turbo by just a tad like a Big 16g, better then VF. you will be boooostin. Your tranny could handle more then 300, avoid launching and stick with the stock clutch and you'll be golden.
#58 | |
Member#: 117767
RMIC
Definitely a great point about the tranny and the clutch. The stock 5 speed can handle 300whp+ (mine has been going strong for a while now). Just avoid launching it and keep the stock clutch so you can be sure it's the weakest link in the drivetrain. My stock clutch has been going strong on this setup for almost a year now with absolutely no issues. |
#59 | |
Member#: 152685
NESIC
#60 | |
n00b Moderator
Moderator Member#: 140114
MAIC
Vehicle:06 18G Semi Built SGM WRX |
#61 |
Member#: 152685
NESIC
#62 |
Member#: 193590
SCIC
Vehicle:2006 WRX WAGON CGM SoCal F4 #24 |
Since your improving the power on your car, my suggestion is to change the OE engine oil pick up tube to a beefier after-market one (look up killer b oil pick up), if you have not already.
There has been instance where the welds on the pick-up tube would crack on the MY06-07 and starve the engine of oil. |
#63 | |
Member#: 267793
MWSOC
![]() Makes sense why you need the bigger area for bigger tmic now! So I need VF48 Turbo inlet Sti tmic Fuel pump Tune Should be a good project to gain good power! Mike |
#64 |
Member#: 117767
RMIC
^^ Throw an upgraded EBCS onto that list as well. I edited my earlier post to include it because I forgot to list it with my mods. I went with the Grimmspeed 3-Port EBCS and it's been flawless.
I replied to your PM as well. |
#65 |
Member#: 112024
NWIC
Vehicle:03 WRX vf34 wagon 6 spd, track & dd duty |
If you know of a body shop that works on a lot of STI's, you could probably pick up a STI splitter for well under $100. I don't remember exactly what I paid for mine, it was so long ago, but it was somewhere around $25-40. I had to trim it a little to fit under the smaller scoop.
#66 | |
n00b Moderator
MAIC
#67 |
Member#: 106116
NESIC
Vehicle:2006 WRX Ltd Wagon CGM, VF39 Brentuned |
Yes, the WRX has a metal part that goes between the scoop and the intercooler. However, it doesn't have the same horizontal plane that cuts across the middle of the scoop to force air to the front of the IC. So it's not really "splitting" the air. That's what I meant. But yes, the WRX has ducting and a boot to channel the air.
#68 | |
Member#: 117767
RMIC
#69 |
Member#: 307177
BAIC
Vehicle:'04 WRX/WRB Shuckin' & Drivin' |
Sweet mother of God. So much non-sense in here.
Make your life easier...call Turn in Concepts and and they'll tell you everything you need and don't need! |
#70 |
Member#: 238640
Tri-State
Vehicle:2007 WRX STi WRB 450+whp |
OP, why ask people on here when you are ALREADY working with your tuner.
Stop asking people here ASK YOUR TUNER. Looks like you already are. Listen to your tuner, ask him all these questions instead. You will get a lot of misinformation mixed with good information on here. Your tuner can set you straight. End thread. PS. Update your profile as it states you have an 02 WRX . I assume you have an 07 WRX? Last edited by Freep; 11-14-2012 at 02:41 PM. |
#71 | |
Member#: 267793
MWSOC
I asked here first so I had a background as to what things I needed when I talked to my tuner so I wasn't talking and not understanding what what was. This also will help other people who might have to same question/s and clear up info other people may have mistaken |
#72 |
Member#: 267793
MWSOC
Guys all you need to get sti setup on a Wrx is:
VF48 Sti/larger tmic Sti splitter Turbo inlet Bigger fuel pump Tune dyno>street Everything else is just extra, not NEEDED. Ill edit original post to show this so everyone who reads knows thanks! |
#73 |
Member#: 208817
Tri-State
Why do you think you need a fuel pump? It can be added to the list of items not needed.
#74 |
n00b Moderator
MAIC
STI's and WRX's use the same fuel pump. So why would you need one? Answer is, you don't.
#75 |
Member#: 267793
MWSOC
It's one if those precautionary things just in case, it couldn't hurt and only costs $80-$100 so might as well.
