#526 |
Member#: 72859
Tri-State
166k 5spd 98 legacy gt wagon original head gaskets and full jdm front end headlights grill foglights side markers
#527 |
Member#: 181333
MY 972.2 LSapprox 200Kreplacing cam, oil pump seals and timing belt.Should I replace head gaskets? are there any recommended?ThanksRich
#528 |
Member#: 259140
I have recently been having over heating problems with my 98 lgt. So far the thermostat water pump and radiator have been replaced. Somehow there is still air getting in the system. Any opinions
#529 |
Member#: 260128
Tri-State
Vehicle:2006 Legacy 2.5i SE Blue |
My 98 Outback just blew the headgaskets. 216k
#530 |
Member#: 22859
Vehicle:2005 Legacy GT White |
My 99 Limited blew a head gasket at 147k miles while I was doing wheelies in an empty Just For Feet parking lot full of snow a couple of years ago. I had my brother replace it for me and it's never been the same since. Intermittent overheating and such. I traded it for my wife's car.
I heard the dealerships were using in WRX head gaskets to replace those that were blown? Anyone can confirm that? |
#531 |
Member#: 19681
RMIC
Vehicle:1998 Legacy Wagon GT Green |
Just blew my second gasket @210k. This time though, I'm swapping in my JDM EJ20 block and heads, until I have time to do the wiring and pop the turbo on there.
#532 |
Member#: 281188
MY-96 bd
Miles-172,345 Trans- auto original and No problems =) |
#533 |
Member#: 94945
MWSOC
Vehicle:1995 Legacy OB 5MT 2003 Forester X 5MT |
#534 |
Member#: 313641
MY-2000 Legacy GT Wagon
Miles-170,000 Trans- Auto Age-12 years Name-twrenwick Left side HG started leaking, ~$1500 to repair, plus had a few other things replaced while it was opened up. |
#535 |
Member#: 181399
Vehicle:05 STi |
so a 98 rs is not a good idea for a beater?
#536 |
Member#: 289011
My 2.5 had a head gasket leaking issue & then it was repaired but the repairs came too late. The constant overheating caused the internal bearings to break down & rod #3 punched its way through the top of the block, necessitating my need to create a hybrid (25D heads/22E block). I did it because I never wanted those previous issues to ever happen again.
#537 |
Member#: 332805
South East
Vehicle:2013 Legacy 2.5 prem white |
I got the extended warrenty cause i got bad luck.
2013 legacy 2.5 1000 miles |
#538 |
Member#: 265789
W. Canada
Vehicle:1997 o/bX2 & ImpzX2 RED, White, Blue Green |
Outback 1 owned since new:
MY-1997 Trans manual Head gaskets went at ~275000 kms. caught early when oil showed up in antifreeze. Head gaskets replaced. Now at 380000 kms and running strong. Outback 2 bought used. MY- 1997 Trams manual Head gaskets blown when I Bought the car with 260000 kms. Replaced the head gaskets right away. At 290000 something bad and noisy happened to the crank. I suspect the previous owner had driven for a while with the head gaskets swapping oil and antifreeze and bearing damage had begun. Replaced engine with jdm turbo ej20k. |
#539 |
Member#: 334146
NWIC
Vehicle:1999 Subaru Legacy 2000 Chevy Silverado 1500 |
MY-99
Miles-126k 5MT Name-tunedbysti No Problem |
#540 |
Member#: 337511
My-04
Miles - 129,000 trans - Auto Age - 8 years Name Outback Head gasket obviously a problem at about 125,000 miles - rapid overheating and a strong smell. It may have been failing much earlier because that "sweet smell" was present for a very long time - as early as 40,000 miles. we always had it serviced at the Subarau dealer so I always assumed that the specified coolant additive was used. |
#541 |
Member#: 305000
MWSOC
Vehicle:2005 Legacy GT 5MT Bright Silver Metallic |
i dont know if i replied to this yet. but
YES my LGT blew them at 60k miles and luckily was covered. the service appt was $2,000 even with the warranty. cylinders 2 and 4. took three weeks to get the car back. |
#542 |
Member#: 332286
MAIC
Vehicle:1997 Legacy Wagon White |
MY - 2011
Miles - 210,xxx Trans - 5mt Age - 15 years HG was replaced at 160k as preventative maintenance. Good to go. EJ22 ftw. |
#543 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
Are you a time traveller? It's 2012, and you've already got 210,000 miles on your 15-year-old 2011 car?
#544 |
Member#: 96293
Tri-State
Vehicle:05 Forester XT AW |
I'm considering the purchase of an '03 Legacy wagon with the 2.5 non-turbo... From what I've read the '03 supposedly isn't affected (according to Subaru). I don't see any signs of external HG failure and the coolant looks clean, the car's got 130K on it... I should be in the green as far as HG is concerned, no?? That's my only real issue with the car, it looks to be in great shape! Any input would be greatly appreciated from 03 owners or those knowledgable
#545 | |
Member#: 300176
SWIC
MY - 1997
Miles - 220k Trans - 5MT Age - 15 The previous owner said Subaru had an engine recall and went in for an engine swap at 40k miles (I purchased her at 80k miles). Therefore only 180k on this engine but zero issues with the head gasket, or really anything with the car. As far as things that have been replaced that wore out on their own (stuff I didn't break) I've replaced the radiator, alternator, a set of front wheel bearings and the driven gear that turns the VSS. Funny thing about that is the shop I took it to tore the trans apart to get to it and they said all the gears were in perfect condition as of 170k miles. Quote:
#546 |
Member#: 210469
just bought an oo with 169K. I'm considering pulling the motor and changing the HG's now as a precaution. It needs a timing belt anyway...
#547 |
Member#: 262052
MWSOC
Vehicle:2001 Legacy Wintergreen |
Got an 01 automatic L sedan with a blown seal somewhere, dripping oil slightly and hitting the exhaust at the Y pipe when I drive, anyone got a fix for it? Or should I just let it be bc it only seems to leak about a half a quart every 3000?
#548 |
Member#: 51823
Vehicle:98 legacy GT blk |
98 gt wagon first blew at 170, I didn't do the work and it only lasted to 210, I did the work this time and replaced it with the six star gaskets. 223 thousand now and looks good.
#549 |
Member#: 344373
Vehicle:2006 Forester XT Steel Grey Metallic |
no CEL light but i think the head gasket is leaking. what does that say?
#550 |
Member#: 120
AKIC
What does what say?
| Thread Tools | |
| Display Modes | |
| Are there any beaches in Hilton Head I can drive my car on? | Silver_04_WRX_SC | South East Region Forum | 7 | 05-25-2010 08:09 PM |
| WTB Mass Area Any subaru with blown head gaskets | 0202Subwrx | Private 'Wanted' Classifieds | 0 | 04-01-2008 10:23 AM |
| those that have driven both 2nd gen Legacy turbo and ~2002 WRX | lag | Legacy Forum | 9 | 10-07-2005 08:05 AM |
| Will a 1st gen Legacy rear sway ('92) fit a 2nd gen Legacy ('99)? | whtlegacy | Brakes, Steering & Suspension | 2 | 06-24-2004 01:38 PM |
| Any 2nd gen MR2 owners here? | Dealer Xing | Tri-State Area Forum | 7 | 12-09-2002 07:55 AM |
