Old 11-14-2012, 11:38 PM   #1
twitch758
Member#: 337923
Default new to subies
Just recently got a 02 wrx wagon. Anyone got any tips an tricks I could put to good use. This is my first subaru. I do have a few issues like minor hesitation n shaking. I replaced plugs since cel was on for a misfire. No cel is on. Everything is fine at wot but under light load it wants to act up sometimes. Any ideas on what it can be an what can fix it? It is bone stock. Thank you for any ideas and tips
twitch758 is offline   Reply With Quote
Old 11-14-2012, 11:58 PM   #2
twitch758
Member#: 337923
Forgot to add it has 236xxx previous owner took very good maintenance of it replaced a lot had aspen white paint job only mods are short shifter and bushings (kart boy) and blitz bov new clutch starter alt battery brakes timing all been done up to date with oil changes etc.
Old 11-15-2012, 07:36 PM   #3
Pandasaurus_rex
Member#: 157114
2002 Impreza WRX
Aspen White & Carbonated
Try seafoam in your intake, it should smooth things out. I'd ditch the bov and get a proper bypass valve. I assume the ecu is tuned for what you are running. These cars don't like blow offs unless properly set up for one. If you still have the stock routing setup, the bov will screw with your throttle lift afr
Pandasaurus_rex is offline   Reply With Quote
Old 11-15-2012, 08:30 PM   #4
Tweeder
Member#: 129922
2007 Titan
Get rid of the blow of valve, no need for it unless you want the Woosh sound. Then just maintain it correctly. But you do not need a tune for it. In fact you can't even tune for the bov. When I got my car it had a hesitation under load or you can say coming into boost. Turned out my fuel pump was going out.
If you have a good tuner local they can diagnose a bad fuel pump by simply pluging in their laptop and seeing what the car is doing.
Tweeder is offline   Reply With Quote
Old 11-15-2012, 08:54 PM   #5
rob1n1
Member#: 276425
2013 335is
Alpine White
Swap the BOV for a stock BPV and come back if you still have a problem.
rob1n1 is online now   Reply With Quote
Old 11-15-2012, 09:36 PM   #6
twitch758
Member#: 337923
I had the stock bov on before and I still had the same hesitation under light load. I know of 2 tuner shops I can go to on a free day from work. Other than that I know my shake is prolly from my snow tires n I live in the city. I had the dealer look over it and my suspension is tight so I'm guessing tires. I plan on getting new ones soon.
Old 11-15-2012, 09:42 PM   #7
twitch758
Member#: 337923
BTW before I changed plugs it was a hole lot worse it had ac delco plugs now its got NGK laser plats. Switching plugs helped a ton just not 100% lol I did use some fuel system cleaner recently also
