Vancouver Impreza Club
Old 11-14-2012, 12:41 PM   #26
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Originally Posted by DIGGYGV8 View Post
Did I hurt your $200 spacer's feelings with my intarweb patois or something?
All I meant was after seeing that, you need not even talk about bearing damage and what have you. They can be fractured with such a small impact, they simply don't belong on any car that turns IMO.
Drop a forged wheel on the ground from 5 feet and it will be damaged as well. Do they also not belong on a car that turns?
I actually agree that a bolt on spacer should not be used. The thinner the spacer is, the weaker it will be. If you use a bolt through spacer with extended studs the spacer is only taking the clamping load of the lugs and a bit of bearing stress if it's hub and wheel concentric.
Zefy is offline   Reply With Quote
Old 11-14-2012, 03:47 PM   #27
belaud
Member#: 224449
2012 Kit B STI
Midnight ???
Spacers, always the debate.
belaud is offline   Reply With Quote
Old 11-14-2012, 06:45 PM   #28
DIGGYGV8
Member#: 313558
2011 STi Sedan
Originally Posted by slowguy View Post
What are your thoughts on plastic hubrings?
I hope you know where I'm going with this.
FWIW, I've only ever used metal ones I don't care what you guys run... if you like it, then more to you. just my experience. Like how rotas were gods own wheels for price/quality before someone showed that pic of the spokes missing from the barrel
but it won't totally shatter like a rota will it? that was my point.
DIGGYGV8 is offline   Reply With Quote
