#1 |
Member#: 322684
South East
Vehicle:2012 WRX Ice Silver Metallic |
Today I went over to Rev Works in Winter Springs, FL. Talked for a long time with Matt there and decided on these parts. He took a lot of time to talk about my goals and gave me great pricing!
Part List: Invidia q300 Turbo Back Exhaust Cobb AP Stage 2+ AEM Intake Stainless Steel Brake Lines Perrin Master Cylinder Brace Kartboy SS and Shifter Bushings Install is on Wednesday. Will post pics. Edit: Pics and review on page 2&3 Second set of Mods: TP Stage 2 AEM OTS map Kartboy 12mm Exhaust Hangers Regular and XL Whiteline 24mm Front/22mm Rear Sways Kartboy Front and Rear Endlinks Whiteline HD Steering Rack Bushings Whiteline Positive Shift Kit Group N Tranny Mount Group N Motor Mounts Torque Solutions pitch stop mount Whiteline Rear Diff Inserts
#2 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
you are paying for install on that stuff? why not do it yourself? stage 2 is a nice bump in power.
#3 | |
Member#: 322684
South East
Maybe I'll install the MCB myself at least. lmao. i can find time for that. Im just STOKED to get some more power. |
#4 |
Member#: 335033
Vehicle:2009 wrx Dark Gray Metallic |
You must have a good job. if ur time is worth more than what a shop charges($75/hr). The point at which its not worth it to do your own car work is when your at about 150k/yr. if you make less than 150k/yr its actually worth it to take the day off from work to do the install.
#5 | |
Member#: 322684
South East
Is there any reason I should keep my oem exhaust and intake? Is there a market for it at all? |
#6 |
Member#: 171948
if you wanna sell the car stock, save the parts to reinstall in the future. i sold all my stock parts. i dont wanna swap everything ive done back and will not sell for a long time anyway.i sold just about everything on here.
#7 |
Member#: 300236
Vehicle:2011 WRX Silver |
I wonder if all the people who say "install it yourself" does any of their home/appliance/electronics repair and maintenance themselves...
#8 |
Member#: 171948
this is the usa, we just throw away electronics when they stop working! lol. ive always liked to work on my own vehicles. i understand what you are saying though. not everyone is mechanical or has somewhere to work on their ride.
#9 |
Member#: 313217
Vehicle:2013 STi Sedan Stg 1 Plasma Blue Pearl |
I don't appreciate being told to work on my own car much like most of the people saying this don't appreciate being told "use proper grammar" or "allow me to share with you about something I'm highly skilled at and explain to you why you're a piece of crap for not being highly skilled at it either"
/90% of NASIOC threads |
#10 | |
Member#: 328794
Vehicle:2012 WRX Premium Ice Silver Metal |
![]() OP - do what you want. whatever makes you happy. i think the reason you'll get the "just do it yourself" is because the bolt-ons really aren't that hard to do. -except if your not mechanically inclined, you will mess something up. i'm not expecting a repair manual.. but the install instructions out there today are garbage! your better off NOT even looking at them going straight to google. or have a laptop or tablet with you. just my .02 |
#11 |
Member#: 263954
Vehicle:2008 STi Aspen White / Gold BBS |
I have to know the reason for the brake lines?
#12 | |
Member#: 313217
#13 |
Member#: 301368
Vehicle:2012 WRX PBP |
How hard is it to install a downpipe in driveway?
#14 |
Member#: 324091
I don't think it's the fact that it's hard to do in a driveway, just tedious. Luckily a friend of mine has a lift that I can use in his garage.I'm extremely claustrophobic so I wouldn't be able to just get a couple of jacks and jackstands and do the job.
#15 | |
Member#: 328794
I did my DP and then the q300 CBE a couple weeks later, then removed the q300 CBE two weeks after. ![]() Using ramps because i dont trust my jack stands on my driveway. Anywho, i'd say the heat shield and DP bolts at the turbo suck the most, especially on a raised car (ramps). But i just took brakes as needed and got done. |
#16 |
Member#: 281656
Vehicle:2011 WRX Limited DGM |
That will get you a very solid daily driver, and you'll be happy with it. Very similar to my setup now. Only other thing I would recommend is a group N transmission mount/crossmember bushings.
#17 |
Member#: 276425
#18 | |
Member#: 316278
TXIC
Vehicle:2010 WRX Sedan WRB |
#19 |
Member#: 263954
#20 |
Member#: 255776
Vehicle:2010 LR WRX MPS and PAR powered. |
It'll help pedal feel a bit. Its one of those "why not" mods, especially if you're doing anything with your brakes.
#21 |
Member#: 305656
South East
Vehicle:05 STi White |
It was great talking with you yesterday, and I for one am very excited to be a part of this "cherry popping" *giggity*
See you Wednesday buddy! |
#22 |
Member#: 276209
Vehicle:I am Rub Function>Form |
Throw some better brake fluid (ATE blue) in there while you're at it, you wont regret it.
#23 |
Member#: 255776
I don't know anything about that stuff, but if its anything as expensive as super blue, go with DOT 5.1
#24 | ||
Member#: 276425
ATE Super Blue or another DOT 4 is good enough. |
#25 |
Member#: 268310
Vehicle:2011 STi SSM saloon Church! |
OP, just a humble suggestion. If you're going to go turboback, get your car protuned. Find a competent tuner in your area and have that person tune your engine. You'll be much happier with the results and so will your engine. OTS stage 2 is nice, but the tune is not for your car specifically. A protune will be.
