#26 |
Member#: 287906
Vehicle:2006 STi Black |
I wonder what this would be like on pump 93 for spool up?
#27 |
Member#: 127704
TXIC
Vehicle:2013 Leggy Scooby no4 - huntin for 5 |
Awesome work - TMIC lover here......
Can you get a pull in third for comparo ? |
#28 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
#29 |
Member#: 127704
TXIC
Thats great dude, must be a blast ;-)
#30 |
Member#: 232458
SWIC
Vehicle:2008 STi (OBP) CAMTuned |
Sweetness Juan! Good work
#31 |
Member#: 56203
Vehicle:00 RSTI Coupe |
whats injectors are you running?
What are the IDCs? |
#32 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
That looks pretty good Juan, but honestly I'm not super impressed with the spool of this turbo. We just did a street pull in the car you were comparing this to and here is the boost plot:
![]() That's 20psi by 4000RPM and 25psi before 4300RPM and this is a GT35R with .82 housing with a FMIC. Of course this is a rotated setup, so its not a direct comparison. Oh and this is 4th gear in an 05 STI. The car did 475whp on our dyno (558whp Dynojet). Thanks -- Ed |
#33 | |
Member#: 133146
I have to look at my logs
I am very happy with this stock location 68lb/min turbo... Do you have any FP reds that can compare? Thanks Ed |
#34 | |
Member#: 26933
BAIC
Juan, You hit that in 4th gear with the 07+ STI gearing. This is an 05 STI 4th which is similar to the 5MT 3rd where you're hitting full boost around 4500RPM. Not trying to rain on your parade or anything here. You were just boasting about your spool and I noted that it was misleading because of the 07+ STI gearing. I did an FP Red recently and was not impressed with the spool either. Thanks -- Ed |
#35 |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
My HTA86 hits 27psi by 4400 rpms
#36 | |
Member#: 133146
I think we should look at torque at 4000rpm for comparison. Torque is what makes a car feel good and fun. This is my car on your road dyno, 5sp 3rd gear, FP black 68lb/min stock location. ![]() EQ - 05 STI, EQ Built Block, GT35 Rotated, E85 - 473whp ...65lb/min rotated ![]() EQ - FP Red on E85 - 456whp! 65lb/min stock location ![]() As far as power goes I have no doubt that I will make around the same power if I raise the timing to 26* you probably hit 300wtq by 5000rpm |
#37 |
Member#: 26933
BAIC
Ok. Lets look at torque. The rotated 35r car hits 400ft-lbs by about 4700RPM and keeps going to 460ft-lbs while your car doesn't even hit 400ft-lbs. Also remember that you're comparing your road pull to my dyno pulls. On the road these cars spool a good 300-400RPM sooner than on the dyno in the same gear. I also highly doubt that you would hit the same power with more timing. Your system has significantly more back pressure which means you will hit MBT at a lower ignition advance. I could be wrong of course, but you can't just assume that you're going to pick up 50whp+ without trying it.
Again, I'm not knocking you or your tuning, just saying I'm not a big fan of the current FP turbos. Including the laggy FP red you posted that I tuned. Thanks -- Ed Last edited by Equilibrium Tuning; 11-15-2012 at 10:09 AM. |
#38 | |
Member#: 133146
Understand, I know we are not discussing tuning but we are discussing turbos and setups. This turbo is very good in IMO and I am very happy with it. I don't consider my setup laggy at all, I respect your opinion. |
#39 |
Member#: 287272
Juan, ED - speaking of stock location turbos: How do you think this compares to ATP's GTX3576r (65lb/min) and Blouch's DOM 5.0 (65lb/min)?
I think these are the competition to the FP Black HTA. Similar flow & price point |
#40 |
Member#: 287272
Bump, considering this turbo or atp gtx3576r. Please help with the decision
#41 |
Member#: 152576
SWIC
Vehicle:2006 STI 10.8@ 129 www.Mayhemtuning.com |
#42 |
Member#: 133146
UPDATE
The car is still running strong no issues at all. It has been about 10 months since I installed the engine. I lowered the timing at peak torque like Crystal suggested for safety of the stock 09 STi rods and increased the timing by one degree at redline. 12* at peak torque and 22.5* at redline 7500. ![]() I lost some mid range but It gained about 10whp from 6000rpm to redline. The TMIC is getting head socked as you can see... second pull . I am still running fairly rich 10.9-11.3 AFR from 4000rpm to redline.So, what should I do next? This is a 68lb/min turbo it should be capable of making quite a lot more power. What should give me the biggest gains? |
#43 |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
Glad to hear its still running good! I'm surprised you haven't switched to a fmic yet, that should help quite a bit for power.
#44 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
which compressor housing? 2.4 or 3 inch?
I want videos!!! |
#45 | |
Member#: 133146
That video is with my 5-speed trans I actually went to the 1/8th of the mile track a few weeks back and it wasn't pretty. Without launching, missing third really bad and hitting the rev limiter at the end, I still trapped 90mph ![]() Last edited by juanmedina; 01-06-2013 at 10:23 PM. |
#46 |
Member#: 44836
Vehicle:1999 Fozzy silver |
what bpv are you running?
#47 |
Member#: 155696
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
I'm running a built block on a dom 3 with meth and on my tmic I was making 375/350 and was knocking past 23. I added a txs fmic and was able to run 26.5 safely and made 415/405 so the switch was a major change in power for me
#48 |
Member#: 81102
You need a fmic, Juan!
Glad to see this motor still going strong.Cheers, Carmi. |
#49 |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
FMIC and EWG.
EDIT: I was pressed for time but wanted to get my words in, if only to revisit them later. The FMIC will allow you to run safer, repeatedly. If you're seeing the power drop on a pull, I'm willing to bet its from post intercooler IAT's. Fix that. EWG is also just eliminating a bottleneck in the system. I know you ported your Green out, but an EWG skips it altogether. It does not get better than that. All that said, you're still on thin ice with those rods and the above parts or deeper tuning will more than likely spell the end. Last edited by Zee Biker; 01-07-2013 at 06:35 AM. |
#50 | ||
Member#: 133146
the stock one crushed. I used to have a Forge BPV but some how it cracked by the flange.
